[PATCH 7/8] i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA Extended Display Identification Data
Thu Nov 20 15:00:14 UTC 2014
On 11/20/2014 8:00 AM, Jan Dolezal wrote:
>  c/src/lib/libbsp/i386/pc386/Makefile.am    |   2 +
>  c/src/lib/libbsp/i386/pc386/include/edid.h | 513 +++++++++++++++++++++++++++++
>  c/src/lib/libbsp/i386/pc386/include/vbe3.h | 463 ++++++++++++++++++++++++++
>  c/src/lib/libbsp/i386/pc386/preinstall.am  |   8 +
>  4 files changed, 986 insertions(+)
>  create mode 100644 c/src/lib/libbsp/i386/pc386/include/edid.h
>  create mode 100644 c/src/lib/libbsp/i386/pc386/include/vbe3.h
> diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
> index 8c06129..de970a3 100644
> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
> @@ -106,6 +106,8 @@ libbsp_a_SOURCES += console/printk_support.c
>  libbsp_a_SOURCES += console/vgacons.c
>  libbsp_a_SOURCES += console/exar17d15x.c
>  libbsp_a_SOURCES += console/rtd316.c
> +include_bsp_HEADERS += include/vbe3.h
> +include_HEADERS += include/edid.h
>  if USE_CIRRUS_GD5446
>  libbsp_a_SOURCES += console/fb_cirrus.c
>  else
> diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
> new file mode 100644
> index 0000000..db3ec25
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
> @@ -0,0 +1,513 @@
> + * @file edid.h
> + * @ingroup i386_pc386
> + * @brief VESA EDID definitions.
> + * edid.h  - This file contains definitions for constants related to
> + *           VESA Extended Display Identification Data.
> + *          More information can be found at
> + *      <http://www.vesa.org/vesa-standards/free-standards/>
> + *          VESA public standards may be found at
> + *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
Incorporate this into the file header block.
> + * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
> + *                     CTU in Prague.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifndef _EDID_H
> +#define _EDID_H
> +#ifndef ASM /* ASM */
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +#include <rtems/score/basedefs.h>
> +#define EDID_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
> +#define EDID_INLINE_ROUTINE     RTEMS_INLINE_ROUTINE
> +/*  VESA Enhanced Extended Display Identification Data (E-EDID) Proposed
> +    Release A, March 27, 2007 */
> +/* *** Detailed Timing Descriptor Flags *** */
> +#define EDID1_DTD_Flag_InterlacedOff            7
> +#define EDID1_DTD_Flag_InterlacedMask           0x1
> +#define EDID1_DTD_Flag_StereoModeOff            0
> +#define EDID1_DTD_Flag_StereoModeMask           0xC1
> +/* values for stereo flag */
> +#define EDID1_DTD_Stereo_FldSeqRightOnSync      0x40
> +#define EDID1_DTD_Stereo_FldSeqLeftOnSync       0x80
> +#define EDID1_DTD_Stereo_2wItlvdRightOnEven     0x41
> +#define EDID1_DTD_Stereo_2wItlvdLeftOnEven      0x81
> +#define EDID1_DTD_Stereo_4wInterleaved          0xC0
> +#define EDID1_DTD_Stereo_SideBySideItlvd        0xC1
> +/* Analog = 0, Digital = 1 */
> +#define EDID1_DTD_Flag_DigitalOff               4
> +#define EDID1_DTD_Flag_DigitalMask              0x1
> +/* Analog */
> +#define EDID1_DTD_BipolarAnalogComposSyncOff    3
> +#define EDID1_DTD_BipolarAnalogComposSyncMask   0x1
> +#define EDID1_DTD_WithSerrationsOff             2
> +#define EDID1_DTD_WithSerrationsMask            0x1
> +/* Digital */
> +#define EDID1_DTD_DigitalSeparateSyncOff        3
> +#define EDID1_DTD_DigitalSeparateSyncMask       0x1
> +    /* when DigitalSeparateSync == 0 -> it is composite
> +       and WithSerrations defined up in Analog part applies */
> +#define EDID1_DTD_VerticalSyncIsPositiveOff     2
> +#define EDID1_DTD_VerticalSyncIsPositiveMask    0x1
> +#define EDID1_DTD_HorizontalSyncIsPositiveOff   1
> +#define EDID1_DTD_HorizontalSyncIsPositiveMask  0x1
> +struct DetailedTimingDescriptor {
> +    uint8_t PixelClock_div10000[2];
> +    uint8_t HorizontalActiveLow;
> +    uint8_t HorizontalBlankingLow;
> +    uint8_t HorizontalBlanking_ActiveHigh;
> +    uint8_t VerticalActiveLow;
> +    uint8_t VerticalBlankingLow;
> +    uint8_t VerticalBlanking_ActiveHigh;
> +    uint8_t HorizontalSyncOffsetLow;
> +    uint8_t HorizontalSyncPulseWidthLow;
> +    uint8_t VerticalSyncPulseWidth_OffsetLow;
> +    uint8_t Vert_Hor_SyncPulseWidth_Offset_High;
> +    uint8_t HorizontalImageSizeLow;
> +    uint8_t VerticalImageSizeLow;
> +    uint8_t Vertical_HorizontalImageSizeHigh;
> +    uint8_t HorizontalBorder;
> +    uint8_t VerticalBorder;
> +    uint8_t Flags;
> +} EDID_PACKED_ATTRIBUTE;
Doxygen on small methods?
> +EDID_INLINE_ROUTINE uint16_t DTD_HorizontalActive (
> +    struct DetailedTimingDescriptor *dtd)
> +    return (dtd->HorizontalActiveLow |
> +        (dtd->HorizontalBlanking_ActiveHigh & 0xF0) << 4);
> +EDID_INLINE_ROUTINE uint16_t DTD_HorizontalBlanking (
> +    return (dtd->HorizontalBlankingLow |
> +        (dtd->HorizontalBlanking_ActiveHigh & 0xF) << 8);
> +EDID_INLINE_ROUTINE uint16_t DTD_VerticalActive (
> +    return (dtd->VerticalActiveLow |
> +        (dtd->VerticalBlanking_ActiveHigh & 0xF0) << 4);
> +EDID_INLINE_ROUTINE uint16_t DTD_VerticalBlanking (
> +    return (dtd->VerticalBlankingLow |
> +        (dtd->VerticalBlanking_ActiveHigh & 0xF) << 8);
> +EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncPulseWidth (
> +    return ((dtd->VerticalSyncPulseWidth_OffsetLow & 0xF) |
> +        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x3) << 4);
> +EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncOffset (
> +    return ((dtd->VerticalSyncPulseWidth_OffsetLow >> 4) |
> +        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC) << 2);
> +EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncPulseWidth (
> +    return (dtd->HorizontalSyncPulseWidthLow |
> +        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x30) << 4);
> +EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncOffset (
> +    return (dtd->HorizontalSyncOffsetLow |
> +        (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC0) << 2);
> +EDID_INLINE_ROUTINE uint16_t DTD_VerticalImageSize (
> +    return (dtd->VerticalImageSizeLow |
> +        (dtd->Vertical_HorizontalImageSizeHigh & 0xF) << 8);
> +EDID_INLINE_ROUTINE uint16_t DTD_HorizontalImageSize (
> +    return (dtd->HorizontalImageSizeLow |
> +        (dtd->Vertical_HorizontalImageSizeHigh & 0xF0) << 4);
> +struct ColorPointData {
> +    uint8_t ColorPointWhitePointIndexNumber;
> +    uint8_t ColorPointWhiteLowBits;
> +    uint8_t ColorPointWhite_x;
> +    uint8_t ColorPointWhite_y;
> +    uint8_t ColorPointWhiteGamma;
> +/* Basic Display Parameters */
> +/* Monitor Descriptor - Data Type Tag */
> +#define EDID_DTT_MonitorSerialNumber        0xFF
> +#define EDID_DTT_ASCIIString                0xFE
> +#define EDID_DTT_MonitorRangeLimits         0xFD
> +struct MonitorRangeLimits {
> +    uint8_t MinVerticalRateInHz;
> +    uint8_t MaxVerticalRateInHz;
> +    uint8_t MinHorizontalInKHz;
> +    uint8_t MaxHorizontalInKHz;
> +    uint8_t MaxSupportedPixelClockIn10MHz;
> +/* see  VESA, Generalized Timing Formula Standard - GTF
> +        Version 1.0, December 18, 1996 */
> +    uint8_t GTFStandard[8];
> +#define EDID_DTT_MonitorName                0xFC
> +#define EDID_DTT_AdditionalColorPointData   0xFB
> +/* Standard Timing Identification */
> +#define EDID_DTT_AdditionalSTI              0xFA
> +#define EDID_DTT_DisplayColorManagement     0xF9
> +#define EDID_DTT_CVT3ByteTimingCodes        0xF8
> +#define EDID1_CVT_AspectRatioOff            2
> +#define EDID1_CVT_AspectRatioMask           0x3
> +#define EDID1_CVT_AddressableLinesHighOff   4
> +#define EDID1_CVT_AddressableLinesHighMask  0xF
> +    /* next 5 bits indicate supported vertical rates */
> +#define EDID1_CVT_VerticalRate60HzRBOff     0
> +#define EDID1_CVT_VerticalRate60HzRBMask    0x1
> +#define EDID1_CVT_VerticalRate85HzOff       1
> +#define EDID1_CVT_VerticalRate85HzMask      0x1
> +#define EDID1_CVT_VerticalRate75HzOff       2
> +#define EDID1_CVT_VerticalRate75HzMask      0x1
> +#define EDID1_CVT_VerticalRate60HzOff       3
> +#define EDID1_CVT_VerticalRate60HzMask      0x1
> +#define EDID1_CVT_VerticalRate50HzOff       4
> +#define EDID1_CVT_VerticalRate50HzMask      0x1
> +#define EDID1_CVT_PreferredVerticalRateOff  5
> +#define EDID1_CVT_PreferredVerticalRateMask 0x3
> +#define EDID_CVT_AspectRatio_4_3            0
> +#define EDID_CVT_AspectRatio_16_9           1
> +#define EDID_CVT_AspectRatio_16_10          2
> +#define EDID_CVT_AspectRatio_15_9           3
> +#define EDID_CVT_PrefVertRate50Hz           0
> +#define EDID_CVT_PrefVertRate60Hz           1
> +#define EDID_CVT_PrefVertRate75Hz           2
> +#define EDID_CVT_PrefVertRate85Hz           3
> +struct CVT3ByteCodeDescriptor {
> +    uint8_t AddressableLinesLow;
> +    uint8_t AspectRatio_AddressableLinesHigh;
> +    uint8_t VerticalRate_PreferredVerticalRate;
> +struct CVTTimingCodes3B {
> +    uint8_t VersionNumber;
> +    struct CVT3ByteCodeDescriptor cvt[4];
> +EDID_INLINE_ROUTINE uint16_t edid1_CVT_AddressableLinesHigh (
> +    struct CVT3ByteCodeDescriptor *cvt)
> +    return (cvt->AddressableLinesLow |
> +        (cvt->VerticalRate_PreferredVerticalRate &
> +         (EDID1_CVT_AddressableLinesHighMask<<EDID1_CVT_AddressableLinesHighOff)
> +        ) << (8-EDID1_CVT_AddressableLinesHighOff) );
> +EDID_INLINE_ROUTINE uint8_t edid1_CVT_AspectRatio (
> +    return (cvt->AspectRatio_AddressableLinesHigh >> EDID1_CVT_AspectRatioOff) &
> +        EDID1_CVT_AspectRatioMask;
> +#define EDID_DTT_EstablishedTimingsIII      0xF7
> +struct EstablishedTimingsIII {
> +    uint8_t RevisionNumber;
> +    uint8_t EST_III[12];
> +enum EST_III {
> +    EST_1152x864_75Hz   = 0,
> +    EST_1024x768_85Hz   = 1,
> +    EST_800x600_85Hz    = 2,
> +    EST_848x480_60Hz    = 3,
> +    EST_640x480_85Hz    = 4,
> +    EST_720x400_85Hz    = 5,
> +    EST_640x400_85Hz    = 6,
> +    EST_640x350_85Hz    = 7,
> +    EST_1280x1024_85Hz  = 8,
> +    EST_1280x1024_60Hz  = 9,
> +    EST_1280x960_85Hz   = 10,
> +    EST_1280x960_60Hz   = 11,
> +    EST_1280x768_85Hz   = 12,
> +    EST_1280x768_75Hz   = 13,
> +    EST_1280x768_60Hz   = 14,
> +    EST_1280x768_60HzRB = 15,
> +    EST_1400x1050_75Hz  = 16,
> +    EST_1400x1050_60Hz  = 17,
> +    EST_1400x1050_60HzRB= 18,
> +    EST_1400x900_85Hz   = 19,
> +    EST_1400x900_75Hz   = 20,
> +    EST_1400x900_60Hz   = 21,
> +    EST_1400x900_60HzRB = 22,
> +    EST_1360x768_60Hz   = 23,
> +    EST_1600x1200_70Hz  = 24,
> +    EST_1600x1200_65Hz  = 25,
> +    EST_1600x1200_60Hz  = 26,
> +    EST_1680x1050_85Hz  = 27,
> +    EST_1680x1050_75Hz  = 28,
> +    EST_1680x1050_60Hz  = 29,
> +    EST_1680x1050_60HzRB= 30,
> +    EST_1400x1050_85Hz  = 31,
> +    EST_1920x1200_60Hz  = 32,
> +    EST_1920x1200_60HzRB= 33,
> +    EST_1856x1392_75Hz  = 34,
> +    EST_1856x1392_60Hz  = 35,
> +    EST_1792x1344_75Hz  = 36,
> +    EST_1792x1344_60Hz  = 37,
> +    EST_1600x1200_85Hz  = 38,
> +    EST_1600x1200_75Hz  = 39,
> +    EST_1920x1440_75Hz  = 44,
> +    EST_1920x1440_60Hz  = 45,
> +    EST_1920x1200_85Hz  = 46,
> +    EST_1920x1200_75Hz  = 47,
> +#define EDID_DTT_DescriptorSpaceUnused      0x10
> +/* DTT 0x0 - 0xF are manufacturer specific */
> +struct MonitorDescriptor {
> +    uint8_t Flag0[2];
> +    uint8_t Flag1;
> +    uint8_t DataTypeTag;
> +    uint8_t Flag2;
> +    uint8_t DescriptorData[13];
> +union DTD_MD {
> +    struct DetailedTimingDescriptor dtd;
> +    struct MonitorDescriptor md;
> +#define EDID1_STI_ImageAspectRatioOff           0
> +#define EDID1_STI_ImageAspectRatioMask          0x3
> +#define EDID1_STI_RefreshRateOff                2
> +#define EDID1_STI_RefreshRateMask               0x3F
> +#define EDID_STI_DescriptorUnused           0x0101
> +#define EDID_STI_AspectRatio_16_10          0
> +#define EDID_STI_AspectRatio_4_3            1
> +#define EDID_STI_AspectRatio_5_4            2
> +#define EDID_STI_AspectRatio_16_9           3
> +struct StandardTimingIdentification {
> +    uint8_t HorizontalActivePixels;
> +    uint8_t ImageAspectRatio_RefreshRate;
> +/* Video Input Definition */
> +#define EDID1_VID_DigitalSignalLevelOff         7
> +#define EDID1_VID_DigitalSignalLevelMask        0x1
> +/* for EDID1_VID_DigitalSignalLevelOff = 1 (Digital) */
> +#define EDID1_VID_ColorBitDepthOff              4
> +#define EDID1_VID_ColorBitDepthMask             0x7 /* see CBD */
> +#define EDID1_VID_DigitalVideoStandardSuppOff   0
> +#define EDID1_VID_DigitalVideoStandardSuppMask  0xF /* see DVS */
> +/* for EDID1_VID_DigitalSignalLevelOff = 0 (Analog) */
> +#define EDID1_VID_SignalLevelStandardOff        5
> +#define EDID1_VID_SignalLevelStandardMask       0x3
> +#define EDID1_VID_VideoSetupBlankOff            4
> +#define EDID1_VID_VideoSetupBlankMask           0x1
> +#define EDID1_VID_SeparateSyncHandVSignalsOff   3
> +#define EDID1_VID_SeparateSyncHandVSignalsMask  0x1
> +#define EDID1_VID_SyncSignalOnHorizontalOff     2
> +#define EDID1_VID_SyncSignalOnHorizontalMask    0x1
> +#define EDID1_VID_SyncSignalOnGreenOff          1
> +#define EDID1_VID_SyncSignalOnGreenMask         0x1
> +#define EDID1_VID_SerationOnVerticalSyncOff     0
> +#define EDID1_VID_SerationOnVerticalSyncMask    0x1
> +/* Analog Interface Data Format - Signal Level Standard */
> +#define EDID_SLS_0700_0300_1000Vpp             0x0
> +#define EDID_SLS_0714_0286_1000Vpp             0x1
> +#define EDID_SLS_1000_0400_1400Vpp             0x2
> +#define EDID_SLS_0700_0000_0700Vpp             0x3
> +/* Color Bit Depths */
> +#define CBD_undef               0x0
> +#define CBD_6bPerPrimaryColor   0x1
> +#define CBD_8bPerPrimaryColor   0x2
> +#define CBD_10bPerPrimaryColor  0x3
> +#define CBD_12bPerPrimaryColor  0x4
> +#define CBD_14bPerPrimaryColor  0x5
> +#define CBD_16bPerPrimaryColor  0x6
> +#define CBD_reserved            0x7
> +/* Digital Video Standard Supported */
> +#define DVS_undef               0x0
> +#define DVS_DVI                 0x1
> +#define DVS_HDMI-a              0x2
> +#define DVS_HDMI-b              0x3
> +#define DVS_MDDI                0x4
> +#define DVS_DiplayPort          0x5
> +/* Feature Support */
> +#define EDID1_Feature_GTFSupported_mask              0x1
> +#define EDID1_Feature_GTFSupported_off               0
> +#define EDID1_Feature_PreferredTimingMode_mask       0x1
> +#define EDID1_Feature_PreferredTimingMode_off        1
> +#define EDID1_Feature_StandardDefaultColorSpace_mask 0x1
> +#define EDID1_Feature_StandardDefaultColorSpace_off  2
> +#define EDID1_Feature_DisplayType_mask               0x2
> +#define EDID1_Feature_DisplayType_off                3
> +        /* Refer to VESA DPMS Specification */
> +#define EDID1_Feature_ActiveOff_mask                 0x1
> +#define EDID1_Feature_ActiveOff_off                  5
> +#define EDID1_Feature_Suspend_mask                   0x1
> +#define EDID1_Feature_Suspend_off                    6
> +#define EDID1_Feature_StandBy_mask                   0x1
> +#define EDID1_Feature_StandBy_off                    7
> +    /* analog - Display Color Type */
> +#define EDID_DisplayType_Monochrome                 0
> +#define EDID_DisplayType_RGBcolor                   1
> +#define EDID_DisplayType_nonRGBcolor                2
> +#define EDID_DisplayType_undef                      3
> +    /* digital - Supported Color Encoding Formats */
> +#define EDID_DisplayType_RGB444                     0
> +#define EDID_DisplayType_RGB444YCrCb444             1
> +#define EDID_DisplayType_RGB444YCrCb422             2
> +#define EDID_DisplayType_RGB444YCrCb444YCrCb422     3
> +struct edid1 {
> +    uint8_t Header[8];
> +/*  Vendor Product Identification */
> +    uint8_t IDManufacturerName[2];
> +    uint8_t IDProductCode[2];
> +    uint8_t IDSerialNumber[4];
> +    uint8_t WeekofManufacture;
> +    uint8_t YearofManufacture;
> +/*  EDID Structure Version Revision Level */
> +    uint8_t Version;
> +    uint8_t Revision;
> +/*  Basic Display Parameters Features */
> +    /* Video Input Definition */
> +    uint8_t VideoInputDefinition;
> +    uint8_t MaxHorizontalImageSize;
> +    uint8_t MaxVerticalImageSize;
> +    uint8_t DisplayTransferCharacteristic;
> +    /* Feature Support */
> +    uint8_t Features;
> +/*  Color Characteristics */
> +    uint8_t GreenRedLow;
> +    uint8_t WhiteBlueLow;
> +    uint8_t RedXHigh;
> +    uint8_t RedYHigh;
> +    uint8_t GreenXHigh;
> +    uint8_t GreenYHigh;
> +    uint8_t BlueXHigh;
> +    uint8_t BlueYHigh;
> +    uint8_t WhiteXHigh;
> +    uint8_t WhiteYHigh;
> +/*  Established Timings I, II, Manufacturer's */
> +    uint8_t EST_I_II_Man[3];
> +    struct StandardTimingIdentification STI[8];
> +/*  Detailed Timing Descriptions / Monitor Descriptions */
> +    union DTD_MD dtd_md[4];
> +    uint8_t ExtensionFlag;
> +    uint8_t Checksum;
> +EDID_INLINE_ROUTINE uint16_t edid1_RedX (struct edid1 *edid) {
> +    return (edid->RedXHigh<<2) | (edid->GreenRedLow>>6);
> +EDID_INLINE_ROUTINE uint16_t edid1_RedY (struct edid1 *edid) {
> +    return (edid->RedYHigh<<2) | (edid->GreenRedLow>>4)&&0x3;
> +EDID_INLINE_ROUTINE uint16_t edid1_GreenX (struct edid1 *edid) {
> +    return (edid->GreenXHigh<<2) | (edid->GreenRedLow>>2)&&0x3;
> +EDID_INLINE_ROUTINE uint16_t edid1_GreenY (struct edid1 *edid) {
> +    return (edid->GreenYHigh<<2) | (edid->GreenRedLow&0x3);
> +EDID_INLINE_ROUTINE uint16_t edid1_BlueX (struct edid1 *edid) {
> +    return (edid->BlueXHigh<<2)  | (edid->WhiteBlueLow>>6);
> +EDID_INLINE_ROUTINE uint16_t edid1_BlueY (struct edid1 *edid) {
> +    return (edid->BlueYHigh<<2)  | (edid->WhiteBlueLow>>4)&&0x3;
> +EDID_INLINE_ROUTINE uint16_t edid1_WhiteX (struct edid1 *edid) {
> +    return (edid->WhiteXHigh<<2) | (edid->WhiteBlueLow>>2)&&0x3;
> +EDID_INLINE_ROUTINE uint16_t edid1_WhiteY (struct edid1 *edid) {
> +    return (edid->WhiteYHigh<<2) | (edid->WhiteBlueLow&0x3);
> +enum edid1_EstablishedTimings {
> +/*  Established Timings I */
> +    EST_800x600_60Hz    = 0,
> +    EST_800x600_56Hz    = 1,
> +    EST_640x480_75Hz    = 2,
> +    EST_640x480_72Hz    = 3,
> +    EST_640x480_67Hz    = 4,
> +    EST_640x480_60Hz    = 5,
> +    EST_720x400_88Hz    = 6,
> +    EST_720x400_70Hz    = 7,
> +/*  Established Timings II */
> +    EST_1280x1024_75Hz  = 8,
> +    EST_1024x768_75Hz   = 9,
> +    EST_1024x768_70Hz   = 10,
> +    EST_1024x768_60Hz   = 11,
> +    EST_1024x768_87Hz   = 12,
> +    EST_832x624_75Hz    = 13,
> +    EST_800x600_75Hz    = 14,
> +    EST_800x600_72Hz    = 15,
> +/*  Manufacturer's Timings */
> +    EST_1152x870_75Hz   = 23,
> +EDID_INLINE_ROUTINE uint8_t edid1_EstablishedTim (
> +    struct edid1 *edid,
> +    enum edid1_EstablishedTimings est)
> +    return (uint8_t)(edid->EST_I_II_Man[est/8] & (est%8));
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* _VBE_H */
> diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> index 0000000..2bf1b59
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
> @@ -0,0 +1,463 @@
> + * @file vbe3.h
> + * @brief VESA Bios Extension definitions.
> + * vbe3.h  - This file contains definitions for constants related to VBE.
Again.
> + *                     CTU in Prague.
> +#ifndef _VBE_H
> +#define _VBE_H
> +#ifdef __cplusplus
> +extern "C" {
> +#define VBE3_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
> +/*  VESA BIOS EXTENSION (VBE) Core functions Standard
> +    Version: 3.0 Date: September 16, 1998               */
> +/* VBE RETURN STATUS */
> +/* AL == 4Fh: Function is supported */
> +/* AL != 4Fh: Function is not supported */
> +#define VBE_functionSupported        0x4F
> +/* AH == 00h: Function call successful */
> +#define VBE_callSuccessful           0x00
> +/* AH == 01h: Function call failed */
> +#define VBE_callFailed               0x01
> +/* AH == 02h: Function is not supported in the current hardware configuration */
> +#define VBE_notSupportedInCurHWConf  0x02
> +/* AH == 03h: Function call invalid in current video mode */
> +#define VBE_callInvalid              0x03
> +/* VBE Mode Numbers */
> +/* D0-D8 =  Mode number */
> +#define VBE_modeNumberMask         0x01FF
> +#define VBE_modeNumberShift          0x00
> +/* If D8 == 0, this is not a VESA defined VBE mode */
> +#define VBE_VESAmodeMask           0x0100
> +/* If D8 == 1, this is a VESA defined VBE mode */
> +/* D9-D12 =  Reserved by VESA for future expansion (= 0) */
> +#define VBE_VESAmodeShift            0x08
> +/* If D11 == 0, Use current BIOS default refresh rate */
> +#define VBE_refreshRateCtrlMask    0x0800
> +/* If D11 == 1, Use user specified CRTC values for refresh rate */
> +/* D12-13 = Reserved for VBE/AF (must be 0) */
> +#define VBE_refreshRateCtrlShift     0x0B
> +/* If D14 == 0, Use Banked/Windowed Frame Buffer */
> +#define VBE_linearFlatFrameBufMask 0x4000
> +/* If D14 == 1, Use Linear/Flat Frame Buffer */
> +#define VBE_linearFlatFrameBufShift  0x0E
> +/* If D15 == 0, Clear display memory */
> +#define VBE_preserveDispMemMask    0x8000
> +/* If D15 == 1, Preserve display memory */
> +#define VBE_preserveDispMemShift     0x0F
> +/* Graphics modes */
> +/* 15-bit mode, Resolution: 640x400,   Colors: 256  */
> +#define VBE_R640x400C256      0x100
> +/* 15-bit mode, Resolution: 640x480,   Colors: 256  */
> +#define VBE_R640x480C256      0x101
> +/* 15-bit mode, Resolution: 800x600,   Colors: 16   */
> +#define VBE_R800x600C16       0x102
> +/* 7-bit mode,  Resolution: 800x600,   Colors: 16   */
> +#define VBE_b7R800x600C16     0x6A
> +/* 15-bit mode, Resolution: 800x600,   Colors: 256  */
> +#define VBE_R800x600C256      0x103
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 16   */
> +#define VBE_R1024x768C16      0x104
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 256  */
> +#define VBE_R1024x768C256     0x105
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 16   */
> +#define VBE_R1280x1024C16     0x106
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 256  */
> +#define VBE_R1280x1024C256    0x107
> +/* 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R320x200C32K      0x10D
> +/* 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
> +#define VBE_R320x200C64K      0x10E
> +/* 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R320x200C17M      0x10F
> +/* 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R640x480C32K      0x110
> +/* 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
> +#define VBE_R640x480C64K      0x111
> +/* 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R640x480C17M      0x112
> +/* 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
> +#define VBE_R800x600C32K      0x113
> +/* 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
> +#define VBE_R800x600C64K      0x114
> +/* 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
> +#define VBE_R800x600C17M      0x115
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
> +#define VBE_R1024x768C32K     0x116
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
> +#define VBE_R1024x768C64K     0x117
> +/* 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
> +#define VBE_R1024x768C17M     0x118
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
> +#define VBE_R1280x1024C32K    0x119
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
> +#define VBE_R1280x1024C64K    0x11A
> +/* 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
> +#define VBE_R1280x1024C17M    0x11B
> +#define VBE_SpecialMode       0x81FF
> +/* Text modes */
> +#define VBE_C80R60            0x108   /* 15-bit mode, Columns: 80,  Rows: 60 */
> +#define VBE_C132R25           0x109   /* 15-bit mode, Columns: 132, Rows: 25 */
> +#define VBE_C132R43           0x10A   /* 15-bit mode, Columns: 132, Rows: 43 */
> +#define VBE_C132R50           0x10B   /* 15-bit mode, Columns: 132, Rows: 50 */
> +#define VBE_C132R60           0x10C   /* 15-bit mode, Columns: 132, Rows: 60 */
> +/* VBE function numbers - passed in AX register */
> +#define VBE_RetVBEConInf       0x4F00 /* Return VBE Controller Information */
> +#define VBE_RetVBEModInf       0x4F01 /* Return VBE Mode Information */
> +#define VBE_SetVBEMod          0x4F02 /* Set VBE Mode */
> +#define VBE_RetCurVBEMod       0x4F03 /* Return Current VBE Mode */
> +#define VBE_SavResSta          0x4F04 /* Save/Restore State */
> +#define VBE_DisWinCon          0x4F05 /* Display Window Control */
> +#define VBE_SetGetLogScaLinLen 0x4F06 /* Set/Get Logical Scan Line Length */
> +#define VBE_SetGetDisSta       0x4F07 /* Set/Get Display Start */
> +#define VBE_SetGetDACPalFor    0x4F08 /* Set/Get DAC Palette Format */
> +#define VBE_SetGetPalDat       0x4F09 /* Set/Get Palette Data */
> +#define VBE_RetVBEProModInt    0x4F0A /* Return VBE Protected Mode Interface */
> +#define VBE_GetSetpixclo       0x4F0B /* Get/Set pixel clock */
> +#define VBE_PowManExt          0x4F10 /* Power Management Extensions (PM) */
> +#define VBE_FlaPanIntExt       0x4F11 /* Flat Panel Interface Extensions (FP) */
> +#define VBE_AudIntExt          0x4F13 /* Audio Interface Extensions (AI) */
> +#define VBE_OEMExt             0x4F14 /* OEM Extensions */
> +#define VBE_DisDatCha          0x4F15 /* Display Data Channel (DDC),
> +                                         Serial Control Interface (SCI) */
> +/* VBE subfunction numbers - passed in BL register */
> +#define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
> +                                        Specification Information */
> +/* *** Structures *** */
> +struct VBE_FarPtr {
> +    uint16_t offset;
> +    uint16_t selector;
> +} VBE3_PACKED_ATTRIBUTE;
> +struct VBE_PMInfoBlock {
> +    uint8_t   Signature[4];    /*  PM Info Block Signature */
> +    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
> +    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
> +    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
> +    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
> +    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
> +    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
> +    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
> +    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
> +    uint8_t   Checksum;        /*  Checksum byte for structure */
> +/* General VBE signature */
> +#define VBE_SIGNATURE "VESA"
> +/* Signature for VBE 2.0 and higher */
> +#define VBE20plus_SIGNATURE "VBE2"
> +/* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
> +#define VBE_END_OF_VideoModeList 0xFFFF
> +#define VBE_STUB_VideoModeList 0xFFFF
> +struct VBE_VbeInfoBlock {
> +    uint8_t   VbeSignature[4];   /*  VBE Signature */
> +    uint16_t  VbeVersion;        /*  VBE Version */
> +    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
> +    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
> +    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
> +    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
> +    /*  Added for VBE 2.0+ */
> +    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
> +    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
> +    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
> +    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
> +    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
> +    /*    area */
> +    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
> +struct VBE_ModeInfoBlock {
> +    /*  Mandatory information for all VBE revisions */
> +    uint16_t  ModeAttributes;        /* mode attributes */
> +    uint8_t   WinAAttributes;        /* window A attributes */
> +    uint8_t   WinBAttributes;        /* window B attributes */
> +    uint16_t  WinGranularity;        /* window granularity */
> +    uint16_t  WinSize;               /* window size */
> +    uint16_t  WinASegment;           /* window A start segment */
> +    uint16_t  WinBSegment;           /* window B start segment */
> +    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
> +    uint16_t  BytesPerScanLine;      /* bytes per scan line */
> +    /*  Mandatory information for VBE 1.2 and above */
> +    uint16_t  XResolution;           /* horizontal resolution in px or chars */
> +    uint16_t  YResolution;           /* vertical resolution in px or chars */
> +    uint8_t   XCharSize;             /* character cell width in pixels */
> +    uint8_t   YCharSize;             /* character cell height in pixels */
> +    uint8_t   NumberOfPlanes;        /* number of memory planes */
> +    uint8_t   BitsPerPixel;          /* bits per pixel */
> +    uint8_t   NumberOfBanks;         /* number of banks */
> +    uint8_t   MemoryModel;           /* memory model type */
> +    uint8_t   BankSize;              /* bank size in KB */
> +    uint8_t   NumberOfImagePages;    /* number of images */
> +    uint8_t   Reserved0;             /* reserved for page function */
> +    /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
> +    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
> +    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
> +    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
> +    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
> +    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
> +    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
> +    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
> +    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
> +    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
> +    /*  Mandatory information for VBE 2.0 and above */
> +    uint32_t *PhysBasePtr;           /* physical address for
> +                                        flat memory frame buffer */
> +    uint32_t  Reserved1;             /* Reserved - always set to 0 */
> +    uint16_t  Reserved2;             /* Reserved - always set to 0 */
> +    /*  Mandatory information for VBE 3.0 and above */
> +    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
> +    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
> +    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
> +        /* linear modes */
> +    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
> +    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
> +    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
> +    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
> +    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
> +    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
> +    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
> +    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
> +    uint32_t  MaxPixelClock;         /* maximum pixel clock
> +                                        (in Hz) for graphics mode */
> +    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
> +struct VBE_CRTCInfoBlock {
> +    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
> +    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
> +    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
> +    uint16_t  VerticalTotal;         /* Vertical total in lines */
> +    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
> +    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
> +    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
> +    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
> +    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
> +    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
> +struct VBE_PaletteEntry {
> +    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
> +    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
> +    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
> +    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
> +struct VBE_SupVbeInfoBlock {
> +    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
> +    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
> +    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
> +    uint16_t  OemSoftwareRev;        /* OEM Software revision */
> +    uint8_t   Reserved[221];         /* Reserved for description
> +                                        strings and future */
> +    /*  expansion */
> +/* VbeInfoBlock Capabilities */
> +/*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
> +/*     = 1 DAC width is switchable to 8 bits per primary color */
> +#define VBE_DACswitchableMask     0x0001
> +/*  D1 = 0 Controller is VGA compatible */
> +/*     = 1 Controller is not VGA compatible */
> +#define VBE_notVGAcompatibleMask  0x0002
> +/*  D2 = 0 Normal RAMDAC operation */
> +/*     = 1 When programming large blocks of information to the RAMDAC,
> +            use the blank bit in Function 09h. */
> +#define VBE_specialRAMDACopMask   0x0004
> +/*  D3 = 0 No hardware stereoscopic signaling support */
> +/*     = 1 Hardware stereoscopic signaling supported by controller */
> +#define VBE_hwStereoscopicMask    0x0008
> +/*  D4 = 0 Stereo signaling supported via external VESA stereo connector */
> +/*     = 1 Stereo signaling supported via VESA EVC connector */
> +#define VBE_supportEVCconnMask    0x0010
> +/*  D5-31 = Reserved */
> +/* ModeInfoBlock ModeAttributes */
> +/*  D0 =  Mode supported by hardware configuration */
> +/*   0 =  Mode not supported in hardware */
> +/*   1 =  Mode supported in hardware */
> +#define VBE_modSupInHWMask        0x0001
> +/*  D1 =  1 (Reserved) */
> +/*  D2 =  TTY Output functions supported by BIOS */
> +/*   0 =  TTY Output functions not supported by BIOS */
> +/*   1 =  TTY Output functions supported by BIOS */
> +#define VBE_TTYOutSupByBIOSMask   0x0004
> +/*  D3 =  Monochrome/color mode (see note below) */
> +/*   0 =  Monochrome mode */
> +/*   1 =  Color mode */
> +#define VBE_ColorModeMask         0x0008
> +/*  D4 =  Mode type */
> +/*   0 =  Text mode */
> +/*   1 =  Graphics mode */
> +#define VBE_GraphicsModeMask      0x0010
> +/*  D5 =  VGA compatible mode */
> +/*   0 =  Yes */
> +/*   1 =  No */
> +#define VBE_VGACompModeMask       0x0020
> +/*  D6 =  VGA compatible windowed memory mode is available */
> +/*   0 =  Yes */
> +/*   1 =  No */
> +#define VBE_VGACompWinMemModeMask 0x0040
> +/*  D7 =  Linear frame buffer mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_LinFraBufModeAvaiMask 0x0080
> +/*  D8 =  Double scan mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_DblScnModeAvaiMask    0x0100
> +/*  D9 =  Interlaced mode is available */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_InterlModeAvaiMask    0x0200
> +/*  D10 =  Hardware triple buffering support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_HWTripBufSupMask      0x0400
> +/*  D11 =  Hardware stereoscopic display support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_HWSterDispSupMask     0x0800
> +/*  D12 =  Dual display start address support */
> +/*   0 =  No */
> +/*   1 =  Yes */
> +#define VBE_DualDispStAdrSupMask  0x1000
> +/*  D13-D15 =  Reserved */
> +/* ModeInfoBlock WinXAttributes */
> +/*  D0 =  Relocatable window(s) supported */
> +/*   0 =  Single non-relocatable window only */
> +/*   1 =  Relocatable window(s) are supported */
> +#define VBE_RelocWinSupMask       0x01
> +/*  D1 =  Window readable */
> +/*   0 =  Window is not readable */
> +/*   1 =  Window is readable */
> +#define VBE_WinReadableMask       0x02
> +/*  D2 =  Window writeable */
> +/*   0 =  Window is not writeable */
> +/*   1 =  Window is writeable */
> +#define VBE_WinWritableMask       0x04
> +/*  D3-D7 =  Reserved */
> +/* ModeInfoBlock MemoryModel */
> +#define VBE_TextMode              0x00
> +#define VBE_CGAGraphics           0x01
> +#define VBE_HerculesGraphics      0x02
> +#define VBE_Planar                0x03
> +#define VBE_PackedPixel           0x04
> +#define VBE_NonChain4Color256     0x05
> +#define VBE_DirectColor           0x06
> +#define VBE_YUV                   0x07
> +    /* 0x08-0x0F Reserved, to be defined by VESA */
> +    /* 0x10-0xFF To be defined by OEM */
> +/* ModeInfoBlock DirectColorModeInfo */
> +/*  D0 =  Color ramp is fixed/programmable */
> +/*   0 =  Color ramp is fixed */
> +/*   1 =  Color ramp is programmable */
> +#define VBE_ColRampProgMask       0x01
> +/*  D1 =  Bits in Rsvd field are usable/reserved */
> +/*   0 =  Bits in Rsvd field are reserved */
> +/*   1 =  Bits in Rsvd field are usable by the application */
> +#define VBE_RsvdBitsUsableMask    0x02
> +/* CRTCInfoBlock Flags */
> +/*  D0 =  Double Scan Mode Enable */
> +/*   0 =  Graphics mode is not double scanned */
> +/*   1 =  Graphics mode is double scanned */
> +#define VBE_GrModeDblScanMask     0x01
> +/*  D1 =  Interlaced Mode Enable */
> +/*   0 =  Graphics mode is non-interlaced */
> +/*   1 =  Graphics mode is interlaced */
> +#define VBE_GrModeInterlMask      0x02
> +/*  D2 =  Horizontal sync polarity */
> +/*   0 =  Horizontal sync polarity is positive (+) */
> +/*   1 =  Horizontal sync polarity is negative (-) */
> +#define VBE_HorSncPolNegMask      0x04
> +/*  D3 =  Vertical sync polarity */
> +/*   0 =  Vertical sync polarity is positive (+) */
> +/*   1 =  Vertical sync polarity is negative (-) */
> +#define VBE_VerSncPolNegMask      0x08
> +/*  VESA BIOS Extensions/Display Data Channel Standard
> +    Version: 1.1 November 18, 1999                      */
> +/* VBE/DDC subfunction numbers - passed in BL register */
> +#define VBEDDC_Capabilities    0x0   /* Report VBE/DDC Capabilities */
> +#define VBEDDC_ReadEDID        0x1   /* Read EDID */
> +/* DDC Capabilities */
> +/* DDC level supported - returned in BL register */
> +/* 0 - DDC1 not supported; 1 - DDC1 supported */
> +#define VBEDDC_1SupportedMask  0x1
> +/* 0 - DDC2 not supported; 1 - DDC2 supported */
> +#define VBEDDC_2SupportedMask  0x2
> +/* 0 - Screen not blanked during data transfer;
> +   1 - Screen blanked during data transfer */
> +#define VBEDDC_scrBlnkDatTrMs  0x4
> +/*  VESA BIOS Extensions/Serial Control Interface Standard
> +    Version: 1.0 Revision: 2 Date: July 2, 1997         */
> +/* VBE/SCI subfunction numbers - passed in BL register */
> +#define VBESCI_ReportCapabil   0x10  /* Report VBE/SCI Capabilities */
> +#define VBESCI_BegSCLSDACtrl   0x11  /* Begin SCL/SDA control */
> +#define VBESCI_EndSCLSDACtrl   0x12  /* End SCL/SDA control */
> +#define VBESCI_WrtSCLClkLine   0x13  /* Write SCL clock line */
> +#define VBESCI_WrtSDADatLine   0x14  /* Write SDA data line */
> +#define VBESCI_RdySCLClkLine   0x15  /* Read SCL clock line */
> +#define VBESCI_RdySDADatLine   0x16  /* Read SDA data line */
> +/* SCI Capabilities */
> +/* I2C level supported - returned in BL register */
> +#define VBESCI_capSCLwrtMask   0x1   /* Can write to SCL clock line */
> +#define VBESCI_capSDAwrtMask   0x2   /* Can write to SDA data line */
> +#define VBESCI_capSCLrdyMask   0x4   /* Can read from SCL clock line */
> +#define VBESCI_capSDArdyMask   0x8   /* Can read from SDA data line */
> +#ifdef __cplusplus
> +#endif /* ASM */
> diff --git a/c/src/lib/libbsp/i386/pc386/preinstall.am b/c/src/lib/libbsp/i386/pc386/preinstall.am
> index 4314f22..b4ac86b 100644
> --- a/c/src/lib/libbsp/i386/pc386/preinstall.am
> +++ b/c/src/lib/libbsp/i386/pc386/preinstall.am
> @@ -147,6 +147,14 @@ $(PROJECT_INCLUDE)/i386_io.h: ../../i386/shared/comm/i386_io.h $(PROJECT_INCLUDE
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i386_io.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/i386_io.h
> +$(PROJECT_INCLUDE)/bsp/vbe3.h: include/vbe3.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vbe3.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vbe3.h
> +$(PROJECT_INCLUDE)/edid.h: include/edid.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/edid.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/edid.h
>  $(PROJECT_INCLUDE)/pcibios.h: ../../i386/shared/pci/pcibios.h $(PROJECT_INCLUDE)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pcibios.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/pcibios.h
> 1.9.1
> devel mailing list
> devel at rtems.org
