Rehosting Update
Thu Nov 20 17:20:09 UTC 2014
It should be working now.
On Thu, Nov 20, 2014 at 11:17 AM, Cláudio Silva
<claudiodcsilva at gmail.com> wrote:
> Hi,
> Password recovery is working correctly, but I can't access any patch
> attached to a ticket. This feature seems to be broken.
> Cláudio
> On Thu Nov 20 2014 at 15:54:58 Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> Hi
>> https://devel.rtems.org/ is now up with our Trac instance.
>> As mentioned in a previous update, this merges Bugzilla and
>> Mediawiki. All the old content is there but it has likely moved
>> around. If you spot something broken or out of date, fix it
>> or report it.
>> Old bugzilla accounts have been migrated to Trac but the passwords
>> all need to be reset.  The accounts the account portion of an email
>> so for user at example.com, it would be "user". Mine is joel.sherrill
>> since I use joel.sherrill at oarcorp.com.
>> Passwords must be reset emails will go to the registered account email.
>> If anyone has problems, email amar at rtems.org.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
