anyone else see sparc-rtems4.11 not building with RSB
Fri Nov 21 19:13:53 UTC 2014
I built a toolchain yesterday for sparc32. Check the build-log for the
error message, the tail of the make is insufficient information.
On Fri, Nov 21, 2014 at 1:53 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> RSB report has:
> make[1]: Leaving directory
> `/users/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.7-1/build'
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex
> /users/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.7-1/doit
> error: building sparc-rtems4.11-gdb-7.7-1
> Make ends with this:
> config.status: creating gdb.xml/Makefile
> make[2]: Entering directory
> `/users/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.7-1/build/sim'
> make[3]: Entering directory
> `/users/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.7-1/build/sim/erc32'
> make[3]: *** No targets specified and no makefile found.  Stop.
> make[3]: Leaving directory
> make[2]: *** [all] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-sim] Error 2
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
