[PATCH 2/8] score: i386: functions converting real mode pointer to physical address and back
Thu Nov 20 14:53:11 UTC 2014
On 11/20/2014 8:00 AM, Jan Dolezal wrote:
>  cpukit/score/cpu/i386/cpu_asm.S          | 43 ++++++++++++++++++++++++++++++++
>  cpukit/score/cpu/i386/rtems/score/i386.h | 32 ++++++++++++++++++++++++
>  2 files changed, 75 insertions(+)
> diff --git a/cpukit/score/cpu/i386/cpu_asm.S b/cpukit/score/cpu/i386/cpu_asm.S
> index 9b39567..f3ef4e2 100644
> --- a/cpukit/score/cpu/i386/cpu_asm.S
> +++ b/cpukit/score/cpu/i386/cpu_asm.S
> @@ -327,6 +327,49 @@ SYM (i386_Physical_to_logical):
>          movl    ecx,eax                /* eax = ecx */
>          ret
> + *  int i386_Physical_to_real(
> + *     void     *address,
> + *     uint16_t *segment,
> + *     uint16_t *offset
> + *  Fills segment:offest realmode pointer counted from thirty-two bit physical
> + *  address.
> + *  Returns 0 if unconvertible, 1 if successfuly converted.
I believe the word is "inconvertible" but I had to look it up myself.
http://dictionary.reference.com/browse/inconvertible
> +.set PHYS_PTR_ARG,   4
> +.set RM_PTR_SEG_ARG, 8
> +.set RM_PTR_OFF_ARG, 12
> +       PUBLIC (i386_Physical_to_real)
> +SYM (i386_Physical_to_real):
> +        movl    PHYS_PTR_ARG(esp),eax
> +        cmpl    $0x10FFF0, eax
> +        js      1f
> +        movl    $0, eax
> +        ret
> +1:  	cmpl    $0x100000, eax
> +        js      2f
> +        subl    $0xFFFF0, eax
> +        movl    RM_PTR_OFF_ARG(esp), ecx
> +        movw    ax, (ecx)
> +        movl    RM_PTR_SEG_ARG(esp), ecx
> +        movw    $0xFFFF, (ecx)
> +        movl    $1, eax
> +        ret
> +2: 	movl    eax, edx
> +        and     $0xF, ax
> +        movw    ax, (ecx)
> +        shrl    $4, edx
> +        movw    dx, (ecx)
> +        movl    $1, eax
> +        ret
>  END_CODE
>  END
> diff --git a/cpukit/score/cpu/i386/rtems/score/i386.h b/cpukit/score/cpu/i386/rtems/score/i386.h
> index 57569fc..926627d 100644
> --- a/cpukit/score/cpu/i386/rtems/score/i386.h
> +++ b/cpukit/score/cpu/i386/rtems/score/i386.h
> @@ -186,6 +186,38 @@ void *i386_Physical_to_logical(
> + *  i386_Real_to_physical
> + *  Converts real mode pointer {segment, offset} to physical address.
> +RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
> +    uint16_t segment,
> +    uint16_t offset)
> +    return (void *)(((uint32_t)segment<<4)+offset);
> + *  i386_Physical_to_real
> + *  Retreives real mode pointer elements {segmnet, offset} from physical address
> + *  Function returns the highest segment (base) address possible.
> + *  Example:    input   address - 0x4B3A2
> + *              output  segment - 0x4B3A
> + *                      offset  - 0x2
> + *              input   address - 0x10F12E
> + *              output  segment - 0xFFFF
> + *                      offset  - 0xF13E
> + *  return  0 address not convertible, must be less than 0x10FFEF
> + *          1 segment and offset extracted
> +int i386_Physical_to_real(
> +  void *address,
> +  uint16_t *segment,
> +  uint16_t *offset
>   *  "Simpler" names for a lot of the things defined in this file
