Coverity Issue with bdbuf.c
Thu Nov 20 04:06:02 UTC 2014
On 20/11/2014 2:10 pm, Joel Sherrill wrote:
> On November 19, 2014 8:37:47 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>> I'm more concerned with the hard-coded cache alignment value, than I
>> am with the dead code.
> The code is likely not doing what the surge intended but Chris needs to comment on that bases on git blame. :)
Sebastian ? :)
> Definitely questionable having a hard coded value and then testing it.
Yes it should be fixed for 4.11.
