[PATCH 4/4] libtests/malloctest/init.c: Fix warning
Thu Nov 20 02:48:45 UTC 2014
On Wed, Nov 19, 2014 at 9:35 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On November 19, 2014 8:34:23 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>>I'd prefer to see it hidden behind a macro, like other
>>compiler-specific stuff (e.g. attributes). It could go in tmacros
>>also, since it should be restricted to testing.
> Can you write this as a macro?
With C99 you can, with _Pragma.
https://gcc.gnu.org/onlinedocs/cpp/Pragmas.html
>>I will oppose any #pragma within cpukit or c subdirectories.
> Me too.
>>-Gedare
>>On Wed, Nov 19, 2014 at 5:45 PM, Joel Sherrill
>>> On 11/19/2014 4:32 PM, Chris Johns wrote:
>>>> On 20/11/2014 6:59 am, Joel Sherrill wrote:
>>>>> +  #pragma GCC diagnostic push
>>>>> +  #pragma GCC diagnostic ignored "-Wnonnull"
>>>> Do we allow the use of #pragma in RTEMS ?
>>> I would say no except for this one particular class.
>>> If a method has the proper prototype with the attribute
>>> "nonnull" on a parameter AND you compiler with -Wnon-null,
>>> then you get a warning for passing a NULL if GCC can detect it.
>>> If a user doesn't compile with this option, then you need a
>>> run-time check and we have them. And we have to test those
>>> NULL checks.
>>> This is TEST code and we are intentionally passing a
>>> hard-coded NULL value in to exercise the run-time check.
>>> We always compile with -Wnon-null so we have to disable
>>> the check for this one specific type of test on methods which
>>> have parameters with this attribute.
>>> Once Trac/Wiki is back up, that should be added to the
>>> Coding Conventions.
>>> FWIW I have never used a pragma in C or C++ before this. Use would
>>> have to be very special and justified than this in test code.
>>>> Chris
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>>> devel mailing list
>>> devel at rtems.org
