[PATCH 19/20] libcsupport/src/sync.c: Explicitly ignore return status
Wed Nov 26 13:55:27 UTC 2014
On 11/26/2014 01:05 AM, Sebastian Huber wrote:
> On 26/11/14 00:02, Joel Sherrill wrote:
>> From: Josh Oguin<josh.oguin at oarcorp.com>
>> CodeSonar spotted that the return values were being ignored.
>>    cpukit/libcsupport/src/sync.c | 6 ++++--
>>    1 file changed, 4 insertions(+), 2 deletions(-)
>> diff --git a/cpukit/libcsupport/src/sync.c b/cpukit/libcsupport/src/sync.c
>> index b8e5059..0e935ce 100644
>> --- a/cpukit/libcsupport/src/sync.c
>> +++ b/cpukit/libcsupport/src/sync.c
>> @@ -43,8 +43,10 @@ static void sync_wrapper(FILE *f)
>>       *  matter if they succeed.  We are just making a best faith attempt
>>       *  at both and trusting that we were passed a good FILE pointer.
>> -  (void) fsync(fn);
>> -  (void) fdatasync(fn);
>> +  if ( fn != -1 ) {
>> +    (void) fsync(fn);
>> +    (void) fdatasync(fn);
>>    /* iterate over all FILE *'s for this thread */
> This test is superfluous since both functions validate the file
> descriptor.  All other patches look good.
How about I add a debug assert on the status code
and the fileno?
One thing that the analysis of Mars Mission software defects
over the past decade of missions showed is that code with
higher level of debug assertions tended to have fewer problems.
If we are making an assumption, don't just document it,
enforce it in code.
--joel
