[PATCH 4/4 v2] SPARC: optimize IRQ enable & disable
Mon Nov 24 15:30:51 UTC 2014
On Mon, Nov 24, 2014 at 5:15 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> * Coding style cleanups.
> * Use OS reserved trap 0x89 for IRQ Disable
> * Use OS reserved trap 0x8A for IRQ Enable
> This will result in faster Disable/Enable code since the
> system trap handler does not need to decode which function
> the user wants. Besides the IRQ disable/enabled can now
> be inline which avoids the caller to take into account that
> o0-o7+g1-g4 registers are destroyed by trap handler.
> It was also possible to reduce the interrupt traphandler with
s/traphandler/trap handler
s/with/by
> five instructions due to this.
>  c/src/lib/libbsp/sparc/leon3/startup/spurious.c |    9 +-
>  c/src/lib/libbsp/sparc/shared/irq_asm.S         |   42 ++++-----
>  c/src/lib/libbsp/sparc/shared/start/start.S     |   25 ++++-
>  c/src/lib/libcpu/sparc/syscall/syscall.S        |  118 +++++++++++++----------
>  c/src/lib/libcpu/sparc/syscall/syscall.h        |    2 -
>  cpukit/score/cpu/sparc/rtems/score/sparc.h      |   18 +++-
>  6 files changed, 124 insertions(+), 90 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> index a29f113..6a93670 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> @@ -146,14 +146,15 @@ void bsp_spurious_initialize()
>       *  Skip window overflow, underflow, and flush as well as software
> -     *  trap 0 which we will use as a shutdown. Also avoid trap 0x70 - 0x7f
> -     *  which cannot happen and where some of the space is used to pass
> -     *  paramaters to the program.
> +     *  trap 0,9,10 which we will use as a shutdown, IRQ disable, IRQ enable.
> +     *  Also avoid trap 0x70 - 0x7f which cannot happen and where some of the
> +     *  space is used to pass paramaters to the program.
>      if (( trap == 5 || trap == 6 ) ||
>          (( trap >= 0x11 ) && ( trap <= 0x1f )) ||
> -        (( trap >= 0x70 ) && ( trap <= 0x83 )))
> +        (( trap >= 0x70 ) && ( trap <= 0x83 )) ||
> +       (( trap >= 0x89 ) && ( trap <= 0x8a )))
>        continue;
>      set_vector(
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index 2ab0def..3e08795 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -499,8 +499,7 @@ dont_fix_pil2:
>          cmp      %l7, 0
>          bne      profiling_not_outer_most_exit
>           nop
> -        call     SYM(sparc_disable_interrupts), 0
> -         nop
> +        ta       SPARC_SWTRAP_IRQDIS    ! Call interrupt disable trap handler
>          ld       [%l4], %o2             ! o2 = 3rd arg = interrupt exit instant
>          mov      %l3, %o1               ! o1 = 2nd arg = interrupt entry instant
>          call     SYM(_Profiling_Outer_most_interrupt_entry_and_exit), 0
> @@ -585,38 +584,31 @@ profiling_not_outer_most_exit:
>          nop
>  isr_dispatch:
>          call    SYM(_Thread_Dispatch), 0
> -        nop
> +         nop
> -        *  We invoked _Thread_Dispatch in a state similar to the interrupted
> -        *  task.  In order to safely be able to tinker with the register
> -        *  windows and get the task back to its pre-interrupt state,
> -        *  we need to disable interrupts disabled so we can safely tinker
> -        *  with the register windowing.  In particular, the CWP in the PSR
> -        *  is fragile during this period. (See PR578.)
> -       mov     2,%g1                           ! syscall (disable interrupts)
> -       ta      0                               ! syscall (disable interrupts)
> +         *  We invoked _Thread_Dispatch in a state similar to the interrupted
> +         *  task.  In order to safely be able to tinker with the register
> +         *  windows and get the task back to its pre-interrupt state,
> +         *  we need to disable interrupts disabled so we can safely tinker
> +         *  with the register windowing.  In particular, the CWP in the PSR
> +         *  is fragile during this period. (See PR578.)
> +        ta      SPARC_SWTRAP_IRQDIS  ! syscall (disable interrupts)
>           *  While we had ISR dispatching disabled in this thread,
>           *  did we miss anything.  If so, then we need to do another
>           *  _Thread_Dispatch before leaving this ISR Dispatch context.
> +        ldub    [%g6 + PER_CPU_DISPATCH_NEEDED], %l7
> -        ldub     [%g6 + PER_CPU_DISPATCH_NEEDED], %l7
> -        orcc     %l7, %g0, %g0    ! Is thread switch necesary?
> -        bz       allow_nest_again ! No, then clear out and return
> -        nop
> -        ! Yes, then invoke the dispatcher
> -dispatchAgain:
> -       mov     3,%g1                           ! syscall (enable interrupts)
> -       ta      0                               ! syscall (enable interrupts)
> -        ba      isr_dispatch
> -        nop
> +        orcc    %l7, %g0, %g0        ! Is thread switch necesary?
> +        bne,a   isr_dispatch         ! Yes, then invoke the dispatcher.
> +                                     ! g1 = Old PSR PIL returned from IRQDis
> +        ta      SPARC_SWTRAP_IRQEN   ! syscall (enable interrupts to same level)
> +        ! No, then clear out and return
>  allow_nest_again:
>          ! Zero out ISR stack nesting prevention flag
> diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
> index 3e0e42e..9e9bcaf 100644
> --- a/c/src/lib/libbsp/sparc/shared/start/start.S
> +++ b/c/src/lib/libbsp/sparc/shared/start/start.S
> @@ -35,11 +35,20 @@
>   * System call optimized trap table entry
> -#define SYSCALL_TRAP(_vector, _handler)  \
> +#define IRQDIS_TRAP(_vector, _handler)  \
>    mov   %psr, %l0 ; \
>    sethi %hi(_handler), %l4 ; \
>    jmp   %l4+%lo(_handler); \
> -   subcc %g1, 3, %g0; ! prepare for syscall 3 check
> +   or  %l0, 0x0f00, %l3; ! Set PIL=0xf to disable IRQ
> + * System call optimized trap table entry
> +#define IRQEN_TRAP(_vector, _handler)  \
> +  mov   %psr, %l0 ; \
> +  sethi %hi(_handler), %l4 ; \
> +  jmp   %l4+%lo(_handler); \
> +   andn %l0, 0xf00, %l3; ! Set PIL=0 to Enable IRQ
>   * Window Overflow optimized trap table entry
> @@ -183,12 +192,20 @@ SYM(CLOCK_SPEED):
>     *        installed before.
> -  SYSCALL_TRAP( 0x80, SYM(syscall) );          ! 80 syscall SW trap
> +  TRAP( 0x80, SYM(syscall) );                  ! 80 halt syscall SW trap
>    SOFT_TRAP; SOFT_TRAP;                        ! 81 - 82
>    TRAP( 0x83, SYM(window_flush_trap_handler) ); ! 83 flush windows SW trap
>    SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 84 - 87
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 88 - 8B
> +  SOFT_TRAP;                                   ! 88
> +   *  SW Trap 9-15 Reserved for Operating System
> +  IRQDIS_TRAP(0x89, SYM(syscall_irqdis));      ! 89 IRQ Disable syscall trap
> +  IRQEN_TRAP(0x8A, SYM(syscall_irqen));                ! 8A IRQ Enable syscall trap
> +  SOFT_TRAP;                                           ! 8B
>    SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 8C - 8F
>    SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 90 - 93
>    SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 94 - 97
> diff --git a/c/src/lib/libcpu/sparc/syscall/syscall.S b/c/src/lib/libcpu/sparc/syscall/syscall.S
> index 9ce7fa5..64c4805 100644
> --- a/c/src/lib/libcpu/sparc/syscall/syscall.S
> +++ b/c/src/lib/libcpu/sparc/syscall/syscall.S
> @@ -19,69 +19,81 @@
>  #include <rtems/asm.h>
>  #include "syscall.h"
> -        .seg    "text"
> -         *  system call
> -         *  On entry:
> -         *    l0 = psr (from trap table)
> -         *    l1 = pc
> -         *    l2 = npc
> -         *    g1 = system call id
> -         *  System Call 1 (exit):
> -         *    g2 = additional exit code 1
> -         *    g3 = additional exit code 2
> -.align 32                              ! Align to 32-byte cache-line
> -        PUBLIC(syscall)
> +       .seg    "text"
> +        *  system call - halt
> +        *  On entry:
> +        *    l0 = psr (from trap table)
> +        *    l1 = pc
> +        *    l2 = npc
> +        *    g1 = system call id (1)
> +        *  System Call 1 (exit):
> +        *    g2 = additional exit code 1
> +        *    g3 = additional exit code 2
> +       PUBLIC(syscall)
>  SYM(syscall):
> +       ta      0                       ! syscall 1, halt with %g1,%g2,%g3 info
> -       ! "subcc, %g1, 3, %g0" done in trap table
> -       bne     2f                      ! syscall 3? enable interrupt
> -        and    %i0, SPARC_PSR_PIL_MASK, %l4
> -       andn    %l0, SPARC_PSR_PIL_MASK, %l5
> -       wr      %l4, %l5, %psr          ! Update PSR according to syscall 3
> -1:                                     ! leave, with 3 inst PSR-write delay
> -       mov     0, %g1                  ! clear %g1
> -       or      %l0, SPARC_PSR_ET_MASK, %i0     ! return old psr with ET=1. No
> -                                               ! effect on syscall 3
> -       jmpl    %l2, %g0
> -        rett   %l2 + 4
> -2:     or      %l0, 0x0f00, %l4        ! set PIL=15
> -       subcc   %g1, 2, %g0             ! syscall 2? disable interrupts
> -       beq,a   1b                      ! Annul delay-slot for syscall 1
> -        mov    %l4, %psr               ! Update PSR according to Syscall 2
> -       ta      0                       ! syscall 1 (not 2 or 3), halt
> -        PUBLIC(sparc_disable_interrupts)
> +       PUBLIC(sparc_syscall_exit)
> -SYM(sparc_disable_interrupts):
> -       mov     SYS_irqdis, %g1
> -       retl
> -        ta     0
> +SYM(sparc_syscall_exit):
> -        PUBLIC(sparc_enable_interrupts)
> +       mov     SYS_exit, %g1
> +       mov     %o0, %g2        ! Additional exit code 1
> +       mov     %o1, %g3        ! Additional exit code 2
> +       ta      SPARC_SWTRAP_SYSCALL
> +        *  system call - Interrupt Disable
> +        *  On entry:
> +        *    l1 = pc
> +        *    l2 = npc
> +        *    l3 = psr | SPARC_PSR_PIL_MASK
> +        *  On exit:
> +        *    g1 = old psr (to user)
> -SYM(sparc_enable_interrupts):
> +.align 32                              ! Align to 32-byte cache-line
> +       PUBLIC(syscall_irqdis)
> -       mov     SYS_irqen, %g1
> -       retl
> -        ta     0
> +SYM(syscall_irqdis):
> +       mov     %l3, %psr                       ! Set PSR. Write delay 3 instr
> +       or      %l0, SPARC_PSR_ET_MASK, %g1     ! return old PSR with ET=1
> +       nop                                     ! PSR write delay
> +       jmp     %l2                             ! Return to after TA 9.
> +        rett   %l2 + 4
> -        PUBLIC(sparc_syscall_exit)
> +        *  system call - Interrupt Enable
> +        *  On entry:
> +        *    l1 = pc
> +        *    l2 = npc
> +        *    l3 = psr & ~0x0f00
> +        *    g1 = new PIL to write (from user)
> -SYM(sparc_syscall_exit):
> +       PUBLIC(syscall_irqen)
> -       mov     SYS_exit, %g1
> -       mov     %o0, %g2        ! Additional exit code 1
> -       mov     %o1, %g3        ! Additional exit code 2
> -       ta      0
> +SYM(syscall_irqen):
> +       and     %g1, SPARC_PSR_PIL_MASK, %l4    ! %l4 = (%g1 & 0xf00)
> +       wr      %l3, %l4, %psr                  ! PSR = (PSR & ~0xf00) ^ %l4
> +       nop; nop                                ! PSR write delay;
> +       jmp     %l2                             ! Return to after TA 10.
> +        rett   %l2 + 4
>  #if defined(RTEMS_PARAVIRT)
> diff --git a/c/src/lib/libcpu/sparc/syscall/syscall.h b/c/src/lib/libcpu/sparc/syscall/syscall.h
> index 9af3560..2f20886 100644
> --- a/c/src/lib/libcpu/sparc/syscall/syscall.h
> +++ b/c/src/lib/libcpu/sparc/syscall/syscall.h
> @@ -1,3 +1 @@
>  #define SYS_exit        1
> -#define SYS_irqdis      2
> -#define SYS_irqen       3
> diff --git a/cpukit/score/cpu/sparc/rtems/score/sparc.h b/cpukit/score/cpu/sparc/rtems/score/sparc.h
> index e3251d8..7fe7ea4 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/sparc.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/sparc.h
> @@ -157,6 +157,11 @@ extern "C" {
>  #define LEON3_ASR17_PROCESSOR_INDEX_SHIFT 28
> +/* SPARC Software Trap number definitions */
> +#define SPARC_SWTRAP_SYSCALL 0
> +#define SPARC_SWTRAP_IRQDIS 9
> +#define SPARC_SWTRAP_IRQEN 10
>  #ifndef ASM
> @@ -306,7 +311,12 @@ void _SPARC_Set_TBR( uint32_t new_tbr );
>   * @return This method returns the entire PSR contents.
> -uint32_t sparc_disable_interrupts(void);
> +static inline uint32_t sparc_disable_interrupts(void)
> +  register uint32_t psr __asm__("g1");
> +  __asm__ volatile ( "ta %1\n\t" : "=r" (psr) : "i" (SPARC_SWTRAP_IRQDIS));
This is clever. A brief comment might be nice to help the reader
understand that writing to g1 is a side-effect of the trap handler.
> +  return psr;
>   * @brief SPARC enable processor interrupts.
> @@ -315,7 +325,11 @@ uint32_t sparc_disable_interrupts(void);
>   * @param[in] psr is the PSR returned by @ref sparc_disable_interrupts.
> -void sparc_enable_interrupts(uint32_t psr);
> +static inline void sparc_enable_interrupts(uint32_t psr)
> +  register uint32_t _psr __asm__("g1") = psr;
> +  __asm__ volatile ( "ta %0\n" :: "i" (SPARC_SWTRAP_IRQEN), "r" (_psr));
Ditto, except this could clobber the g1 register directly instead of
through the _psr variable.
>   * @brief SPARC exit through system call 1
> 1.7.0.4
> devel mailing list
> devel at rtems.org
