spsem01 does not terminate on sis (and real leon3 hardware)
Wed Nov 26 00:31:42 UTC 2014
On 11/25/2014 4:54 PM, Joel Sherrill wrote:
> On 11/25/2014 4:49 PM, Jiri Gaisler wrote:
>> On 11/25/2014 11:42 PM, Jiri Gaisler wrote:
>>> spsem01.exe executes correctly on sis and real hardware, but does not terminate.
>>> The program hangs in the bsp_idle_tread() after executing the final rtems_test_exit(0).
>>> Is this the intention of the test?
>> OK, I found a difference in the output compared to the spsem01.scn:
>> @@ -9,7 +9,8 @@
>>  TA02: started with priority 34
>>  TA01: priority 34, holding S0
>>  TA02: priority 34, holding S1
>> -TA02: suspending
>> +TA02: exiting
>>  TA01: priority 36
>>  TA01: exiting
>> In spsem01.scn, task 2 is suspended at the end while in the current
>> executable task 2 reports 'exiting'. Is spsem01.scn just not updated
>> or is there bug here ...?
> I would bet the screen is not up to date. :(
After checking, the screen is a dead match for me.
>> devel mailing list
>> devel at rtems.org
