sis, psim,anf jmr3904 test results
Fri Nov 28 15:20:30 UTC 2014
On 11/28/2014 04:11 AM, Sebastian Huber wrote:
> On 27/11/14 20:43, Joel Sherrill wrote:
>> sparc/sis
>> Passed:   511
>> Failed:     3
>> Timeouts:   7
>> Invalid:    0
>> Total:    521
>> Failures:
>>   heapwalk.exe
>>   dl02.exe
>>   psx13.exe
>> Timeouts:
>>   *** Interactive
>>     termios.exe,  pppd.exe,  capture.exe,  top.exe, monitor.exe,
>> fileio.exe
> Why do you get timeouts for these tests? They should run 20s waiting for
> user input and then exit if nothing happened.
I don't know. Only took 5.9 seconds of computer time
to run by hand and prints "END OF" message.
When run with rtems-tester, it gives the timeout but
looking at top, it doesn't appear to be running anymore.
Time shows at 0:00.17
[1/1] p:0 f:0 t:0 i:0 | sparc/sis: fileio.exe
 > gdb: /users/joel/rtems-4.11-work/tools/bin/sparc-rtems4.11-gdb -i=mi
--nx --quiet ./sparc-rtems4.11/c/sis/testsuites/samples/fileio/fileio.exe
 > Reading symbols from
./sparc-rtems4.11/c/sis/testsuites/samples/fileio/fileio.exe...
 > done.
 > target sim
 > Connected to the simulator.
 > load
 > run
 > Starting program:
/users/joel/rtems-4.11-work/b-sis/sparc-rtems4.11/c/sis/testsuites/samples/fileio/fileio.exe
] *** BEGIN OF TEST FILE I/O ***
] *** TIMEOUT TIMEOUT
Result: timeout    Time: 0:03:02.200058
My guess would be that it is stuck in the first
polling read and not returning.
--joel
