Please review RTEMS JFFS2 Adapter Issue
Tue Nov 25 19:49:04 UTC 2014
On Tue, Nov 25, 2014 at 2:48 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Sebastian will have to comment, but it looks like the inner path is
> not expected to be taken the first time through, i.e. you might add:
> assert(root_i->i_count > 0);
P.S. the function has a FIXME at the top suggesting it should be done
a different way, but how is not clear.
> -Gedare
> On Tue, Nov 25, 2014 at 2:30 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Coverity Id 1255348 in fs-rtems.c can't be ignored on the grounds
>> the JFFS2 project will see it.
>>                                this->i_cache_prev->i_cache_next =
>> this->i_cache_next;
>>  84                        jffs2_clear_inode(this);
>>  85                        memset(this, 0x5a, sizeof(*this));
>> 15. freed_arg: free frees this. [Note: The source code implementation of the
>> function has been overridden by a builtin model.]
>>  86                        free(this);
>> 6. Condition parent, taking true branch
>> 7. Condition parent != this, taking true branch
>> 16. Condition parent, taking true branch
>> 17. Condition parent != this, taking true branch
>>  87                        if (parent && parent != this) {
>>  88                                parent->i_count--;
>> 8. alias: Assigning: this = root_i. Now both point to the same storage.
>> CID 1255348 (#1-2 of 2): Use after free (USE_AFTER_FREE)18. use_after_free:
>> Using freed pointer root_i.
>>  89                                this = root_i;
>> 9. Jumping to label restart
>>  90                                goto restart;
>>  91                        }
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
