[PATCH 07/20] libcsupport/src/newlibc_exit.c: Remove dead code
Tue Nov 25 23:02:35 UTC 2014
This was flagged as an empty for statement by CodeSonar but is actually
unreachable code that should be removed.
 cpukit/libcsupport/src/newlibc_exit.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/libcsupport/src/newlibc_exit.c b/cpukit/libcsupport/src/newlibc_exit.c
index 74c547b..fad7f76 100644
--- a/cpukit/libcsupport/src/newlibc_exit.c
+++ b/cpukit/libcsupport/src/newlibc_exit.c
@@ -45,7 +45,7 @@ void _exit(int status)
   (*rtems_libio_exit_helper)();
   rtems_shutdown_executive(status);
-  for (;;) ; /* to avoid warnings */
+  /* does not return */
 #endif
1.9.3
