[PATCH 04/22] dosfs: Avoid MIN() re-definition
Fri Nov 21 11:11:00 UTC 2014
On 21/11/14 11:26, Peter Dufault wrote:
> I don't like these kind of "ifndef" tests before defining something because how do you know it was defined compatibly?  Granted MIN is well-known so that's less likely than other uses of this pattern.
> Can the definition be made identical to the other definition to eliminate a warning or does GCC still warn about a redefinition?
I fixed it this way:
http://git.rtems.org/rtems/commit/?id=11925eef789566a226d8eaacbceb4d89df787ebc
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
