[PATCH 13/20] monitor/mon-editor.c: Use puts() and snprintf() not fprintf() or sprintf()
Tue Nov 25 23:02:41 UTC 2014
CodeSonar flagged this as a case where the user could inject a format
string and cause issues. Since we were not printing anything but a
string, just switching to puts() rather than fprintf(stdout,...) was
sufficient to make this code safer.
snprintf() places a limit on the length of the output from sprintf()
and avoids similar buffer overrun issues.
 cpukit/libmisc/monitor/mon-editor.c | 12 +++++++-----
 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
index 813c883..e7a3ae4 100644
--- a/cpukit/libmisc/monitor/mon-editor.c
+++ b/cpukit/libmisc/monitor/mon-editor.c
@@ -265,7 +265,7 @@ rtems_monitor_line_editor (
         switch (c)
           case KEYS_END:
-            fprintf(stdout,buffer + pos);
+            puts(buffer + pos);
             pos = (int) strlen (buffer);
             break;
@@ -428,7 +428,7 @@ rtems_monitor_line_editor (
                 int ch, bs;
                 for (ch = end; ch > pos; ch--)
                   buffer[ch] = buffer[ch - 1];
                 for (bs = 0; bs < (end - pos + 1); bs++)
                   putchar ('\b');
@@ -490,16 +490,18 @@ rtems_monitor_command_read(char *command,
 #if defined(RTEMS_MULTIPROCESSING)
   if (!rtems_configuration_get_user_multiprocessing_table ())
-    sprintf (monitor_prompt, "%s",
+    snprintf (monitor_prompt, sizeof(monitor_prompt), "%s",
              (env_prompt == NULL) ? MONITOR_PROMPT: env_prompt);
   else /* .... */
 #endif
   if (rtems_monitor_default_node != rtems_monitor_node)
-    sprintf (monitor_prompt, "%" PRId32 "-%s-%" PRId32 "", rtems_monitor_node,
+              "%" PRId32 "-%s-%" PRId32 "", rtems_monitor_node,
              (env_prompt == NULL) ? MONITOR_PROMPT : env_prompt,
              rtems_monitor_default_node);
   else
-    sprintf (monitor_prompt, "%" PRId32 "-%s", rtems_monitor_node,
+             "%" PRId32 "-%s", rtems_monitor_node,
              (env_prompt == NULL) ? MONITOR_PROMPT : env_prompt);
   rtems_monitor_line_editor (command);
1.9.3
