[PATCH 20/20] tools/build/*.c: Clean up issues reported by CodeSonar
Tue Nov 25 23:02:48 UTC 2014
This code is built without warnings and ignored by Coverity Scan.
CodeSonar found a wide range of issues including buffer overruns,
buffer underruns, questionable type conversions, leaks, etc. This
set of patches addresses all reported issues.
 tools/build/binpatch.c    | 144 ++++++++++++++--------------
 tools/build/cklength.c    |  28 +++---
 tools/build/eolstrip.c    |  14 ++-
 tools/build/rtems-bin2c.c | 233 ++++++++++++++++++++++++----------------------
 tools/build/unhex.c       | 196 +++++++++++++++++++-------------------
 5 files changed, 309 insertions(+), 306 deletions(-)
diff --git a/tools/build/binpatch.c b/tools/build/binpatch.c
index 4748b11..d85303e 100644
--- a/tools/build/binpatch.c
+++ b/tools/build/binpatch.c
@@ -1,11 +1,10 @@
-#include <stdio.h>
-#include <stdlib.h>
  * This function will patch binary file
+#include <stdio.h>
+#include <stdlib.h>
+#include <assert.h>
 static char buf[512];
@@ -25,128 +24,121 @@ usage(void)
   printf("<byte1>  - byte 1 of patch\n");
   printf("<byte2>  - byte 1 of patch\n");
   printf("<byte3>  - byte 1 of patch\n");
-  return;
 int
 main(int argc, char **argv)
-  int   c;
+  int    c;
   FILE  *ofp, *ifp;
-  char  patch[4], *end;
-  int   patchLen, tmp, i, off, cnt, patched, len, reloc;
+  char  *patch, *end;
+  int    patchLen, tmp, i, off, cnt, patched, len, reloc;
   /* parse command line options */
-  while ((c = getopt(argc, argv, "h")) >= 0)
-      switch (c)
-	case 'h':
-	  usage();
-	  return 0;
-	default:
-	  usage();
-	  return 1;
-  if(argc < 6)
+  while ((c = getopt(argc, argv, "h")) >= 0) {
+      switch (c) {
+        case 'h':
+          usage();
+          return 0;
+        default:
+          usage();
+          return 1;
+  if(argc < 6) {
       usage();
       return 1;
   /* Let us get offset in file */
   reloc = strtol(argv[3], &end, 0);
-  if(end == argv[3] || off < 0)
+  if (end == argv[3] || reloc < 0) {
       fprintf(stderr, "bad reloc value %s\n", argv[3]);
       return 1;
   off = strtol(argv[4], &end, 0);
-  if(end == argv[4] || off < 0 || off < reloc)
+  if (end == argv[4] || off < 0 || off < reloc) {
       fprintf(stderr, "bad offset value %s\n", argv[4]);
       return 1;
   off -= reloc;
   /* Let us get patch  */
   patchLen = argc - 5;
+  patch = calloc( patchLen, sizeof(char) );
+  assert( patch );
-  for(i=0; i<patchLen; i++)
+  for (i=0; i<patchLen; i++) {
       tmp = strtol(argv[5+i], &end, 0);
-      if(end == argv[4+i] || tmp < 0 || tmp > 0xff)
-	  fprintf(stderr, "bad byte value %s\n", argv[5+i]);
-	  return 1;
-      patch[i] = tmp;
+      if (end == argv[4+i]) {
+          fprintf(stderr, "bad byte value %s\n", argv[5+i]);
+          free(patch);
+          return 1;
+      if (tmp < 0 || tmp > 0xff) {
+          fprintf(stderr, "not a byte value %s\n", argv[5+i]);
+          free(patch);
+          return 1;
+      patch[i] = (tmp & 0xff);
   ifp = fopen(argv[2], "r");
-  if(ifp == NULL)
+  if (ifp == NULL) {
       fprintf(stderr, "unable to open file %s\n", argv[2]);
+      free(patch);
       return 1;
   ofp = fopen(argv[1], "w");
-  if(ofp == NULL)
+  if (ofp == NULL) {
       fprintf(stderr, "unable to open file %s\n", argv[1]);
+      fclose(ifp);
+      free(patch);
       return 1;
   cnt     = 0;
   patched = 0;
-  for(;;)
+  for(;;) {
       len = fread(buf, 1, sizeof(buf), ifp);
-      if(len == 0)
-	  break;
-      if(cnt <= off && (cnt + len) > off)
-	  /* Perform patch */
-	  for(i=0; i<patchLen && (off+i)<(cnt+len); i++)
-	      buf[off-cnt+i] = patch[i];
-	  patched = 1;
-      else if(cnt > off && cnt < (off + patchLen))
-	  for(i=cnt-off; i<patchLen; i++)
-	  patched = 1;
+      if(len == 0) {
+          break;
+      if (cnt <= off && (cnt + len) > off) {
+          /* Perform patch */
+          for(i=0; i<patchLen && (off+i)<(cnt+len); i++)
+              buf[off-cnt+i] = patch[i];
+          patched = 1;
+      } else if(cnt > off && cnt < (off + patchLen)) {
+          for(i=cnt-off; i<patchLen; i++) {
+          patched = 1;
       fwrite(buf, 1, len, ofp);
       cnt += len;
   fclose(ifp);
   fclose(ofp);
+  free(patch);
-  if(!patched)
+  if (!patched) {
       fprintf(stderr, "warning: offset is beyond input file length\n");
       fprintf(stderr, "         no patch is performed\n");
   return 0;
diff --git a/tools/build/cklength.c b/tools/build/cklength.c
index 47675ce..fd6ed26 100644
--- a/tools/build/cklength.c
+++ b/tools/build/cklength.c
@@ -125,8 +125,7 @@ int main(
     opterr = 0;                                 /* we'll report all errors */
     while ((c = getopt(argc, argv, GETOPTARGS)) != EOF)
-        switch (c)
+        switch (c) {
             case 'l':                            /* line length */
                 line_length = atoi( optarg );
                 if ( line_length < 0 || line_length > BUFFER_SIZE )
@@ -150,8 +149,7 @@ int main(
                 showusage = TRUE;
-    if (showusage)
+    if (showusage) {
         (void) fprintf(stderr, "%s", USAGE);
         exit(1);
@@ -160,9 +158,10 @@ int main(
      *  traverse and process the arguments
-    for ( ; argv[optind]; optind++)
+    for ( ; optind < argc; optind++) {
         if (Failed(process(argv[optind])))
             rc = FAILURE;
     return rc;
@@ -268,15 +267,11 @@ error(int error_flag, ...)
     (void) fflush(stderr);
-    if (error_flag & (ERR_FATAL | ERR_ABORT))
-        if (error_flag & ERR_FATAL)
+    if (error_flag & (ERR_FATAL | ERR_ABORT)) {
+        if (error_flag & ERR_FATAL) {
             error(0, "fatal error, exiting");
             exit(local_errno ? local_errno : 1);
-        else
+        } else {
             error(0, "fatal error, aborting");
             abort();
@@ -291,19 +286,18 @@ getparm(char *s,
     long val;
-    if ( ! strchr("0123456789-", *s))
+    if ( !strchr("0123456789-", *s) ) {
         error(ERR_FATAL, "'%s' is not a number", s);
-        return min;
+        /* does not return */
     val = strtol(s, (char **) NULL, 0);
-    if ((val < min) || (val > max))
+    if ((val < min) || (val > max)) {
         if (min == max)
             error(ERR_FATAL, "%s can only be %ld", s, min);
         else
             error(ERR_FATAL, "%s must be between %ld and %ld", msg, min, max);
     return val;
diff --git a/tools/build/eolstrip.c b/tools/build/eolstrip.c
index 859f174..e93b45e 100644
--- a/tools/build/eolstrip.c
+++ b/tools/build/eolstrip.c
@@ -189,13 +189,14 @@ process(char *arg)
      *  Don't count the carriage return.
-    length = strlen( buffer ) - 1;
+    length = 0;
+    if ( *buffer != '\0' )
+      length = strnlen( buffer, BUFFER_SIZE ) - 1;
     if ( buffer[ length ] != '\n' )
       error(ERR_ERRNO|ERR_FATAL, "Line %d too long in %s\n", line_number, arg);
-    while ( isspace( (unsigned char) buffer[ length ] ) )
+    while ( length && isspace( (unsigned char) buffer[ length ] ) )
       buffer[ length-- ] = '\0';
     if ( test_only ) {
@@ -208,8 +209,11 @@ process(char *arg)
   fclose( in );
   if ( !test_only ) {
-    fclose( out );
-    rename( outname, arg );
+    if (out) fclose( out );
+    rc = rename( outname, arg );
+    if ( rc != 0 ) {
+      fprintf( stderr, "Unable to rename %s to %s\n", outname, arg );
   return rc;
diff --git a/tools/build/rtems-bin2c.c b/tools/build/rtems-bin2c.c
index 710c97e..fc0381a 100644
--- a/tools/build/rtems-bin2c.c
+++ b/tools/build/rtems-bin2c.c
@@ -55,13 +55,16 @@ int myfgetc(FILE *f)
 void process(const char *ifname, const char *ofname)
   FILE *ifile, *ocfile, *ohfile;
-  char buf[PATH_MAX], *p;
-  char obasename[PATH_MAX];
-  char ocname[PATH_MAX];
-  char ohname[PATH_MAX];
+  char buf[PATH_MAX+1], *p;
+  char obasename[PATH_MAX+1];
+  char ocname[PATH_MAX+1];
+  char ohname[PATH_MAX+1];
   const char *cp;
   size_t len;
+  ocfile = NULL;
+  ohfile = NULL;
   /* Error check */
   if ( !ifname || !ofname ) {
     fprintf(stderr, "process has NULL filename\n");
@@ -100,75 +103,84 @@ void process(const char *ifname, const char *ofname)
   if ( createC ) {
-  ocfile = fopen(ocname, "wb");
-  if (ocfile == NULL) {
-    fprintf(stderr, "cannot open %s for writing\n", ocname);
-    exit(1);
+    ocfile = fopen(ocname, "wb");
+    if (ocfile == NULL) {
+      fprintf(stderr, "cannot open %s for writing\n", ocname);
+      exit(1);
   if ( createH ) {
-  ohfile = fopen(ohname, "wb");
-  if (ohfile == NULL) {
-    fprintf(stderr, "cannot open %s for writing\n", ohname);
-    exit(1);
+    ohfile = fopen(ohname, "wb");
+    if (ohfile == NULL) {
+      fprintf(stderr, "cannot open %s for writing\n", ohname);
+      exit(1);
   /* find basename */
   char *ifbasename = strdup(ifname);
+  if ( ifbasename == NULL ) {
+    fprintf(stderr, "cannot allocate memory\n" );
+    fclose(ifile);
+    if ( createC ) { fclose(ocfile); }
+    if ( createH ) { fclose(ohfile); }
+    exit(1);
   ifbasename = basename(ifbasename);
   strcpy(buf, ifbasename);
-  for (p = buf; *p != '\0'; ++p)
-    if (!isalnum(*p))
+  for (p = buf; *p != '\0'; ++p) {
+    if (!isalnum((unsigned char)*p)) /* cast to avoid negative indexing */
       *p = '_';
   if ( createC ) {
-  /* print C file header */
-  fprintf(
-    ocfile,
-    "/*\n"
-    " *  Declarations for C structure representing binary file %s\n"
-    " *\n"
-    " *  WARNING: Automatically generated -- do not edit!\n"
-    " */\n"
-    "\n"
-    "#include <sys/types.h>\n"
-    "\n",
-    ifbasename
+    /* print C file header */
+    fprintf(
+      ocfile,
+      "/*\n"
+      " *  Declarations for C structure representing binary file %s\n"
+      " *\n"
+      " *  WARNING: Automatically generated -- do not edit!\n"
+      " */\n"
+      "\n"
+      "#include <sys/types.h>\n"
+      "\n",
+      ifbasename
-  /* print structure */
-  fprintf(
-    ocfile,
-    "%s%sunsigned char %s[] = {\n  ",
-    ((usestatic) ? "static " : ""),
-    ((useconst) ? "const " : ""),
-    buf
-  int c, col = 1;
-  while ((c = myfgetc(ifile)) != EOF) {
-    if (col >= 78 - 6) {
-      fprintf(ocfile, "\n  ");
-      col = 1;
-    fprintf(ocfile, "0x%.2x, ", c);
-    col += 6;
+    /* print structure */
+    fprintf(
+      ocfile,
+      "%s%sunsigned char %s[] = {\n  ",
+      ((usestatic) ? "static " : ""),
+      ((useconst) ? "const " : ""),
+      buf
+    int c, col = 1;
+    while ((c = myfgetc(ifile)) != EOF) {
+      if (col >= 78 - 6) {
+        fprintf(ocfile, "\n  ");
+        col = 1;
+      fprintf(ocfile, "0x%.2x, ", c);
+      col += 6;
-  fprintf(ocfile, "\n};\n");
+    fprintf(ocfile, "\n};\n");
-  /* print sizeof */
-  fprintf(
-    ocfile,
-    "\n"
-    "%s%ssize_t %s_size = sizeof(%s);\n",
-    buf,
-    buf
+    /* print sizeof */
+    fprintf(
+      ocfile,
+      "\n"
+      "%s%ssize_t %s_size = sizeof(%s);\n",
+      buf,
+      buf
   } /* createC */
@@ -176,61 +188,61 @@ void process(const char *ifname, const char *ofname)
   if ( createH ) {
-  /* print H file header */
-  char hbasename[PATH_MAX];
-  char* p;
-  /* Clean up the file name if it is an abs path */
-  strcpy(
-    hbasename,
-    obasename
-  p = hbasename;
-  while (*p != '\0') {
-    if (*p < '0' || *p > 'z')
-      *p = '_';
-    ++p;
-  fprintf(
-    ohfile,
-    "/*\n"
-    " *  Extern declarations for C structure representing binary file %s\n"
-    " *\n"
-    " */\n"
-    "\n"
-    "#ifndef __%s_h\n"
-    "#define __%s_h\n"
-    "\n"
-    "\n",
-    ifbasename,  /* header */
-    hbasename,  /* ifndef */
-    hbasename   /* define */
+    /* print H file header */
+    char hbasename[PATH_MAX];
+    char* p;
+    /* Clean up the file name if it is an abs path */
+    strcpy(
+      hbasename,
+      obasename
+    p = hbasename;
+    while (*p != '\0') {
+      if (*p < '0' || *p > 'z')
+        *p = '_';
+      ++p;
+    fprintf(
+      ohfile,
+      "/*\n"
+      " *  Extern declarations for C structure representing binary file %s\n"
+      " *\n"
+      " */\n"
+      "\n"
+      "#ifndef __%s_h\n"
+      "#define __%s_h\n"
+      "\n"
+      "\n",
+      ifbasename,  /* header */
+      hbasename,  /* ifndef */
+      hbasename   /* define */
-  fprintf(
-    ohfile,
-    "extern %s%sunsigned char %s[];",
-    buf
-  fprintf(
-    ohfile,
-    "\n"
-    "extern %s%ssize_t %s_size;\n",
-    buf
+    fprintf(
+      ohfile,
+      "extern %s%sunsigned char %s[];",
+      buf
+    fprintf(
+      ohfile,
+      "\n"
+      "extern %s%ssize_t %s_size;\n",
+      buf
-  fprintf(
-    ohfile,
-    "\n"
-    "#endif\n"
+    fprintf(
+      ohfile,
+      "\n"
+      "#endif\n"
   } /* createH */
@@ -240,6 +252,7 @@ void process(const char *ifname, const char *ofname)
   fclose(ifile);
+  free(ifbasename);
 void usage(void)
diff --git a/tools/build/unhex.c b/tools/build/unhex.c
index be4465d..7c3bab0 100644
--- a/tools/build/unhex.c
+++ b/tools/build/unhex.c
@@ -36,6 +36,7 @@ usage:    unhex [-va] [ -o file ] [ file [file ... ] ]\n\
 #include <stdarg.h>
 #include "config.h"
@@ -71,10 +72,10 @@ typedef unsigned long u32;
  * Pick out designated bytes
-#define B0(x)       ((x) & 0xff)
-#define B1(x)       B0((x) >> 8)
-#define B2(x)       B0((x) >> 16)
-#define B3(x)       B0((x) >> 24)
+#define B0(x)       (((u32)x) & 0xff)
+#define B1(x)       B0(((u32)x) >> 8)
+#define B2(x)       B0(((u32)x) >> 16)
+#define B3(x)       B0(((u32)x) >> 24)
 typedef struct buffer_rec {
     u32 dl_destaddr;
@@ -119,9 +120,10 @@ int   getnibble(char **p);
 int   getbyte(char **p);
 long  getNbytes(char **p, int n);
 void  badformat(char *s, char *fname, char *msg);
+void  fix_string_from_gets(char *s, size_t max);
-#define get1bytes(p)    ((int) getbyte(p))
-#define get2bytes(p)    ((int) getNbytes(p, 2))
+#define get1bytes(p)    (getbyte(p))
+#define get2bytes(p)    getNbytes(p, 2)
 #define get3bytes(p)    getNbytes(p, 3)
 #define get4bytes(p)    getNbytes(p, 4)
@@ -140,15 +142,15 @@ int main(
   char **argv
-    register int c;
+    int c;
     bool showusage = FALSE;                     /* usage error? */
     int rc = 0;
     FILE *outfp, *infp;
+    long base_long = 0;
      * figure out invocation leaf-name
     if ((progname = strrchr(argv[0], '/')) == (char *) NULL)
         progname = argv[0];
     else
@@ -159,13 +161,18 @@ int main(
      *  Check options and arguments.
     progname = argv[0];
-    while ((c = getopt(argc, argv, "F:a:o:vl")) != EOF)
-        switch (c)
+    while ((c = getopt(argc, argv, "F:a:o:vl")) != EOF) {
+        switch (c) {
             case 'a':                           /* base address */
-                base = stol(optarg);
+                base_long = stol(optarg);
+                if (base_long < 0) {
+                    (void) fprintf(stderr, "%s", USAGE);
+                    (void) fprintf(stderr, "\n*** base is an illegal value\n" );
+                    exit(1);
+                base = (u32) base_long;
                 break;
             case 'l':                           /* linear output */
@@ -187,53 +194,47 @@ int main(
             case '?':
                 showusage = TRUE;
-    if (showusage)
+    if (showusage) {
         exit(1);
-    if (linear && (base != 0))
+    if (linear && (base != 0)) {
         error(0, "-l and -a may not be specified in combination");
         exit(1);
-    if (STREQ(outfilename, "-"))
+    if (STREQ(outfilename, "-")) {
         outfp = stdout;
         outfilename = "stdout";
+    } else if ((outfp = fopen(outfilename, "w")) == (FILE *) NULL) {
+        error(-1, "couldn't open '%s' for output", outfilename);
+        exit(1);
-    else
-        if ((outfp = fopen(outfilename, "w")) == (FILE *) NULL)
-            error(-1, "couldn't open '%s' for output", outfilename);
-            exit(1);
      * Now process the input files (or stdin, if none specified)
-    if (argv[optind] == (char *) NULL)          /* just stdin */
+    if (argc == optind)          /* just stdin */
         exit(unhex(stdin, "stdin", outfp, outfilename));
     else
-        for (; (optarg = argv[optind]); optind++)
-            if (STREQ(optarg, "-"))
+        for (; optind < argc ; optind++) {
+            optarg = argv[optind];
+            if (STREQ(optarg, "-")) {
                 rc += unhex(stdin, "stdin", outfp, outfilename);
-            else
-                if ((infp = fopen(optarg, "r")) == (FILE *) NULL)
+            } else {
+                if ((infp = fopen(optarg, "r")) == (FILE *) NULL) {
                     error(-1, "couldn't open '%s' for input", optarg);
                     exit(1);
                 rc += unhex(infp, optarg, outfp, outfilename);
+                fclose(infp);
+    fclose(outfp);
     return(rc);
@@ -260,8 +261,7 @@ unhex(FILE *ifp,
      *  'stripffs'
-    if (FFfill)
+    if (FFfill) {
         (void) fseek(ofp, 0, 0);
         for (c = FFfill; c > 0; c--)
             (void) fputc(0xFF, ofp);
@@ -271,11 +271,9 @@ unhex(FILE *ifp,
      * Read the first char from file and determine record types
-    if ((c = getc(ifp)) != EOF)
+    if ((c = getc(ifp)) != EOF) {
         ungetc(c, ifp);
-        switch(c)
+        switch(c) {
             case 'S':
                 convert_S_records(ifp, inm, ofp, onm);
                 break;
@@ -292,7 +290,8 @@ unhex(FILE *ifp,
             default:
                 char tmp[2];
-                tmp[0] = c; tmp[1] = 0;
+                tmp[0] = (char) (c & 0x7f);
+                tmp[1] = 0;
                 badformat(tmp, inm, BADFMT);
@@ -317,21 +316,17 @@ convert_Intel_records(
     int incksum;
     int c;
     int rectype;                    /* record type */
-    int len;                        /* data length of current line */
+    long len;                        /* data length of current line */
     u32 addr;
     u32 base_address = 0;
     bool endrecord = FALSE;
     buffer_rec tb;
+    long getBytesStatus;
-    while ( ! endrecord && (fgets(buff, sizeof(buff), ifp)))
+    while ( !endrecord && (fgets(buff, sizeof(buff), ifp)) ) {
         p = &buff[0];
-        if (p[strlen(p)-1] == '\n')                 /* get rid of newline */
-            p[strlen(p)-1] = '\0';
-        if (p[strlen(p)-1] == '\r')                 /* get rid of any CR */
+        fix_string_from_gets(p, sizeof(buff));
         tb.dl_count = 0;
@@ -342,17 +337,17 @@ convert_Intel_records(
         if ((len = getbyte(&p)) == -1)      /* record len */
             badformat(buff, inm, BADLEN);
-        if ((addr = get2bytes(&p)) == -1L)          /* record addr */
+        if ((getBytesStatus = get2bytes(&p)) == -1L)          /* record addr */
             badformat(buff, inm, BADADDR);
+        addr = (u32) getBytesStatus;
         rectype = getbyte(&p);
         cksum = len + B0(addr) + B1(addr) + rectype;
-        switch (rectype)
+        switch (rectype) {
             case 0x00:                  /* normal data record */
-                tb.dl_destaddr = base_address + addr;
+                tb.dl_destaddr = (u32) base_address + addr;
                 while (len--)
                     if ((c = getbyte(&p)) == -1)
@@ -369,15 +364,18 @@ convert_Intel_records(
                 break;
             case 0x02:                  /* new base */
-                if ((base_address = get2bytes(&p)) == -1L)
+                long blong;
+                if ((blong = get2bytes(&p)) == -1L)
                     badformat(buff, inm, BADBASE);
+                base_address = (u32) blong;
                 cksum += B0(base_address) + B1(base_address);
                 base_address <<= 4;
                 break;
             case 0x03:                  /* seg/off execution start address */
-                u32 seg, off;
+                long seg, off;
                 seg = get2bytes(&p);
                 off = get2bytes(&p);
@@ -423,21 +421,16 @@ convert_S_records(
     u8 cksum;
     int incksum;
     int c;
-    u32 addr;
+    long addr;
     buffer_rec tb;
         p = &buff[0];
         tb.dl_count = 0;
@@ -452,8 +445,7 @@ convert_S_records(
         cksum = len;
-        switch (rectype)
             case 0x00:                  /* comment field, ignored */
                 goto write_it;
@@ -476,9 +468,8 @@ convert_S_records(
     doit:
                 cksum += B0(addr) + B1(addr) + B2(addr) + B3(addr);
-                tb.dl_destaddr = addr;
-                while (len--)
+                tb.dl_destaddr = (u32) addr;
+                while (len--) {
                         badformat(buff, inm, BADDATA);
                     cksum += c;
@@ -543,33 +534,29 @@ convert_TI_records(
     bool eol;
     buffer_rec tb;
+    while ( ! endrecord && (fgets(buff, sizeof(buff), ifp))) {
         p = &buff[0];
         tb.dl_count = 0;
         eol = FALSE;
-        while ( ! eol && ! endrecord)
-            switch (*p++)
+        while ( ! eol && ! endrecord) {
+            switch (*p++) {
                 case '9':
                     if (tb.dl_count)
                         write_record(&tb, ofp);
-                    tb.dl_destaddr = get2bytes(&p);
+                    tb.dl_destaddr = (u32) get2bytes(&p);
                     break;
                 case 'B':
                     c = getbyte(&p);
+                    assert( c != -1 );
                     filesum += c;
                     tb.dl_buf[tb.dl_count++] = c;
                     c = getbyte(&p);
                     filesum += c;
                     break;
@@ -596,8 +583,7 @@ void
 write_record(buffer_rec *tb,
              FILE *fp)
-    if ( ! linear)
+    if ( ! linear) {
         if (tb->dl_destaddr < base)
             error(ERR_FATAL, "record at address 0x%x precedes base of 0x%x",
                      tb->dl_destaddr, base);
@@ -615,8 +601,7 @@ getnibble(char **p)
     register int val;
     **p = toupper(**p);
-    switch (**p)
+    switch (**p) {
         case '0': case '1': case '2': case '3': case '4':
         case '5': case '6': case '7': case '8': case '9':
             val = **p - '0';
@@ -651,15 +636,14 @@ long
 getNbytes(char **p,
           int n)
-    int t;
+    long t;
     u32 val = 0;
-    while (n--)
+    while (n--) {
         if ((t = getbyte(p)) == -1)
             return(-1L);
         val <<= 8;
-        val += t;
+        val += (u32) t;
     return(val);
@@ -670,8 +654,10 @@ badformat(char *s,
           char *fname,
           char *msg)
-    if (s[strlen(s)-1] == '\n')             /* get rid of newline */
+    if ( *s != '\0' ) {
+      if (s[strlen(s)-1] == '\n')             /* get rid of newline */
         s[strlen(s)-1] = '\0';
     error(0, "line '%s'::\n\tfrom file '%s'; %s", s, fname, msg);
     exit(1);
@@ -719,17 +705,31 @@ error(int error_flag, ...)
-        else
+        } else {
             abort();
+  size_t len;
+  assert( s );
+  if ( *s == '\0' )
+    return;
+  len = strnlen( s, max );
+  if ( s[len - 1] == '\n')                 /* get rid of newline */
+      s[len - 1] = '\0';
+  if ( s[len - 1] == '\r')                 /* get rid of any CR */
1.9.3
