[PATCH] smp: Fix scheduler helping protocol
Fri Nov 21 16:09:53 UTC 2014
On 11/21/2014 10:07 AM, Sebastian Huber wrote:
> From: Luca Bonato <lohathe at gmail.com>
> New test case for smptests/smpmrsp01.
> It possible that a state change from SCHEDULER_SMP_NODE_READY to
> SCHEDULER_SMP_NODE_READY can happen.
Fix English.
How about a short description of the scenario this is addressing?
>  cpukit/score/include/rtems/score/schedulerimpl.h   |  28 ++--
>  .../score/include/rtems/score/schedulersmpimpl.h   |  25 ++-
>  testsuites/smptests/smpmrsp01/init.c               | 174 +++++++++++++++++++++
>  testsuites/smptests/smpmrsp01/smpmrsp01.scn        |   1 +
>  4 files changed, 210 insertions(+), 18 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index 45a2f8d..b262b91 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -1081,6 +1081,7 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Release_idle_thread(
>  RTEMS_INLINE_ROUTINE bool _Scheduler_Block_node(
>    Scheduler_Context         *context,
> +  Thread_Control            *thread,
>    Scheduler_Node            *node,
>    bool                       is_scheduled,
>    Scheduler_Get_idle_thread  get_idle_thread
> @@ -1088,25 +1089,24 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Block_node(
>    bool block;
>    Thread_Control *old_user = _Scheduler_Node_get_user( node );
> -  Thread_Control *new_user;
> +  Thread_Control *new_user = NULL;
>    _Scheduler_Thread_change_state( old_user, THREAD_SCHEDULER_BLOCKED );
> -  if ( node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL ) {
> -    new_user = _Scheduler_Node_get_owner( node );
> -    _Assert( new_user != old_user );
> -    _Scheduler_Node_set_user( node, new_user );
> -  } else if (
> -    node->help_state == SCHEDULER_HELP_ACTIVE_OWNER
> -      && is_scheduled
> -    new_user = _Scheduler_Use_idle_thread( context, node, get_idle_thread );
> -  } else {
> -    new_user = NULL;
> +  if ( is_scheduled ) {
> +    if ( node->help_state == SCHEDULER_HELP_ACTIVE_OWNER ) {
> +      new_user = _Scheduler_Use_idle_thread( context, node, get_idle_thread );
> +    } else if ( node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL ) {
> +      Thread_Control *owner = _Scheduler_Node_get_owner( node );
> +      if ( thread == old_user && owner != old_user ) {
> +        new_user = owner;
> +        _Scheduler_Node_set_user( node, new_user );
> -  if ( new_user != NULL && is_scheduled ) {
> +  if ( new_user != NULL ) {
>      Per_CPU_Control *cpu = _Thread_Get_CPU( old_user );
>      _Scheduler_Thread_change_state( new_user, THREAD_SCHEDULER_SCHEDULED );
> diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
> index 156307d..0ddfce0 100644
> --- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
> @@ -793,13 +793,17 @@ static inline void _Scheduler_SMP_Block(
>    Scheduler_SMP_Node *node = _Scheduler_SMP_Thread_get_node( thread );
>    bool is_scheduled = node->state == SCHEDULER_SMP_NODE_SCHEDULED;
> -  bool block = _Scheduler_Block_node(
> +  bool block;
> +  _Assert( is_scheduled || node->state == SCHEDULER_SMP_NODE_READY );
> +  block = _Scheduler_Block_node(
>      context,
> +    thread,
>      &node->Base,
>      is_scheduled,
>      _Scheduler_SMP_Get_idle_thread
>    if ( block ) {
>      _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
> @@ -838,9 +842,22 @@ static inline Thread_Control *_Scheduler_SMP_Unblock(
>    Thread_Control *needs_help;
>    if ( unblock ) {
> -    _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
> +    if ( node->state != SCHEDULER_SMP_NODE_READY ) {
> +      _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
> +      needs_help = ( *enqueue_fifo )( context, &node->Base, thread );
> +    } else {
> +      _Assert( node->state == SCHEDULER_SMP_NODE_READY );
> +      _Assert( node->Base.idle == NULL );
> -    needs_help = ( *enqueue_fifo )( context, &node->Base, thread );
> +      if ( node->Base.accepts_help == thread ) {
> +        _Assert( node->Base.help_state == SCHEDULER_HELP_ACTIVE_OWNER );
> +        needs_help = thread;
> +      } else {
> +        _Assert( node->Base.help_state == SCHEDULER_HELP_ACTIVE_RIVAL );
> +        needs_help = NULL;
>    } else {
>      needs_help = NULL;
> diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
> index bfa5d98..f6a98e2 100644
> --- a/testsuites/smptests/smpmrsp01/init.c
> +++ b/testsuites/smptests/smpmrsp01/init.c
> @@ -54,6 +54,7 @@ typedef struct {
>  typedef struct {
>    rtems_id main_task_id;
>    rtems_id migration_task_id;
> +  rtems_id high_task_id;
>    rtems_id counting_sem_id;
>    rtems_id mrsp_ids[MRSP_COUNT];
>    rtems_id scheduler_ids[CPU_COUNT];
> @@ -66,6 +67,7 @@ typedef struct {
>    SMP_lock_Control switch_lock;
>    size_t switch_index;
>    switch_event switch_events[32];
> +  volatile bool run;
>  } test_context;
>  static test_context test_instance = {
> @@ -728,6 +730,177 @@ static void run_task(rtems_task_argument arg)
> +static void ready_unlock_worker(rtems_task_argument arg)
> +  test_context *ctx = &test_instance;
> +  rtems_status_code sc;
> +  SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
> +  assert_prio(RTEMS_SELF, 4);
> +  /* Obtain (F) */
> +  barrier(ctx, &barrier_state);
> +  sc = rtems_semaphore_obtain(ctx->mrsp_ids[0], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  sc = rtems_semaphore_release(ctx->mrsp_ids[0]);
> +  /* Done (G) */
> +  rtems_task_suspend(RTEMS_SELF);
> +  rtems_test_assert(0);
> +static void ready_unblock_timer(rtems_id timer_id, void *arg)
> +  test_context *ctx = arg;
> +  sc = rtems_task_start(
> +    ctx->high_task_id,
> +    run_task,
> +    (rtems_task_argument) &ctx->run
> +  sc = rtems_task_suspend(ctx->high_task_id);
> +  sc = rtems_task_resume(ctx->high_task_id);
> +   * At this point the scheduler node of the main thread is in the
> +   * SCHEDULER_SMP_NODE_READY state and a _Scheduler_SMP_Unblock() operation is
> +   * performed.
> +  sc = rtems_event_transient_send(ctx->main_task_id);
> +static void test_mrsp_ready_unblock(test_context *ctx)
> +  rtems_id timer_id;
> +  puts("test MrsP ready unblock");
> +  ctx->run = false;
> +  change_prio(RTEMS_SELF, 4);
> +  sc = rtems_semaphore_create(
> +    rtems_build_name(' ', ' ', ' ', 'A'),
> +    1,
> +    RTEMS_MULTIPROCESSOR_RESOURCE_SHARING
> +      | RTEMS_BINARY_SEMAPHORE,
> +    3,
> +    &ctx->mrsp_ids[0]
> +  sc = rtems_task_create(
> +    rtems_build_name('H', 'I', 'G', 'H'),
> +    2,
> +    RTEMS_MINIMUM_STACK_SIZE,
> +    RTEMS_DEFAULT_MODES,
> +    RTEMS_DEFAULT_ATTRIBUTES,
> +    &ctx->high_task_id
> +    rtems_build_name('W', 'O', 'R', 'K'),
> +    4,
> +    &ctx->worker_ids[0]
> +  sc = rtems_task_set_scheduler(ctx->worker_ids[0], ctx->scheduler_ids[1]);
> +  sc = rtems_timer_create(rtems_build_name('T', 'I', 'M', 'R'), &timer_id);
> +  assert_prio(RTEMS_SELF, 3);
> +  sc = rtems_timer_fire_after(timer_id, 2, ready_unblock_timer, ctx);
> +  sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> +  rtems_test_assert(!ctx->run);
> +  sc = rtems_task_start(ctx->worker_ids[0], ready_unlock_worker, 0);
> +  /* Worker obtain (F) */
> +  sc = rtems_task_wake_after(2);
> +  sc = rtems_task_suspend(ctx->worker_ids[0]);
> +  sc = rtems_task_set_scheduler(ctx->high_task_id, ctx->scheduler_ids[1]);
> +  while (!ctx->run) {
> +    /* Do noting */
> +  sc = rtems_task_resume(ctx->worker_ids[0]);
> +  /* Worker done (F) */
> +  sc = rtems_timer_delete(timer_id);
> +  sc = rtems_task_delete(ctx->worker_ids[0]);
> +  sc = rtems_task_delete(ctx->high_task_id);
> +  sc = rtems_semaphore_delete(ctx->mrsp_ids[0]);
> +  change_prio(RTEMS_SELF, 2);
>  static void test_mrsp_obtain_and_sleep_and_release(test_context *ctx)
> @@ -1232,6 +1405,7 @@ static void Init(rtems_task_argument arg)
>    test_mrsp_unlock_order_error();
>    test_mrsp_deadlock_error(ctx);
>    test_mrsp_multiple_obtain();
> +  test_mrsp_ready_unblock(ctx);
>    test_mrsp_obtain_and_sleep_and_release(ctx);
>    test_mrsp_obtain_and_release_with_help(ctx);
>    test_mrsp_obtain_and_release(ctx);
> diff --git a/testsuites/smptests/smpmrsp01/smpmrsp01.scn b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
> index 3315db1..2e1f32c 100644
> --- a/testsuites/smptests/smpmrsp01/smpmrsp01.scn
> +++ b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
> @@ -5,6 +5,7 @@ test MrsP nested obtain error
>  test MrsP unlock order error
>  test MrsP deadlock error
>  test MrsP multiple obtain
> +test MrsP ready unblock
>  test MrsP obtain and sleep and release
>  [0] MAIN ->  RUN (prio   2, node  RUN)
>  [0]  RUN -> MAIN (prio   1, node MAIN)
