[PATCH 7/8] i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA Extended Display Identification Data
Jan Dolezal dolezj21 at fel.cvut.cz
Thu Nov 20 14:00:32 UTC 2014
 c/src/lib/libbsp/i386/pc386/Makefile.am    |   2 +
 c/src/lib/libbsp/i386/pc386/include/edid.h | 513 +++++++++++++++++++++++++++++
 c/src/lib/libbsp/i386/pc386/include/vbe3.h | 463 ++++++++++++++++++++++++++
 c/src/lib/libbsp/i386/pc386/preinstall.am  |   8 +
 4 files changed, 986 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/pc386/include/edid.h
 create mode 100644 c/src/lib/libbsp/i386/pc386/include/vbe3.h
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index 8c06129..de970a3 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -106,6 +106,8 @@ libbsp_a_SOURCES += console/printk_support.c
 libbsp_a_SOURCES += console/vgacons.c
 libbsp_a_SOURCES += console/exar17d15x.c
 libbsp_a_SOURCES += console/rtd316.c
+include_bsp_HEADERS += include/vbe3.h
+include_HEADERS += include/edid.h
 if USE_CIRRUS_GD5446
 libbsp_a_SOURCES += console/fb_cirrus.c
 else
diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
new file mode 100644
index 0000000..db3ec25
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
@@ -0,0 +1,513 @@
+ * @file edid.h
+ * @ingroup i386_pc386
+ * @brief VESA EDID definitions.
+ * edid.h  - This file contains definitions for constants related to
+ *           VESA Extended Display Identification Data.
+ *          More information can be found at
+ *      <http://www.vesa.org/vesa-standards/free-standards/>
+ *          VESA public standards may be found at
+ *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
+ * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
+ *                     CTU in Prague.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _EDID_H
+#define _EDID_H
+#ifndef ASM /* ASM */
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#include <rtems/score/basedefs.h>
+#define EDID_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
+#define EDID_INLINE_ROUTINE     RTEMS_INLINE_ROUTINE
+/*  VESA Enhanced Extended Display Identification Data (E-EDID) Proposed
+    Release A, March 27, 2007 */
+/* *** Detailed Timing Descriptor Flags *** */
+#define EDID1_DTD_Flag_InterlacedOff            7
+#define EDID1_DTD_Flag_InterlacedMask           0x1
+#define EDID1_DTD_Flag_StereoModeOff            0
+#define EDID1_DTD_Flag_StereoModeMask           0xC1
+/* values for stereo flag */
+#define EDID1_DTD_Stereo_FldSeqRightOnSync      0x40
+#define EDID1_DTD_Stereo_FldSeqLeftOnSync       0x80
+#define EDID1_DTD_Stereo_2wItlvdRightOnEven     0x41
+#define EDID1_DTD_Stereo_2wItlvdLeftOnEven      0x81
+#define EDID1_DTD_Stereo_4wInterleaved          0xC0
+#define EDID1_DTD_Stereo_SideBySideItlvd        0xC1
+/* Analog = 0, Digital = 1 */
+#define EDID1_DTD_Flag_DigitalOff               4
+#define EDID1_DTD_Flag_DigitalMask              0x1
+/* Analog */
+#define EDID1_DTD_BipolarAnalogComposSyncOff    3
+#define EDID1_DTD_BipolarAnalogComposSyncMask   0x1
+#define EDID1_DTD_WithSerrationsOff             2
+#define EDID1_DTD_WithSerrationsMask            0x1
+/* Digital */
+#define EDID1_DTD_DigitalSeparateSyncOff        3
+#define EDID1_DTD_DigitalSeparateSyncMask       0x1
+    /* when DigitalSeparateSync == 0 -> it is composite
+       and WithSerrations defined up in Analog part applies */
+#define EDID1_DTD_VerticalSyncIsPositiveOff     2
+#define EDID1_DTD_VerticalSyncIsPositiveMask    0x1
+#define EDID1_DTD_HorizontalSyncIsPositiveOff   1
+#define EDID1_DTD_HorizontalSyncIsPositiveMask  0x1
+struct DetailedTimingDescriptor {
+    uint8_t PixelClock_div10000[2];
+    uint8_t HorizontalActiveLow;
+    uint8_t HorizontalBlankingLow;
+    uint8_t HorizontalBlanking_ActiveHigh;
+    uint8_t VerticalActiveLow;
+    uint8_t VerticalBlankingLow;
+    uint8_t VerticalBlanking_ActiveHigh;
+    uint8_t HorizontalSyncOffsetLow;
+    uint8_t HorizontalSyncPulseWidthLow;
+    uint8_t VerticalSyncPulseWidth_OffsetLow;
+    uint8_t Vert_Hor_SyncPulseWidth_Offset_High;
+    uint8_t HorizontalImageSizeLow;
+    uint8_t VerticalImageSizeLow;
+    uint8_t Vertical_HorizontalImageSizeHigh;
+    uint8_t HorizontalBorder;
+    uint8_t VerticalBorder;
+    uint8_t Flags;
+} EDID_PACKED_ATTRIBUTE;
+EDID_INLINE_ROUTINE uint16_t DTD_HorizontalActive (
+    struct DetailedTimingDescriptor *dtd)
+    return (dtd->HorizontalActiveLow |
+        (dtd->HorizontalBlanking_ActiveHigh & 0xF0) << 4);
+EDID_INLINE_ROUTINE uint16_t DTD_HorizontalBlanking (
+    return (dtd->HorizontalBlankingLow |
+        (dtd->HorizontalBlanking_ActiveHigh & 0xF) << 8);
+EDID_INLINE_ROUTINE uint16_t DTD_VerticalActive (
+    return (dtd->VerticalActiveLow |
+        (dtd->VerticalBlanking_ActiveHigh & 0xF0) << 4);
+EDID_INLINE_ROUTINE uint16_t DTD_VerticalBlanking (
+    return (dtd->VerticalBlankingLow |
+        (dtd->VerticalBlanking_ActiveHigh & 0xF) << 8);
+EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncPulseWidth (
+    return ((dtd->VerticalSyncPulseWidth_OffsetLow & 0xF) |
+        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x3) << 4);
+EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncOffset (
+    return ((dtd->VerticalSyncPulseWidth_OffsetLow >> 4) |
+        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC) << 2);
+EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncPulseWidth (
+    return (dtd->HorizontalSyncPulseWidthLow |
+        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x30) << 4);
+EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncOffset (
+    return (dtd->HorizontalSyncOffsetLow |
+        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC0) << 2);
+EDID_INLINE_ROUTINE uint16_t DTD_VerticalImageSize (
+    return (dtd->VerticalImageSizeLow |
+        (dtd->Vertical_HorizontalImageSizeHigh & 0xF) << 8);
+EDID_INLINE_ROUTINE uint16_t DTD_HorizontalImageSize (
+    return (dtd->HorizontalImageSizeLow |
+        (dtd->Vertical_HorizontalImageSizeHigh & 0xF0) << 4);
+struct ColorPointData {
+    uint8_t ColorPointWhitePointIndexNumber;
+    uint8_t ColorPointWhiteLowBits;
+    uint8_t ColorPointWhite_x;
+    uint8_t ColorPointWhite_y;
+    uint8_t ColorPointWhiteGamma;
+/* Basic Display Parameters */
+/* Monitor Descriptor - Data Type Tag */
+#define EDID_DTT_MonitorSerialNumber        0xFF
+#define EDID_DTT_ASCIIString                0xFE
+#define EDID_DTT_MonitorRangeLimits         0xFD
+struct MonitorRangeLimits {
+    uint8_t MinVerticalRateInHz;
+    uint8_t MaxVerticalRateInHz;
+    uint8_t MinHorizontalInKHz;
+    uint8_t MaxHorizontalInKHz;
+    uint8_t MaxSupportedPixelClockIn10MHz;
+/* see  VESA, Generalized Timing Formula Standard - GTF
+        Version 1.0, December 18, 1996 */
+    uint8_t GTFStandard[8];
+#define EDID_DTT_MonitorName                0xFC
+#define EDID_DTT_AdditionalColorPointData   0xFB
+/* Standard Timing Identification */
+#define EDID_DTT_AdditionalSTI              0xFA
+#define EDID_DTT_DisplayColorManagement     0xF9
+#define EDID_DTT_CVT3ByteTimingCodes        0xF8
+#define EDID1_CVT_AspectRatioOff            2
+#define EDID1_CVT_AspectRatioMask           0x3
+#define EDID1_CVT_AddressableLinesHighOff   4
+#define EDID1_CVT_AddressableLinesHighMask  0xF
+    /* next 5 bits indicate supported vertical rates */
+#define EDID1_CVT_VerticalRate60HzRBOff     0
+#define EDID1_CVT_VerticalRate60HzRBMask    0x1
+#define EDID1_CVT_VerticalRate85HzOff       1
+#define EDID1_CVT_VerticalRate85HzMask      0x1
+#define EDID1_CVT_VerticalRate75HzOff       2
+#define EDID1_CVT_VerticalRate75HzMask      0x1
+#define EDID1_CVT_VerticalRate60HzOff       3
+#define EDID1_CVT_VerticalRate60HzMask      0x1
+#define EDID1_CVT_VerticalRate50HzOff       4
+#define EDID1_CVT_VerticalRate50HzMask      0x1
+#define EDID1_CVT_PreferredVerticalRateOff  5
+#define EDID1_CVT_PreferredVerticalRateMask 0x3
+#define EDID_CVT_AspectRatio_4_3            0
+#define EDID_CVT_AspectRatio_16_9           1
+#define EDID_CVT_AspectRatio_16_10          2
+#define EDID_CVT_AspectRatio_15_9           3
+#define EDID_CVT_PrefVertRate50Hz           0
+#define EDID_CVT_PrefVertRate60Hz           1
+#define EDID_CVT_PrefVertRate75Hz           2
+#define EDID_CVT_PrefVertRate85Hz           3
+struct CVT3ByteCodeDescriptor {
+    uint8_t AddressableLinesLow;
+    uint8_t AspectRatio_AddressableLinesHigh;
+    uint8_t VerticalRate_PreferredVerticalRate;
+struct CVTTimingCodes3B {
+    uint8_t VersionNumber;
+    struct CVT3ByteCodeDescriptor cvt[4];
+EDID_INLINE_ROUTINE uint16_t edid1_CVT_AddressableLinesHigh (
+    struct CVT3ByteCodeDescriptor *cvt)
+    return (cvt->AddressableLinesLow |
+        (cvt->VerticalRate_PreferredVerticalRate &
+         (EDID1_CVT_AddressableLinesHighMask<<EDID1_CVT_AddressableLinesHighOff)
+        ) << (8-EDID1_CVT_AddressableLinesHighOff) );
+EDID_INLINE_ROUTINE uint8_t edid1_CVT_AspectRatio (
+    return (cvt->AspectRatio_AddressableLinesHigh >> EDID1_CVT_AspectRatioOff) &
+        EDID1_CVT_AspectRatioMask;
+#define EDID_DTT_EstablishedTimingsIII      0xF7
+struct EstablishedTimingsIII {
+    uint8_t RevisionNumber;
+    uint8_t EST_III[12];
+enum EST_III {
+    EST_1152x864_75Hz   = 0,
+    EST_1024x768_85Hz   = 1,
+    EST_800x600_85Hz    = 2,
+    EST_848x480_60Hz    = 3,
+    EST_640x480_85Hz    = 4,
+    EST_720x400_85Hz    = 5,
+    EST_640x400_85Hz    = 6,
+    EST_640x350_85Hz    = 7,
+    EST_1280x1024_85Hz  = 8,
+    EST_1280x1024_60Hz  = 9,
+    EST_1280x960_85Hz   = 10,
+    EST_1280x960_60Hz   = 11,
+    EST_1280x768_85Hz   = 12,
+    EST_1280x768_75Hz   = 13,
+    EST_1280x768_60Hz   = 14,
+    EST_1280x768_60HzRB = 15,
+    EST_1400x1050_75Hz  = 16,
+    EST_1400x1050_60Hz  = 17,
+    EST_1400x1050_60HzRB= 18,
+    EST_1400x900_85Hz   = 19,
+    EST_1400x900_75Hz   = 20,
+    EST_1400x900_60Hz   = 21,
+    EST_1400x900_60HzRB = 22,
+    EST_1360x768_60Hz   = 23,
+    EST_1600x1200_70Hz  = 24,
+    EST_1600x1200_65Hz  = 25,
+    EST_1600x1200_60Hz  = 26,
+    EST_1680x1050_85Hz  = 27,
+    EST_1680x1050_75Hz  = 28,
+    EST_1680x1050_60Hz  = 29,
+    EST_1680x1050_60HzRB= 30,
+    EST_1400x1050_85Hz  = 31,
+    EST_1920x1200_60Hz  = 32,
+    EST_1920x1200_60HzRB= 33,
+    EST_1856x1392_75Hz  = 34,
+    EST_1856x1392_60Hz  = 35,
+    EST_1792x1344_75Hz  = 36,
+    EST_1792x1344_60Hz  = 37,
+    EST_1600x1200_85Hz  = 38,
+    EST_1600x1200_75Hz  = 39,
+    EST_1920x1440_75Hz  = 44,
+    EST_1920x1440_60Hz  = 45,
+    EST_1920x1200_85Hz  = 46,
+    EST_1920x1200_75Hz  = 47,
+#define EDID_DTT_DescriptorSpaceUnused      0x10
+/* DTT 0x0 - 0xF are manufacturer specific */
+struct MonitorDescriptor {
+    uint8_t Flag0[2];
+    uint8_t Flag1;
+    uint8_t DataTypeTag;
+    uint8_t Flag2;
+    uint8_t DescriptorData[13];
+union DTD_MD {
+    struct DetailedTimingDescriptor dtd;
+    struct MonitorDescriptor md;
+#define EDID1_STI_ImageAspectRatioOff           0
+#define EDID1_STI_ImageAspectRatioMask          0x3
+#define EDID1_STI_RefreshRateOff                2
+#define EDID1_STI_RefreshRateMask               0x3F
+#define EDID_STI_DescriptorUnused           0x0101
+#define EDID_STI_AspectRatio_16_10          0
+#define EDID_STI_AspectRatio_4_3            1
+#define EDID_STI_AspectRatio_5_4            2
+#define EDID_STI_AspectRatio_16_9           3
+struct StandardTimingIdentification {
+    uint8_t HorizontalActivePixels;
+    uint8_t ImageAspectRatio_RefreshRate;
+/* Video Input Definition */
+#define EDID1_VID_DigitalSignalLevelOff         7
+#define EDID1_VID_DigitalSignalLevelMask        0x1
+/* for EDID1_VID_DigitalSignalLevelOff = 1 (Digital) */
+#define EDID1_VID_ColorBitDepthOff              4
+#define EDID1_VID_ColorBitDepthMask             0x7 /* see CBD */
+#define EDID1_VID_DigitalVideoStandardSuppOff   0
+#define EDID1_VID_DigitalVideoStandardSuppMask  0xF /* see DVS */
+/* for EDID1_VID_DigitalSignalLevelOff = 0 (Analog) */
+#define EDID1_VID_SignalLevelStandardOff        5
+#define EDID1_VID_SignalLevelStandardMask       0x3
+#define EDID1_VID_VideoSetupBlankOff            4
+#define EDID1_VID_VideoSetupBlankMask           0x1
+#define EDID1_VID_SeparateSyncHandVSignalsOff   3
+#define EDID1_VID_SeparateSyncHandVSignalsMask  0x1
+#define EDID1_VID_SyncSignalOnHorizontalOff     2
+#define EDID1_VID_SyncSignalOnHorizontalMask    0x1
+#define EDID1_VID_SyncSignalOnGreenOff          1
+#define EDID1_VID_SyncSignalOnGreenMask         0x1
+#define EDID1_VID_SerationOnVerticalSyncOff     0
+#define EDID1_VID_SerationOnVerticalSyncMask    0x1
+/* Analog Interface Data Format - Signal Level Standard */
+#define EDID_SLS_0700_0300_1000Vpp             0x0
+#define EDID_SLS_0714_0286_1000Vpp             0x1
+#define EDID_SLS_1000_0400_1400Vpp             0x2
+#define EDID_SLS_0700_0000_0700Vpp             0x3
+/* Color Bit Depths */
+#define CBD_undef               0x0
+#define CBD_6bPerPrimaryColor   0x1
+#define CBD_8bPerPrimaryColor   0x2
+#define CBD_10bPerPrimaryColor  0x3
+#define CBD_12bPerPrimaryColor  0x4
+#define CBD_14bPerPrimaryColor  0x5
+#define CBD_16bPerPrimaryColor  0x6
+#define CBD_reserved            0x7
+/* Digital Video Standard Supported */
+#define DVS_undef               0x0
+#define DVS_DVI                 0x1
+#define DVS_HDMI-a              0x2
+#define DVS_HDMI-b              0x3
+#define DVS_MDDI                0x4
+#define DVS_DiplayPort          0x5
+/* Feature Support */
+#define EDID1_Feature_GTFSupported_mask              0x1
+#define EDID1_Feature_GTFSupported_off               0
+#define EDID1_Feature_PreferredTimingMode_mask       0x1
+#define EDID1_Feature_PreferredTimingMode_off        1
+#define EDID1_Feature_StandardDefaultColorSpace_mask 0x1
+#define EDID1_Feature_StandardDefaultColorSpace_off  2
+#define EDID1_Feature_DisplayType_mask               0x2
+#define EDID1_Feature_DisplayType_off                3
+        /* Refer to VESA DPMS Specification */
+#define EDID1_Feature_ActiveOff_mask                 0x1
+#define EDID1_Feature_ActiveOff_off                  5
+#define EDID1_Feature_Suspend_mask                   0x1
+#define EDID1_Feature_Suspend_off                    6
+#define EDID1_Feature_StandBy_mask                   0x1
+#define EDID1_Feature_StandBy_off                    7
+    /* analog - Display Color Type */
+#define EDID_DisplayType_Monochrome                 0
+#define EDID_DisplayType_RGBcolor                   1
+#define EDID_DisplayType_nonRGBcolor                2
+#define EDID_DisplayType_undef                      3
+    /* digital - Supported Color Encoding Formats */
+#define EDID_DisplayType_RGB444                     0
+#define EDID_DisplayType_RGB444YCrCb444             1
+#define EDID_DisplayType_RGB444YCrCb422             2
+#define EDID_DisplayType_RGB444YCrCb444YCrCb422     3
+struct edid1 {
+    uint8_t Header[8];
+/*  Vendor Product Identification */
+    uint8_t IDManufacturerName[2];
+    uint8_t IDProductCode[2];
+    uint8_t IDSerialNumber[4];
+    uint8_t WeekofManufacture;
+    uint8_t YearofManufacture;
+/*  EDID Structure Version Revision Level */
+    uint8_t Version;
+    uint8_t Revision;
+/*  Basic Display Parameters Features */
+    /* Video Input Definition */
+    uint8_t VideoInputDefinition;
+    uint8_t MaxHorizontalImageSize;
+    uint8_t MaxVerticalImageSize;
+    uint8_t DisplayTransferCharacteristic;
+    /* Feature Support */
+    uint8_t Features;
+/*  Color Characteristics */
+    uint8_t GreenRedLow;
+    uint8_t WhiteBlueLow;
+    uint8_t RedXHigh;
+    uint8_t RedYHigh;
+    uint8_t GreenXHigh;
+    uint8_t GreenYHigh;
+    uint8_t BlueXHigh;
+    uint8_t BlueYHigh;
+    uint8_t WhiteXHigh;
+    uint8_t WhiteYHigh;
+/*  Established Timings I, II, Manufacturer's */
+    uint8_t EST_I_II_Man[3];
+    struct StandardTimingIdentification STI[8];
+/*  Detailed Timing Descriptions / Monitor Descriptions */
+    union DTD_MD dtd_md[4];
+    uint8_t ExtensionFlag;
+    uint8_t Checksum;
+EDID_INLINE_ROUTINE uint16_t edid1_RedX (struct edid1 *edid) {
+    return (edid->RedXHigh<<2) | (edid->GreenRedLow>>6);
+EDID_INLINE_ROUTINE uint16_t edid1_RedY (struct edid1 *edid) {
+    return (edid->RedYHigh<<2) | (edid->GreenRedLow>>4)&&0x3;
+EDID_INLINE_ROUTINE uint16_t edid1_GreenX (struct edid1 *edid) {
+    return (edid->GreenXHigh<<2) | (edid->GreenRedLow>>2)&&0x3;
+EDID_INLINE_ROUTINE uint16_t edid1_GreenY (struct edid1 *edid) {
+    return (edid->GreenYHigh<<2) | (edid->GreenRedLow&0x3);
+EDID_INLINE_ROUTINE uint16_t edid1_BlueX (struct edid1 *edid) {
+    return (edid->BlueXHigh<<2)  | (edid->WhiteBlueLow>>6);
+EDID_INLINE_ROUTINE uint16_t edid1_BlueY (struct edid1 *edid) {
+    return (edid->BlueYHigh<<2)  | (edid->WhiteBlueLow>>4)&&0x3;
+EDID_INLINE_ROUTINE uint16_t edid1_WhiteX (struct edid1 *edid) {
+    return (edid->WhiteXHigh<<2) | (edid->WhiteBlueLow>>2)&&0x3;
+EDID_INLINE_ROUTINE uint16_t edid1_WhiteY (struct edid1 *edid) {
+    return (edid->WhiteYHigh<<2) | (edid->WhiteBlueLow&0x3);
+enum edid1_EstablishedTimings {
+/*  Established Timings I */
+    EST_800x600_60Hz    = 0,
+    EST_800x600_56Hz    = 1,
+    EST_640x480_75Hz    = 2,
+    EST_640x480_72Hz    = 3,
+    EST_640x480_67Hz    = 4,
+    EST_640x480_60Hz    = 5,
+    EST_720x400_88Hz    = 6,
+    EST_720x400_70Hz    = 7,
+/*  Established Timings II */
+    EST_1280x1024_75Hz  = 8,
+    EST_1024x768_75Hz   = 9,
+    EST_1024x768_70Hz   = 10,
+    EST_1024x768_60Hz   = 11,
+    EST_1024x768_87Hz   = 12,
+    EST_832x624_75Hz    = 13,
+    EST_800x600_75Hz    = 14,
+    EST_800x600_72Hz    = 15,
+/*  Manufacturer's Timings */
+    EST_1152x870_75Hz   = 23,
+EDID_INLINE_ROUTINE uint8_t edid1_EstablishedTim (
+    struct edid1 *edid,
+    enum edid1_EstablishedTimings est)
+    return (uint8_t)(edid->EST_I_II_Man[est/8] & (est%8));
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* _VBE_H */
diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
index 0000000..2bf1b59
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
@@ -0,0 +1,463 @@
+ * @file vbe3.h
+ * @brief VESA Bios Extension definitions.
+ * vbe3.h  - This file contains definitions for constants related to VBE.
+ *                     CTU in Prague.
+#ifndef _VBE_H
+#define _VBE_H
+#ifdef __cplusplus
+extern "C" {
+#define VBE3_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
+/*  VESA BIOS EXTENSION (VBE) Core functions Standard
+    Version: 3.0 Date: September 16, 1998               */
+/* VBE RETURN STATUS */
+/* AL == 4Fh: Function is supported */
+/* AL != 4Fh: Function is not supported */
+#define VBE_functionSupported        0x4F
+/* AH == 00h: Function call successful */
+#define VBE_callSuccessful           0x00
+/* AH == 01h: Function call failed */
+#define VBE_callFailed               0x01
+/* AH == 02h: Function is not supported in the current hardware configuration */
+#define VBE_notSupportedInCurHWConf  0x02
+/* AH == 03h: Function call invalid in current video mode */
+#define VBE_callInvalid              0x03
+/* VBE Mode Numbers */
+/* D0-D8 =  Mode number */
+#define VBE_modeNumberMask         0x01FF
+#define VBE_modeNumberShift          0x00
+/* If D8 == 0, this is not a VESA defined VBE mode */
+#define VBE_VESAmodeMask           0x0100
+/* If D8 == 1, this is a VESA defined VBE mode */
+/* D9-D12 =  Reserved by VESA for future expansion (= 0) */
+#define VBE_VESAmodeShift            0x08
+/* If D11 == 0, Use current BIOS default refresh rate */
+#define VBE_refreshRateCtrlMask    0x0800
+/* If D11 == 1, Use user specified CRTC values for refresh rate */
+/* D12-13 = Reserved for VBE/AF (must be 0) */
+#define VBE_refreshRateCtrlShift     0x0B
+/* If D14 == 0, Use Banked/Windowed Frame Buffer */
+#define VBE_linearFlatFrameBufMask 0x4000
+/* If D14 == 1, Use Linear/Flat Frame Buffer */
+#define VBE_linearFlatFrameBufShift  0x0E
+/* If D15 == 0, Clear display memory */
+#define VBE_preserveDispMemMask    0x8000
+/* If D15 == 1, Preserve display memory */
+#define VBE_preserveDispMemShift     0x0F
+/* Graphics modes */
+/* 15-bit mode, Resolution: 640x400,   Colors: 256  */
+#define VBE_R640x400C256      0x100
+/* 15-bit mode, Resolution: 640x480,   Colors: 256  */
+#define VBE_R640x480C256      0x101
+/* 15-bit mode, Resolution: 800x600,   Colors: 16   */
+#define VBE_R800x600C16       0x102
+/* 7-bit mode,  Resolution: 800x600,   Colors: 16   */
+#define VBE_b7R800x600C16     0x6A
+/* 15-bit mode, Resolution: 800x600,   Colors: 256  */
+#define VBE_R800x600C256      0x103
+/* 15-bit mode, Resolution: 1024x768,  Colors: 16   */
+#define VBE_R1024x768C16      0x104
+/* 15-bit mode, Resolution: 1024x768,  Colors: 256  */
+#define VBE_R1024x768C256     0x105
+/* 15-bit mode, Resolution: 1280x1024, Colors: 16   */
+#define VBE_R1280x1024C16     0x106
+/* 15-bit mode, Resolution: 1280x1024, Colors: 256  */
+#define VBE_R1280x1024C256    0x107
+/* 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
+#define VBE_R320x200C32K      0x10D
+/* 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
+#define VBE_R320x200C64K      0x10E
+/* 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
+#define VBE_R320x200C17M      0x10F
+/* 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
+#define VBE_R640x480C32K      0x110
+/* 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
+#define VBE_R640x480C64K      0x111
+/* 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
+#define VBE_R640x480C17M      0x112
+/* 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
+#define VBE_R800x600C32K      0x113
+/* 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
+#define VBE_R800x600C64K      0x114
+/* 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
+#define VBE_R800x600C17M      0x115
+/* 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
+#define VBE_R1024x768C32K     0x116
+/* 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
+#define VBE_R1024x768C64K     0x117
+/* 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
+#define VBE_R1024x768C17M     0x118
+/* 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
+#define VBE_R1280x1024C32K    0x119
+/* 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
+#define VBE_R1280x1024C64K    0x11A
+/* 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
+#define VBE_R1280x1024C17M    0x11B
+#define VBE_SpecialMode       0x81FF
+/* Text modes */
+#define VBE_C80R60            0x108   /* 15-bit mode, Columns: 80,  Rows: 60 */
+#define VBE_C132R25           0x109   /* 15-bit mode, Columns: 132, Rows: 25 */
+#define VBE_C132R43           0x10A   /* 15-bit mode, Columns: 132, Rows: 43 */
+#define VBE_C132R50           0x10B   /* 15-bit mode, Columns: 132, Rows: 50 */
+#define VBE_C132R60           0x10C   /* 15-bit mode, Columns: 132, Rows: 60 */
+/* VBE function numbers - passed in AX register */
+#define VBE_RetVBEConInf       0x4F00 /* Return VBE Controller Information */
+#define VBE_RetVBEModInf       0x4F01 /* Return VBE Mode Information */
+#define VBE_SetVBEMod          0x4F02 /* Set VBE Mode */
+#define VBE_RetCurVBEMod       0x4F03 /* Return Current VBE Mode */
+#define VBE_SavResSta          0x4F04 /* Save/Restore State */
+#define VBE_DisWinCon          0x4F05 /* Display Window Control */
+#define VBE_SetGetLogScaLinLen 0x4F06 /* Set/Get Logical Scan Line Length */
+#define VBE_SetGetDisSta       0x4F07 /* Set/Get Display Start */
+#define VBE_SetGetDACPalFor    0x4F08 /* Set/Get DAC Palette Format */
+#define VBE_SetGetPalDat       0x4F09 /* Set/Get Palette Data */
+#define VBE_RetVBEProModInt    0x4F0A /* Return VBE Protected Mode Interface */
+#define VBE_GetSetpixclo       0x4F0B /* Get/Set pixel clock */
+#define VBE_PowManExt          0x4F10 /* Power Management Extensions (PM) */
+#define VBE_FlaPanIntExt       0x4F11 /* Flat Panel Interface Extensions (FP) */
+#define VBE_AudIntExt          0x4F13 /* Audio Interface Extensions (AI) */
+#define VBE_OEMExt             0x4F14 /* OEM Extensions */
+#define VBE_DisDatCha          0x4F15 /* Display Data Channel (DDC),
+                                         Serial Control Interface (SCI) */
+/* VBE subfunction numbers - passed in BL register */
+#define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
+                                        Specification Information */
+/* *** Structures *** */
+struct VBE_FarPtr {
+    uint16_t offset;
+    uint16_t selector;
+} VBE3_PACKED_ATTRIBUTE;
+struct VBE_PMInfoBlock {
+    uint8_t   Signature[4];    /*  PM Info Block Signature */
+    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
+    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
+    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
+    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
+    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
+    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
+    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
+    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
+    uint8_t   Checksum;        /*  Checksum byte for structure */
+/* General VBE signature */
+#define VBE_SIGNATURE "VESA"
+/* Signature for VBE 2.0 and higher */
+#define VBE20plus_SIGNATURE "VBE2"
+/* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
+#define VBE_END_OF_VideoModeList 0xFFFF
+#define VBE_STUB_VideoModeList 0xFFFF
+struct VBE_VbeInfoBlock {
+    uint8_t   VbeSignature[4];   /*  VBE Signature */
+    uint16_t  VbeVersion;        /*  VBE Version */
+    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
+    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
+    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
+    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
+    /*  Added for VBE 2.0+ */
+    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
+    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
+    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
+    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
+    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
+    /*    area */
+    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
+struct VBE_ModeInfoBlock {
+    /*  Mandatory information for all VBE revisions */
+    uint16_t  ModeAttributes;        /* mode attributes */
+    uint8_t   WinAAttributes;        /* window A attributes */
+    uint8_t   WinBAttributes;        /* window B attributes */
+    uint16_t  WinGranularity;        /* window granularity */
+    uint16_t  WinSize;               /* window size */
+    uint16_t  WinASegment;           /* window A start segment */
+    uint16_t  WinBSegment;           /* window B start segment */
+    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
+    uint16_t  BytesPerScanLine;      /* bytes per scan line */
+    /*  Mandatory information for VBE 1.2 and above */
+    uint16_t  XResolution;           /* horizontal resolution in px or chars */
+    uint16_t  YResolution;           /* vertical resolution in px or chars */
+    uint8_t   XCharSize;             /* character cell width in pixels */
+    uint8_t   YCharSize;             /* character cell height in pixels */
+    uint8_t   NumberOfPlanes;        /* number of memory planes */
+    uint8_t   BitsPerPixel;          /* bits per pixel */
+    uint8_t   NumberOfBanks;         /* number of banks */
+    uint8_t   MemoryModel;           /* memory model type */
+    uint8_t   BankSize;              /* bank size in KB */
+    uint8_t   NumberOfImagePages;    /* number of images */
+    uint8_t   Reserved0;             /* reserved for page function */
+    /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
+    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
+    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
+    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
+    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
+    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
+    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
+    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
+    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
+    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
+    /*  Mandatory information for VBE 2.0 and above */
+    uint32_t *PhysBasePtr;           /* physical address for
+                                        flat memory frame buffer */
+    uint32_t  Reserved1;             /* Reserved - always set to 0 */
+    uint16_t  Reserved2;             /* Reserved - always set to 0 */
+    /*  Mandatory information for VBE 3.0 and above */
+    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
+    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
+    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
+        /* linear modes */
+    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
+    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
+    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
+    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
+    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
+    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
+    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
+    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
+    uint32_t  MaxPixelClock;         /* maximum pixel clock
+                                        (in Hz) for graphics mode */
+    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
+struct VBE_CRTCInfoBlock {
+    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
+    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
+    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
+    uint16_t  VerticalTotal;         /* Vertical total in lines */
+    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
+    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
+    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
+    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
+    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
+    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
+struct VBE_PaletteEntry {
+    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
+    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
+    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
+    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
+struct VBE_SupVbeInfoBlock {
+    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
+    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
+    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
+    uint16_t  OemSoftwareRev;        /* OEM Software revision */
+    uint8_t   Reserved[221];         /* Reserved for description
+                                        strings and future */
+    /*  expansion */
+/* VbeInfoBlock Capabilities */
+/*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
+/*     = 1 DAC width is switchable to 8 bits per primary color */
+#define VBE_DACswitchableMask     0x0001
+/*  D1 = 0 Controller is VGA compatible */
+/*     = 1 Controller is not VGA compatible */
+#define VBE_notVGAcompatibleMask  0x0002
+/*  D2 = 0 Normal RAMDAC operation */
+/*     = 1 When programming large blocks of information to the RAMDAC,
+            use the blank bit in Function 09h. */
+#define VBE_specialRAMDACopMask   0x0004
+/*  D3 = 0 No hardware stereoscopic signaling support */
+/*     = 1 Hardware stereoscopic signaling supported by controller */
+#define VBE_hwStereoscopicMask    0x0008
+/*  D4 = 0 Stereo signaling supported via external VESA stereo connector */
+/*     = 1 Stereo signaling supported via VESA EVC connector */
+#define VBE_supportEVCconnMask    0x0010
+/*  D5-31 = Reserved */
+/* ModeInfoBlock ModeAttributes */
+/*  D0 =  Mode supported by hardware configuration */
+/*   0 =  Mode not supported in hardware */
+/*   1 =  Mode supported in hardware */
+#define VBE_modSupInHWMask        0x0001
+/*  D1 =  1 (Reserved) */
+/*  D2 =  TTY Output functions supported by BIOS */
+/*   0 =  TTY Output functions not supported by BIOS */
+/*   1 =  TTY Output functions supported by BIOS */
+#define VBE_TTYOutSupByBIOSMask   0x0004
+/*  D3 =  Monochrome/color mode (see note below) */
+/*   0 =  Monochrome mode */
+/*   1 =  Color mode */
+#define VBE_ColorModeMask         0x0008
+/*  D4 =  Mode type */
+/*   0 =  Text mode */
+/*   1 =  Graphics mode */
+#define VBE_GraphicsModeMask      0x0010
+/*  D5 =  VGA compatible mode */
+/*   0 =  Yes */
+/*   1 =  No */
+#define VBE_VGACompModeMask       0x0020
+/*  D6 =  VGA compatible windowed memory mode is available */
+/*   0 =  Yes */
+/*   1 =  No */
+#define VBE_VGACompWinMemModeMask 0x0040
+/*  D7 =  Linear frame buffer mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_LinFraBufModeAvaiMask 0x0080
+/*  D8 =  Double scan mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_DblScnModeAvaiMask    0x0100
+/*  D9 =  Interlaced mode is available */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_InterlModeAvaiMask    0x0200
+/*  D10 =  Hardware triple buffering support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_HWTripBufSupMask      0x0400
+/*  D11 =  Hardware stereoscopic display support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_HWSterDispSupMask     0x0800
+/*  D12 =  Dual display start address support */
+/*   0 =  No */
+/*   1 =  Yes */
+#define VBE_DualDispStAdrSupMask  0x1000
+/*  D13-D15 =  Reserved */
+/* ModeInfoBlock WinXAttributes */
+/*  D0 =  Relocatable window(s) supported */
+/*   0 =  Single non-relocatable window only */
+/*   1 =  Relocatable window(s) are supported */
+#define VBE_RelocWinSupMask       0x01
+/*  D1 =  Window readable */
+/*   0 =  Window is not readable */
+/*   1 =  Window is readable */
+#define VBE_WinReadableMask       0x02
+/*  D2 =  Window writeable */
+/*   0 =  Window is not writeable */
+/*   1 =  Window is writeable */
+#define VBE_WinWritableMask       0x04
+/*  D3-D7 =  Reserved */
+/* ModeInfoBlock MemoryModel */
+#define VBE_TextMode              0x00
+#define VBE_CGAGraphics           0x01
+#define VBE_HerculesGraphics      0x02
+#define VBE_Planar                0x03
+#define VBE_PackedPixel           0x04
+#define VBE_NonChain4Color256     0x05
+#define VBE_DirectColor           0x06
+#define VBE_YUV                   0x07
+    /* 0x08-0x0F Reserved, to be defined by VESA */
+    /* 0x10-0xFF To be defined by OEM */
+/* ModeInfoBlock DirectColorModeInfo */
+/*  D0 =  Color ramp is fixed/programmable */
+/*   0 =  Color ramp is fixed */
+/*   1 =  Color ramp is programmable */
+#define VBE_ColRampProgMask       0x01
+/*  D1 =  Bits in Rsvd field are usable/reserved */
+/*   0 =  Bits in Rsvd field are reserved */
+/*   1 =  Bits in Rsvd field are usable by the application */
+#define VBE_RsvdBitsUsableMask    0x02
+/* CRTCInfoBlock Flags */
+/*  D0 =  Double Scan Mode Enable */
+/*   0 =  Graphics mode is not double scanned */
+/*   1 =  Graphics mode is double scanned */
+#define VBE_GrModeDblScanMask     0x01
+/*  D1 =  Interlaced Mode Enable */
+/*   0 =  Graphics mode is non-interlaced */
+/*   1 =  Graphics mode is interlaced */
+#define VBE_GrModeInterlMask      0x02
+/*  D2 =  Horizontal sync polarity */
+/*   0 =  Horizontal sync polarity is positive (+) */
+/*   1 =  Horizontal sync polarity is negative (-) */
+#define VBE_HorSncPolNegMask      0x04
+/*  D3 =  Vertical sync polarity */
+/*   0 =  Vertical sync polarity is positive (+) */
+/*   1 =  Vertical sync polarity is negative (-) */
+#define VBE_VerSncPolNegMask      0x08
+/*  VESA BIOS Extensions/Display Data Channel Standard
+    Version: 1.1 November 18, 1999                      */
+/* VBE/DDC subfunction numbers - passed in BL register */
+#define VBEDDC_Capabilities    0x0   /* Report VBE/DDC Capabilities */
+#define VBEDDC_ReadEDID        0x1   /* Read EDID */
+/* DDC Capabilities */
+/* DDC level supported - returned in BL register */
+/* 0 - DDC1 not supported; 1 - DDC1 supported */
+#define VBEDDC_1SupportedMask  0x1
+/* 0 - DDC2 not supported; 1 - DDC2 supported */
+#define VBEDDC_2SupportedMask  0x2
+/* 0 - Screen not blanked during data transfer;
+   1 - Screen blanked during data transfer */
+#define VBEDDC_scrBlnkDatTrMs  0x4
+/*  VESA BIOS Extensions/Serial Control Interface Standard
+    Version: 1.0 Revision: 2 Date: July 2, 1997         */
+/* VBE/SCI subfunction numbers - passed in BL register */
+#define VBESCI_ReportCapabil   0x10  /* Report VBE/SCI Capabilities */
+#define VBESCI_BegSCLSDACtrl   0x11  /* Begin SCL/SDA control */
+#define VBESCI_EndSCLSDACtrl   0x12  /* End SCL/SDA control */
+#define VBESCI_WrtSCLClkLine   0x13  /* Write SCL clock line */
+#define VBESCI_WrtSDADatLine   0x14  /* Write SDA data line */
+#define VBESCI_RdySCLClkLine   0x15  /* Read SCL clock line */
+#define VBESCI_RdySDADatLine   0x16  /* Read SDA data line */
+/* SCI Capabilities */
+/* I2C level supported - returned in BL register */
+#define VBESCI_capSCLwrtMask   0x1   /* Can write to SCL clock line */
+#define VBESCI_capSDAwrtMask   0x2   /* Can write to SDA data line */
+#define VBESCI_capSCLrdyMask   0x4   /* Can read from SCL clock line */
+#define VBESCI_capSDArdyMask   0x8   /* Can read from SDA data line */
+#ifdef __cplusplus
+#endif /* ASM */
diff --git a/c/src/lib/libbsp/i386/pc386/preinstall.am b/c/src/lib/libbsp/i386/pc386/preinstall.am
index 4314f22..b4ac86b 100644
--- a/c/src/lib/libbsp/i386/pc386/preinstall.am
+++ b/c/src/lib/libbsp/i386/pc386/preinstall.am
@@ -147,6 +147,14 @@ $(PROJECT_INCLUDE)/i386_io.h: ../../i386/shared/comm/i386_io.h $(PROJECT_INCLUDE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i386_io.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/i386_io.h
+$(PROJECT_INCLUDE)/bsp/vbe3.h: include/vbe3.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vbe3.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vbe3.h
+$(PROJECT_INCLUDE)/edid.h: include/edid.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/edid.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/edid.h
 $(PROJECT_INCLUDE)/pcibios.h: ../../i386/shared/pci/pcibios.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pcibios.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/pcibios.h
1.9.1
