[PATCH 10/20] dosfs/msdos_file.c: Return an error if it occurs
Wed Nov 26 15:22:21 UTC 2014
Just a general comment that I think it better to have the last line be
the "good" return value, that is, check for an error and return EIO,
otherwise default to return RC_OK. Usually you want to have errors
cause short-circuits, while non-error execution proceeds to the end.
On Tue, Nov 25, 2014 at 6:02 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> From: Josh Oguin <josh.oguin at oarcorp.com>
> CodeSonar flagged this as a case where the return value from fat_sync()
> was not used. Now it is used to return pass/fail to the caller.
>  cpukit/libfs/src/dosfs/msdos_file.c | 5 ++++-
>  1 file changed, 4 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libfs/src/dosfs/msdos_file.c b/cpukit/libfs/src/dosfs/msdos_file.c
> index 7a09272..1d62886 100644
> --- a/cpukit/libfs/src/dosfs/msdos_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_file.c
> @@ -244,5 +244,8 @@ msdos_file_sync(rtems_libio_t *iop)
>      rc = fat_sync(&fs_info->fat);
>      rtems_semaphore_release(fs_info->vol_sema);
> -    return RC_OK;
> +    if ( rc == 0 )
> +      return RC_OK;
> +    rtems_set_errno_and_return_minus_one(EIO);
> 1.9.3
> devel mailing list
> devel at rtems.org
