[PATCH 4/4] SPARC: optimize IRQ enable & disable
Daniel Hellstrom daniel at gaisler.com
Thu Nov 20 11:36:41 UTC 2014
On 11/20/2014 12:08 PM, Sebastian Huber wrote:
> On 20/11/14 10:22, Daniel Hellstrom wrote:
>> I will fix this. I missed it since it I never enabled RTEMS_PROFILING.
> I did a test suite run on NGMP with profiling enabled and your patches with a local fix.  So overall they don't make things worse and the median of all maximum thread dispatch disabled times drops a
> bit (Std = Git master, Opt = with your patches).
How should I interpret this, is it all RTEMS test-suite you have run performing the profiling?
Turning on/off interrupts should be faster, but the code calling the on/off routines should also be faster. I used GRMON to extract instruction traces for window overflow/underflow handling to benchmark.
DanielH
