[PATCH 05/20] libchip/serial/z85c30.c: Remove redundant assignment
Wed Nov 26 15:12:20 UTC 2014
To be clear, I meant the commit comment. Obviously don't add a source
comment about a deleted line.
On Wed, Nov 26, 2014 at 10:11 AM, Gedare Bloom <gedare at rtems.org> wrote:
> In the future, please add more in the comment to explain for example
> that the same variable initialization happens earlier. I had to go
> look at the code to see why it was OK to delete this line.
> -Gedare
> On Tue, Nov 25, 2014 at 6:02 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> From: Josh Oguin <josh.oguin at oarcorp.com>
>> This was flagged by CodeSonar.
>>  c/src/libchip/serial/z85c30.c | 1 -
>>  1 file changed, 1 deletion(-)
>> diff --git a/c/src/libchip/serial/z85c30.c b/c/src/libchip/serial/z85c30.c
>> index 1f43271..7c55a51 100644
>> --- a/c/src/libchip/serial/z85c30.c
>> +++ b/c/src/libchip/serial/z85c30.c
>> @@ -269,7 +269,6 @@ Z85C30_STATIC void z85c30_init(int minor)
>>    pz85c30Context->ucModemCtrl = SCC_WR5_TX_8_BITS | SCC_WR5_TX_EN;
>> -  ulCtrlPort = Console_Port_Tbl[minor]->ulCtrlPort1;
>>    if ( ulCtrlPort == Console_Port_Tbl[minor]->ulCtrlPort2 ) {
>>       * This is channel A
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
