crypt01 execution time
Wed Nov 26 13:48:15 UTC 2014
On 11/26/2014 01:12 AM, Sebastian Huber wrote:
> On 25/11/14 23:25, Joel Sherrill wrote:
>> How long is this test supposed to run?
>> It takes 4:42 using sis on my computer which is a 2.9 Ghz i7 .
> SIS is a slow simulator.  On Qemu it runs much faster.
>> Is there anything to do? Split it?
> Splitting it up doesn't reduce the overall test time.  The test cases in
> this test are standard test cases.  I am not so fond of removing them,
> but in case the test time is too long for you then you can drop the ones
> with the many rounds.
Chris.. my old test scripts knew some tests ran
quickly and some ran long. The BSP settings could
adjust the timeout period based on the test name.
We shouldn't wait 5 minutes for every test to time
out when 95+% run in milliseconds.
How can we account for this in rtems-tester?
--joel
--joel
