Please review RTEMS JFFS2 Adapter Issue
Tue Nov 25 19:48:32 UTC 2014
Sebastian will have to comment, but it looks like the inner path is
not expected to be taken the first time through, i.e. you might add:
assert(root_i->i_count > 0);
-Gedare
On Tue, Nov 25, 2014 at 2:30 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Coverity Id 1255348 in fs-rtems.c can't be ignored on the grounds
> the JFFS2 project will see it.
>                                this->i_cache_prev->i_cache_next =
> this->i_cache_next;
>  84                        jffs2_clear_inode(this);
>  85                        memset(this, 0x5a, sizeof(*this));
> 15. freed_arg: free frees this. [Note: The source code implementation of the
> function has been overridden by a builtin model.]
>  86                        free(this);
> 6. Condition parent, taking true branch
> 7. Condition parent != this, taking true branch
> 16. Condition parent, taking true branch
> 17. Condition parent != this, taking true branch
>  87                        if (parent && parent != this) {
>  88                                parent->i_count--;
> 8. alias: Assigning: this = root_i. Now both point to the same storage.
> CID 1255348 (#1-2 of 2): Use after free (USE_AFTER_FREE)18. use_after_free:
> Using freed pointer root_i.
>  89                                this = root_i;
> 9. Jumping to label restart
>  90                                goto restart;
>  91                        }
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
