[PATCH 2/6] capture: Move print methods out of cli for reuse.
Jennifer Averett jennifer.averett at oarcorp.com
Thu Nov 20 21:05:20 UTC 2014
Methods to print the data were moved from capture-cli into
a support area and are no longer static so that they can
be shared by test routines, or application code that wants
to use the capture engine without the shell interface.
 cpukit/libmisc/Makefile.am               |   1 +
 cpukit/libmisc/capture/capture-cli.c     | 215 +---------------------
 cpukit/libmisc/capture/capture_support.c | 307 +++++++++++++++++++++++++++++++
 cpukit/libmisc/capture/captureimpl.h     |  58 ++++++
 4 files changed, 371 insertions(+), 210 deletions(-)
 create mode 100644 cpukit/libmisc/capture/capture_support.c
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 0cc9851..209b46d 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -19,6 +19,7 @@ EXTRA_DIST += capture/README
 noinst_LIBRARIES += libcapture.a
 libcapture_a_SOURCES = capture/capture.c capture/capture-cli.c \
     capture/capture_user_extension.c capture/capture_buffer.c \
+    capture/capture_support.c \
     capture/capture.h capture/captureimpl.h capture/capture-cli.h \
     capture/capture_buffer.h
diff --git a/cpukit/libmisc/capture/capture-cli.c b/cpukit/libmisc/capture/capture-cli.c
index ad53ccc..d790b85 100644
--- a/cpukit/libmisc/capture/capture-cli.c
+++ b/cpukit/libmisc/capture/capture-cli.c
@@ -5,7 +5,7 @@
   All rights reserved Objective Design Systems Pty Ltd, 2002
   Chris Johns (ccj at acm.org)
-  COPYRIGHT (c) 1989-1998.
+  COPYRIGHT (c) 1989-2014.
   On-Line Applications Research Corporation (OAR).
   The license and distribution terms for this file may be
@@ -34,6 +34,7 @@
 #include <rtems/capture-cli.h>
+#include <rtems/captureimpl.h>
 #include <rtems/monitor.h>
 #include <rtems/cpuuse.h>
@@ -209,31 +210,6 @@ rtems_capture_cli_disable (int                                argc RC_UNUSED,
   fprintf (stdout, "capture engine disabled.\n");
- * rtems_catpure_cli_print_uptime
- *  DESCRIPTION:
- * This function prints the nanosecond uptime to stdout.
-static void
-rtems_capture_cli_print_timestamp (uint64_t uptime)
-  uint32_t hours;
-  uint32_t minutes;
-  uint32_t seconds;
-  uint32_t nanosecs;
-  seconds  = uptime / 1000000000LLU;
-  minutes  = seconds / 60;
-  hours    = minutes / 60;
-  minutes  = minutes % 60;
-  seconds  = seconds % 60;
-  nanosecs = uptime % 1000000000;
-  fprintf (stdout, "%5lu:%02lu:%02lu.%09lu", hours, minutes, seconds, nanosecs);
 static void
 rtems_capture_cli_print_task (rtems_tcb *tcb)
@@ -273,47 +249,6 @@ rtems_capture_cli_print_task (rtems_tcb *tcb)
   fprintf (stdout, "\n");
-static void
-rtems_caputure_cli_print_record_std(rtems_capture_record_t* rec, uint64_t diff)
-  uint32_t                     event;
-  int                          e;
-  event = rec->events >> RTEMS_CAPTURE_EVENT_START;
-  for (e = RTEMS_CAPTURE_EVENT_START; e < RTEMS_CAPTURE_EVENT_END; e++)
-    if (event & 1)
-      rtems_capture_cli_print_timestamp (rec->time);
-      fprintf (stdout, " %9" PRId64 " ", diff);
-      rtems_monitor_dump_id (rec->task_id);
-      fprintf(stdout, "      %3" PRId32 " %3" PRId32 " %s\n",
-             (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
-             (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
-             rtems_capture_event_text (e));
-    event >>= 1;
-static void
-rtems_caputre_cli_print_record_task(rtems_capture_record_t* rec)
-  rtems_capture_task_record_t* task_rec = (rtems_capture_task_record_t*) rec;
-  fprintf (stdout, "           ");
-   fprintf (stdout, " %c%c%c%c",
-            (char) (task_rec->name >> 24) & 0xff,
-            (char) (task_rec->name >> 16) & 0xff,
-            (char) (task_rec->name >> 8) & 0xff,
-            (char) (task_rec->name >> 0) & 0xff);
-   fprintf (stdout, " %3" PRId32   " %3" PRId32 "\n",
-            task_rec->start_priority,
-            task_rec->stack_size);
  * rtems_capture_cli_count_tasks
@@ -355,7 +290,7 @@ rtems_capture_cli_task_list (int                                argc RC_UNUSED,
   rtems_iterate_over_all_threads (rtems_capture_cli_count_tasks);
   fprintf (stdout, "uptime: ");
-  rtems_capture_cli_print_timestamp (uptime);
+  rtems_capture_print_timestamp (uptime);
   fprintf (stdout, "\ntotal %i\n", rtems_capture_cli_task_count);
   rtems_iterate_over_all_threads (rtems_capture_cli_print_task);
@@ -375,79 +310,7 @@ rtems_capture_cli_watch_list (int                                argc RC_UNUSED,
                               const rtems_monitor_command_arg_t* command_arg RC_UNUSED,
                               bool                               verbose RC_UNUSED)
-  rtems_capture_control_t* control = rtems_capture_get_control_list ();
-  rtems_task_priority      ceiling = rtems_capture_watch_get_ceiling ();
-  rtems_task_priority      floor = rtems_capture_watch_get_floor ();
-  fprintf (stdout, "watch priority ceiling is %" PRId32 "\n", ceiling);
-  fprintf (stdout, "watch priority floor is %" PRId32 "\n", floor);
-  fprintf (stdout, "global watch is %s\n",
-          rtems_capture_watch_global_on () ? "enabled" : "disabled");
-  fprintf (stdout, "total %" PRId32 "\n", rtems_capture_control_count ());
-  while (control)
-    uint32_t flags;
-    int      f;
-    int      fshowed;
-    int      lf;
-    rtems_monitor_dump_id (rtems_capture_control_id (control));
-    rtems_monitor_dump_name (rtems_capture_control_name (control));
-    flags = rtems_capture_control_flags (control);
-    fprintf (stdout, " %c%c ",
-             rtems_capture_watch_global_on () ? 'g' : '-',
-             flags & RTEMS_CAPTURE_WATCH ? 'w' : '-');
-    flags = rtems_capture_control_to_triggers (control);
-    fprintf (stdout, " T:%c%c%c%c%c%c%c",
-             flags & RTEMS_CAPTURE_SWITCH    ? 'S' : '-',
-             flags & RTEMS_CAPTURE_CREATE ? 'C' : '-',
-             flags & RTEMS_CAPTURE_START ? 'S' : '-',
-             flags & RTEMS_CAPTURE_RESTART ? 'R' : '-',
-             flags & RTEMS_CAPTURE_DELETE ? 'D' : '-',
-             flags & RTEMS_CAPTURE_BEGIN ? 'B' : '-',
-             flags & RTEMS_CAPTURE_EXITTED ? 'E' : '-');
-    flags = rtems_capture_control_from_triggers (control);
-    fprintf (stdout, " F:%c%c%c%c%c",
-             flags & RTEMS_CAPTURE_DELETE  ? 'D' : '-');
-    for (f = 0, fshowed = 0, lf = 1; f < RTEMS_CAPTURE_TRIGGER_TASKS; f++)
-      if (rtems_capture_control_by_valid (control, f))
-        if (lf && ((fshowed % 3) == 0))
-          fprintf (stdout, "\n");
-          lf = 0;
-        fprintf (stdout, "  %2i:", f);
-        rtems_monitor_dump_name (rtems_capture_control_by_name (control, f));
-        fprintf (stdout, "/");
-        rtems_monitor_dump_id (rtems_capture_control_by_id (control, f));
-        flags = rtems_capture_control_by_triggers (control, f);
-        fprintf (stdout, ":%c%c%c%c%c",
-        fshowed++;
-        lf = 1;
-    if (lf)
-    control = rtems_capture_next_control (control);
+  rtems_capture_print_watch_list();
@@ -1154,16 +1017,9 @@ rtems_capture_cli_trace_records (int                                argc,
-  rtems_status_code       sc;
   bool                    csv = false;
   static int              dump_total = 22;
-  int                     total;
-  int                     count;
-  uint32_t                read;
-  rtems_capture_record_t* rec;
-  uint8_t*                ptr;
   int                     arg;
-  rtems_capture_time_t    last_t = 0;
   for (arg = 1; arg < argc; arg++)
@@ -1192,68 +1048,7 @@ rtems_capture_cli_trace_records (int                                argc,
-  total = dump_total;
-  while (total)
-    sc = rtems_capture_read (0, 0, &read, &rec);
-    if (sc != RTEMS_SUCCESSFUL)
-      fprintf (stdout, "error: trace read failed: %s\n", rtems_status_text (sc));
-      rtems_capture_flush (0);
-      return;
-     * If we have no records then just exist. We still need to release
-     * the reader lock.
-    if (read == 0)
-      rtems_capture_release (read);
-      break;
-    count = total < read ? total : read;
-    ptr = (uint8_t *) rec;
-    while (count--)
-      rec = (rtems_capture_record_t*) ptr;
-      if (csv)
-        fprintf (stdout, "%08" PRIu32 ",%03" PRIu32
-                   ",%03" PRIu32 ",%04" PRIx32 ",%" PRId64 "\n",
-                 rec->task_id,
-                 (rec->events >> RTEMS_CAPTURE_EVENT_START),
-                 (uint64_t) rec->time);
-      else {
-        if ((rec->events >> RTEMS_CAPTURE_EVENT_START) == 0)
-          rtems_caputre_cli_print_record_task( rec );
-        else {
-          uint64_t diff = 0;
-          if (last_t)
-            diff = rec->time - last_t;
-          last_t = rec->time;
-          rtems_caputure_cli_print_record_std( rec, diff );
-      ptr += rec->size;
-    if (count < total)
-      total -= count;
-    else
-      total = 0;
-    rtems_capture_release (count);
+  rtems_capture_print_trace_records( dump_total, csv );
diff --git a/cpukit/libmisc/capture/capture_support.c b/cpukit/libmisc/capture/capture_support.c
new file mode 100644
index 0000000..bdfd37b
--- /dev/null
+++ b/cpukit/libmisc/capture/capture_support.c
@@ -0,0 +1,307 @@
+  Copyright Objective Design Systems Pty Ltd, 2002
+  All rights reserved Objective Design Systems Pty Ltd, 2002
+  Chris Johns (ccj at acm.org)
+  On-Line Applications Research Corporation (OAR).
+  The license and distribution terms for this file may be
+  found in the file LICENSE in this distribution.
+  This software with is provided ``as is'' and with NO WARRANTY.
+  RTEMS Performance Monitoring and Measurement Framework.
+  This is a set of print support routines that may be shared between
+  the RTEMS monitor and direct callers of the capture engine.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <ctype.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <inttypes.h>
+#include <rtems.h>
+#include <rtems/monitor.h>
+ * Structure used during printing of the capture records.
+typedef struct {
+  rtems_capture_record_t* rec;
+  uint32_t                read;
+  uint32_t                last_t;
+  uint32_t                printed;
+} ctrace_per_cpu_t;
+ * rtems_catpure_print_uptime
+ *  DESCRIPTION:
+ * This function prints the nanosecond uptime to stdout.
+void
+rtems_capture_print_timestamp (uint64_t uptime)
+  uint32_t hours;
+  uint32_t minutes;
+  uint32_t seconds;
+  uint32_t nanosecs;
+  seconds  = uptime / 1000000000LLU;
+  minutes  = seconds / 60;
+  hours    = minutes / 60;
+  minutes  = minutes % 60;
+  seconds  = seconds % 60;
+  nanosecs = uptime % 1000000000;
+  fprintf (stdout, "%5lu:%02lu:%02lu.%09lu", hours, minutes, seconds, nanosecs);
+void
+rtems_capture_print_record_task( uint32_t cpu, rtems_capture_record_t* rec)
+  rtems_capture_task_record_t* task_rec = (rtems_capture_task_record_t*) rec;
+  fprintf(stdout,"%2" PRId32 " ", cpu);
+  rtems_capture_print_timestamp (rec->time);
+  fprintf (stdout, "            ");
+  rtems_monitor_dump_id (rec->task_id);
+  fprintf (stdout, " %c%c%c%c",
+           (char) (task_rec->name >> 24) & 0xff,
+           (char) (task_rec->name >> 16) & 0xff,
+           (char) (task_rec->name >> 8) & 0xff,
+           (char) (task_rec->name >> 0) & 0xff);
+  fprintf(stdout, " %3" PRId32 " %3" PRId32 " ",
+             (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
+             (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff );
+   fprintf (stdout, "%3" PRId32   " %3" PRId32 "  TASK_RECORD\n",
+            task_rec->start_priority,
+            task_rec->stack_size);
+void
+rtems_capture_print_record_capture(
+  uint32_t                cpu,
+  rtems_capture_record_t* rec,
+  uint64_t                diff
+  uint32_t                     event;
+  int                          e;
+  event = rec->events >> RTEMS_CAPTURE_EVENT_START;
+  for (e = RTEMS_CAPTURE_EVENT_START; e < RTEMS_CAPTURE_EVENT_END; e++)
+    if (event & 1)
+      fprintf (stdout, " %10" PRId64 " ", diff);
+      fprintf(stdout, "      %3" PRId32 " %3" PRId32 "           %s\n",
+             (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
+             rtems_capture_event_text (e));
+    event >>= 1;
+ *  rtems_capture_print_trace_records
+ *  DESCRIPTION:
+ * This function is a monitor command that dumps trace records.
+void
+rtems_capture_print_trace_records ( int total, bool csv )
+  rtems_status_code       sc;
+  int                     count;
+  ctrace_per_cpu_t*       per_cpu;
+  uint8_t*                ptr;
+  uint32_t                i;
+  uint32_t                cpu = 0;
+  rtems_capture_record_t* rec_out;
+  count = rtems_get_processor_count();
+  per_cpu = calloc( count, sizeof(*per_cpu) );
+  while (total)
+    /* Prime the per_cpu data */
+    for (i=0; i< count; i++) {
+      if ( per_cpu[i].read == 0 ) {
+        sc = rtems_capture_read (i, &per_cpu[i].read, &per_cpu[i].rec);
+        if (sc != RTEMS_SUCCESSFUL)
+          fprintf (stdout, "error: trace read failed: %s\n", rtems_status_text (sc));
+          rtems_capture_flush (0);
+          return;
+        /* Release the buffer if there are no records to read */
+        if (per_cpu[i].read == 0)
+          rtems_capture_release (i, 0);
+    /* Find the next record to print */
+    rec_out = NULL;
+      if ((rec_out == NULL) ||
+          ((per_cpu[i].read != 0) && (rec_out->time > per_cpu[i].rec->time))) {
+        rec_out = per_cpu[i].rec;
+        cpu = i;
+    /*  If we have read all the records abort. */
+    if (rec_out == NULL)
+      break;
+    /* Print the record */
+    if (csv)
+      fprintf (stdout, "%03" PRIu32 ",%08" PRIu32 ",%03" PRIu32
+                   ",%03" PRIu32 ",%04" PRIx32 ",%" PRId64 "\n",
+                 cpu, rec_out->task_id,
+                 (rec_out->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
+                 (rec_out->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
+                 (rec_out->events >> RTEMS_CAPTURE_EVENT_START),
+                 (uint64_t) rec_out->time);
+    else {
+      if ((rec_out->events >> RTEMS_CAPTURE_EVENT_START) == 0)
+          rtems_capture_print_record_task(cpu, rec_out );
+      else {
+        uint64_t diff = 0;
+        if (per_cpu[cpu].last_t)
+          diff = rec_out->time - per_cpu[cpu].last_t;
+        per_cpu[cpu].last_t = rec_out->time;
+        rtems_capture_print_record_capture( cpu, rec_out, diff );
+     * If we have not printed all the records read
+     * increment to the next record.  If we have
+     * printed all records release the records printed.
+    per_cpu[cpu].printed++;
+    if (per_cpu[cpu].printed != per_cpu[cpu].read) {
+      ptr =  (uint8_t *)per_cpu[cpu].rec;
+      ptr += per_cpu[cpu].rec->size;
+      per_cpu[cpu].rec = (rtems_capture_record_t *)ptr;
+    } else {
+      rtems_capture_release (cpu, per_cpu[cpu].printed);
+      per_cpu[cpu].read = 0;
+      per_cpu[cpu].printed = 0;
+    total --;
+  /* Finished so release all the records that were printed. */
+    if ( per_cpu[i].read != 0 )  {
+      rtems_capture_release( i, per_cpu[i].printed );
+  free( per_cpu );
+void
+rtems_capture_print_watch_list ()
+  rtems_capture_control_t* control = rtems_capture_get_control_list ();
+  rtems_task_priority      ceiling = rtems_capture_watch_get_ceiling ();
+  rtems_task_priority      floor = rtems_capture_watch_get_floor ();
+  fprintf (stdout, "watch priority ceiling is %" PRId32 "\n", ceiling);
+  fprintf (stdout, "watch priority floor is %" PRId32 "\n", floor);
+  fprintf (stdout, "global watch is %s\n",
+          rtems_capture_watch_global_on () ? "enabled" : "disabled");
+  fprintf (stdout, "total %" PRId32 "\n", rtems_capture_control_count ());
+  while (control)
+    uint32_t flags;
+    int      f;
+    int      fshowed;
+    int      lf;
+    rtems_monitor_dump_id (rtems_capture_control_id (control));
+    rtems_monitor_dump_name (rtems_capture_control_name (control));
+    flags = rtems_capture_control_flags (control);
+    fprintf (stdout, " %c%c ",
+             rtems_capture_watch_global_on () ? 'g' : '-',
+             flags & RTEMS_CAPTURE_WATCH ? 'w' : '-');
+    flags = rtems_capture_control_to_triggers (control);
+    fprintf (stdout, " T:%c%c%c%c%c%c%c",
+             flags & RTEMS_CAPTURE_SWITCH    ? 'S' : '-',
+             flags & RTEMS_CAPTURE_CREATE ? 'C' : '-',
+             flags & RTEMS_CAPTURE_START ? 'S' : '-',
+             flags & RTEMS_CAPTURE_RESTART ? 'R' : '-',
+             flags & RTEMS_CAPTURE_DELETE ? 'D' : '-',
+             flags & RTEMS_CAPTURE_BEGIN ? 'B' : '-',
+             flags & RTEMS_CAPTURE_EXITTED ? 'E' : '-');
+    flags = rtems_capture_control_from_triggers (control);
+    fprintf (stdout, " F:%c%c%c%c%c",
+             flags & RTEMS_CAPTURE_DELETE  ? 'D' : '-');
+    for (f = 0, fshowed = 0, lf = 1; f < RTEMS_CAPTURE_TRIGGER_TASKS; f++)
+      if (rtems_capture_control_by_valid (control, f))
+        if (lf && ((fshowed % 3) == 0))
+          fprintf (stdout, "\n");
+          lf = 0;
+        fprintf (stdout, "  %2i:", f);
+        rtems_monitor_dump_name (rtems_capture_control_by_name (control, f));
+        fprintf (stdout, "/");
+        rtems_monitor_dump_id (rtems_capture_control_by_id (control, f));
+        flags = rtems_capture_control_by_triggers (control, f);
+        fprintf (stdout, ":%c%c%c%c%c",
+        fshowed++;
+        lf = 1;
+    if (lf)
+    control = rtems_capture_next_control (control);
diff --git a/cpukit/libmisc/capture/captureimpl.h b/cpukit/libmisc/capture/captureimpl.h
index 3c2f6c3..cc11646 100644
--- a/cpukit/libmisc/capture/captureimpl.h
+++ b/cpukit/libmisc/capture/captureimpl.h
@@ -260,6 +260,64 @@ void* rtems_capture_record_open (rtems_tcb*                    task,
 void rtems_capture_record_close( void *rec, rtems_interrupt_lock_context* lock_context);
+ * @brief Capture print trace records.
+ * This function reads, prints and releases up to
+ * total trace records in either a csv format or an
+ * ascii table format.
+ * @param[in] total specifies the number of records to print
+ * @param[in] csv specifies a comma seperated value format
+void rtems_capture_print_trace_records ( int total, bool csv );
+ * @brief Capture print timestamp.
+ * This function prints uptime in a timestamp format.
+ * @param[in] uptime specifies the timestamp to print
+void rtems_capture_print_timestamp (uint64_t uptime);
+ * @brief Capture print record task.
+ * This function  prints a capture record task.  This
+ * record contains information to identify a task.  It
+ * is refrenced in other records by the task id.
+ * @param[in] cpu specifies the cpu the cpu the record was logged on.
+ * @param[in] rec specifies the task record.
+void rtems_capture_print_record_task(
+  uint32_t                cpu,
+ * @brief Capture print capture record.
+ * This function prints a user extension
+ * capture record.
+ * @param[in] rec specifies the record.
+ * @param[in] diff specifies the time between this and the last capture record.
+void rtems_capture_print_record_capture(
+  uint32_t                cpu,
+  uint64_t                diff
+ * @brief Capture print watch list
+ * This function  prints a capture watch list
+void rtems_capture_print_watch_list( void );
 #ifdef __cplusplus
1.8.1.4
