Coverity Issue with bdbuf.c
Thu Nov 20 03:10:24 UTC 2014
On November 19, 2014 8:37:47 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>I'm more concerned with the hard-coded cache alignment value, than I
>am with the dead code.
The code is likely not doing what the surge intended but Chris needs to comment on that bases on git blame. :)
Definitely questionable having a hard coded value and then testing it.
>-Gedare
>On Wed, Nov 19, 2014 at 6:10 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Coverity ID: 1255327
>> I think this looks like a legitimately flagged piece of code :
>> 1537   * For unspecified cache alignments we use the CPU alignment.
>> 1538   */
>> assignment: Assigning: cache_aligment = 32U.
>> 1539  cache_aligment = 32; /* FIXME rtems_cache_get_data_line_size()
>> const: At condition cache_aligment <= 0U, the value of cache_aligment
>must
>> be equal to 32.
>> dead_error_condition: The condition cache_aligment <= 0U cannot be
>true.
>> 1540  if (cache_aligment <= 0)
>> CID 1255327 (#1 of 1): Logically dead code (DEADCODE)dead_error_line:
>> Execution cannot reach this statement: cache_aligment = 8U;.
>> 1541    cache_aligment = CPU_ALIGNMENT;
>> Josh .. can you check if CodeSonar flagged this?
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
