spsem01 does not terminate on sis (and real leon3 hardware)
Tue Nov 25 22:54:21 UTC 2014
On 11/25/2014 4:49 PM, Jiri Gaisler wrote:
> On 11/25/2014 11:42 PM, Jiri Gaisler wrote:
>> spsem01.exe executes correctly on sis and real hardware, but does not terminate.
>> The program hangs in the bsp_idle_tread() after executing the final rtems_test_exit(0).
>> Is this the intention of the test?
> OK, I found a difference in the output compared to the spsem01.scn:
> @@ -9,7 +9,8 @@
>  TA02: started with priority 34
>  TA01: priority 34, holding S0
>  TA02: priority 34, holding S1
> -TA02: suspending
> +TA02: exiting
>  TA01: priority 36
>  TA01: exiting
> In spsem01.scn, task 2 is suspended at the end while in the current
> executable task 2 reports 'exiting'. Is spsem01.scn just not updated
> or is there bug here ...?
I would bet the screen is not up to date. :(
> devel mailing list
> devel at rtems.org
