[RTEMS Project] #2175: C++ Exception Catch Handler Crash on Sparc ERC32 Simulator(SIS)
Sun Nov 23 19:31:29 UTC 2014
Thanks Jiri!
On Sun, Nov 23, 2014 at 1:22 PM, Jiri Gaisler <jiri at gaisler.se> wrote:
> On 11/23/2014 04:36 PM, Gedare Bloom wrote:
>>  Is this fixed?
> Seems OK with the new version of sis. Below is the log from cdtest.exe.
> I'm using the leon3 bsp, but is should be the same on all sparc bsp's.
> Jiri.
> $ sparc-rtems4.11-sis -leon3 src/rtems/4.11/sparc-rtems4.11/leon3/lib/rtems-4.11/tests/cdtest.exe
>  SIS - SPARC instruction simulator 2.8,  copyright Jiri Gaisler 1995
>  Bug-reports to jiri at gaisler.se
>  LEON3 emulation enabled
> sis> run
> GLOBAL: Hey I'm in base class constructor number 1 for 0x40033254.
> GLOBAL: Hey I'm in base class constructor number 2 for 0x40033248.
> GLOBAL: Hey I'm in derived class constructor number 3 for 0x40033248.
> *** CONSTRUCTOR/DESTRUCTOR TEST ***
> LOCAL: Hey I'm in base class constructor number 4 for 0x4003db60.
> LOCAL: Hey I'm in base class constructor number 5 for 0x4003db6c.
> LOCAL: Hey I'm in base class constructor number 6 for 0x4003db78.
> LOCAL: Hey I'm in base class constructor number 7 for 0x4003db84.
> LOCAL: Hey I'm in derived class constructor number 8 for 0x4003db84.
> IO Stream not tested
> LOCAL: Hey I'm in derived class destructor number 8 for 4003DB84.
> Derived class - Instantiation order 8
> LOCAL: Hey I'm in base class destructor number 7 for 4003DB84.
> LOCAL: Hey I'm in base class destructor number 6 for 4003DB78.
> Derived class - Instantiation order 6
> LOCAL: Hey I'm in base class destructor number 5 for 4003DB6C.
> Derived class - Instantiation order 5
> LOCAL: Hey I'm in base class destructor number 4 for 4003DB60.
> *** END OF CONSTRUCTOR/DESTRUCTOR TEST ***
> *** TESTING C++ EXCEPTIONS ***
> foo_function() catch block called:
>    < foo_function() throw this exception  >
> Success catching a char * exception
> foo_function() re-throwing execption...
> throw an instance based exception
> RtemsException raised=File:../../../../../../../rtems-4.11/c/src/../../testsuites/samples/cdtest/main.cc, Line:199, Error=55
> Success catching RtemsException...
> RtemsException ---> File:../../../../../../../rtems-4.11/c/src/../../testsuites/samples/cdtest/main.cc, Line:199, Error=55
> Exceptions are working properly.
> Global Dtors should be called after this line....
> GLOBAL: Hey I'm in derived class destructor number 3 for 40033248.
> Derived class - Instantiation order 3
> GLOBAL: Hey I'm in base class destructor number 2 for 40033248.
> GLOBAL: Hey I'm in base class destructor number 1 for 40033254.
> Derived class - Instantiation order 1
>>>>  Reporter:  jbkim     |       Owner:  ralf.corsepius
>>>>      Type:  defect    |      Status:  closed
>>>>  Priority:  normal    |   Milestone:  4.11
>>>> Component:  GCC       |     Version:  4.11
>>>>  Severity:  critical  |  Resolution:  fixed
>>>>  Keywords:            |
>>>> Changes (by joel.sherrill):
>>>>  * status:  new => closed
>>>>  * version:  unknown => 4.11
>>>>  * resolution:   => fixed
>>>> Ticket URL: <http://devel.rtems.org/ticket/2175#comment:3>
>>>> RTEMS Project <http://www.rtems.org/>
>>>> RTEMS Project
>> devel mailing list
>> devel at rtems.org
