[PATCH 06/20] libcsupport/src/mount.c: Remove unnecessary operation
Wed Nov 26 15:17:34 UTC 2014
Again, I don't know why this is unecessary. Because str is never used?
On Tue, Nov 25, 2014 at 6:02 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> From: Josh Oguin <josh.oguin at oarcorp.com>
> This was flagged by CodeSonar.
>  cpukit/libcsupport/src/mount.c | 1 -
>  1 file changed, 1 deletion(-)
> diff --git a/cpukit/libcsupport/src/mount.c b/cpukit/libcsupport/src/mount.c
> index d993686..0d66477 100644
> --- a/cpukit/libcsupport/src/mount.c
> +++ b/cpukit/libcsupport/src/mount.c
> @@ -77,7 +77,6 @@ static rtems_filesystem_mount_table_entry_t *alloc_mount_table_entry(
>      memcpy( str, target, target_size );
>      mt_entry->target = str;
> -    str += target_size;
>      mt_entry->mounted = true;
>      mt_entry->mt_fs_root = mt_fs_root;
> 1.9.3
> devel mailing list
> devel at rtems.org
