Rehosting Update
Thu Nov 20 15:54:51 UTC 2014
Hi
https://devel.rtems.org/ is now up with our Trac instance.
As mentioned in a previous update, this merges Bugzilla and
Mediawiki. All the old content is there but it has likely moved
around. If you spot something broken or out of date, fix it
or report it.
Old bugzilla accounts have been migrated to Trac but the passwords
all need to be reset.  The accounts the account portion of an email
so for user at example.com, it would be "user". Mine is joel.sherrill
since I use joel.sherrill at oarcorp.com.
Passwords must be reset emails will go to the registered account email.
If anyone has problems, email amar at rtems.org.
