[PATCH 4/4] libtests/malloctest/init.c: Fix warning v2
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Nov 20 16:32:16 UTC 2014
Gedare.. does this look better?
posix_memalign() is prototyped to take a non-NULL parameter. But our
test is deliberately passing one in. With the -Wnon-null warning flag
enabled, we will always get warnings on this test unless we disable
that warning for this single test case.
testsuites/libtests/malloctest/init.c | 24 ++++++++++--------------
testsuites/support/include/tmacros.h | 32 +++++++++++++++++++++++++++-----
2 files changed, 37 insertions(+), 19 deletions(-)
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index 0d95e3b..399cdd5 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -1,17 +1,5 @@
-/* Init
- * This routine is the initialization task for this test program.
- * It is a user initialization task and has the responsibility for creating
- * and starting the tasks that make up the test. If the time of day
- * clock is required for the test, it should also be set to a known
- * value by this function.
- * Input parameters:
- * argument - task argument
- * Output parameters: NONE
- * COPYRIGHT (c) 1989-2011.
+ * COPYRIGHT (c) 1989-2011, 2014.
* On-Line Applications Research Corporation (OAR).
* Copyright (c) 2009, 2010 embedded brains GmbH.
@@ -1188,9 +1176,17 @@ static void test_posix_memalign(void)
int sc;
int maximumShift;
+ * posix_memalign() is declared as never having a NULL first parameter.
+ * We need to explicitly disable this compiler warning to make this code
+ * warning free.
+ COMPILER_DIAGNOSTIC_SETTINGS_PUSH
+ COMPILER_DIAGNOSTIC_SETTINGS_DISABLE_NONNULL
puts( "posix_memalign - NULL return pointer -- EINVAL" );
sc = posix_memalign( NULL, 32, 8 );
fatal_posix_service_status( sc, EINVAL, "posix_memalign NULL pointer" );
+ COMPILER_DIAGNOSTIC_SETTINGS_POP
puts( "posix_memalign - alignment of 0 -- EINVAL" );
sc = posix_memalign( &p1, 0, 8 );
diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
index 91f23e0..4524cf9 100644
--- a/testsuites/support/include/tmacros.h
+++ b/testsuites/support/include/tmacros.h
@@ -1,9 +1,12 @@
-/* tmacros.h
+ * @file
- * This include file contains macros which are useful in the RTEMS
- * test suites.
- * COPYRIGHT (c) 1989-2009.
+ * This include file contains macros which are useful in the RTEMS
+ * test suites.
+ * COPYRIGHT (c) 1989-2014.
* The license and distribution terms for this file may be
@@ -297,6 +300,25 @@ extern "C" {
/* newlib's ino_t is a typedef to "unsigned long" */
#define PRIxino_t "lx"
+ * This assists in clearly disabling warnings on GCC in certain very
+ * specific cases.
+ * + -Wnon-null - If a method is declared as never having a NULL first
+ * parameter. We need to explicitly disable this compiler warning to make
+ * the code warning free.
+#ifdef __GNUC__
+ #define COMPILER_DIAGNOSTIC_SETTINGS_PUSH _Pragma("GCC diagnostic push")
+ #define COMPILER_DIAGNOSTIC_SETTINGS_POP _Pragma("GCC diagnostic pop")
+ #define COMPILER_DIAGNOSTIC_SETTINGS_DISABLE_NONNULL \
+ _Pragma("GCC diagnostic ignored \"-Wnonnull\"")
+#else
+#endif
#ifdef __cplusplus
#endif
1.9.3
