[rtems commit] bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs
Fri Nov 21 07:31:45 UTC 2014
On 21/11/14 06:10, Chris Johns wrote:
> On 21/11/2014 12:53 am, Sebastian Huber wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    50440c065e247899ee739d56cb1392c259289031
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=50440c065e247899ee739d56cb1392c259289031
>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date:      Wed Nov 19 15:30:24 2014 +0100
>> +RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*],[1])
>> +RTEMS_BSPOPTS_HELP([BSP_DATA_CACHE_ENABLED],[enable data cache])
>> +RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*],[1])
>> +RTEMS_BSPOPTS_HELP([BSP_INSTRUCTION_CACHE_ENABLED],[enable
>> instruction cache])
> To disable I provide configure with:
>  BSP_DATA_CACHE_ENABLED=0 BSP_INSTRUCTION_CACHE_ENABLED=0
> however this:
>> +#if defined(BSP_DATA_CACHE_ENABLED) ||
>> defined(BSP_INSTRUCTION_CACHE_ENABLED)
>> +    /* Enable unified L2 cache */
>> +    rtems_cache_enable_data();
>> +#endif
> and this:
>> +#if !defined(RTEMS_SMP) \
>> +  && (defined(BSP_DATA_CACHE_ENABLED) \
>> +    || defined(BSP_INSTRUCTION_CACHE_ENABLED))
>> +#endif
> only check for defined and it is always defined. These should check
> for the value only ie:
> #if BSP_DATA_CACHE_ENABLED || BSP_INSTRUCTION_CACHE_ENABLED
You should use
BSP_DATA_CACHE_ENABLED= BSP_INSTRUCTION_CACHE_ENABLED=
for the configure.
> This is not the only case of BSPOPTS'less'ness we have in RTEMS but
> this one is an issue for me. Have I told you recently how much I
> dislike the BSPOPTS support.
Yes, I know, but what is the alternative?  These defines are already
used for a lot of PowerPC BSPs and I don't think it is good to invent
yet another solution for the same problem on ARM.
> FYI the L2 cache seems to have upset OpenOCD and breakpoints. They are
> now stopdeadpoints and once hit you never leave.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
