[PATCH 15/20] chainimpl.h: Add _Assert() to _Chain_Initialize_empty()
Peter Dufault dufault at hda.com
Wed Nov 26 17:32:15 UTC 2014
> On Nov 26, 2014, at 11:40 , Gedare Bloom <gedare at rtems.org> wrote:
> What is the difference between the previous two variants? Would you
> expect to optimize out "Assert_known" in all production code?
"Assert_known_not_NULL" implies that either someone broke the code (the known assertion no longer applies due to a new bug) or that there is memory corruption (a previously asserted non-NULL pointer is now NULL).  This should never be optimized away - you want to know that this has happened, something is really, really wrong.
"Assert_not_NULL" implies laziness (or expedience?) in production code.  The call chain down to the asserting function hasn't been analyzed to know that a passed in pointer is not NULL, and all you want to do today is shutdown if the passed-in pointer is NULL.
Both situations require a fail-safe shutdown but you want to know that the first happened.  The second can be handled in an exception by de-referencing low memory, the first needs to be treated more seriously.
They should be handled differently because the first is so much worse than the second.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
