[PATCH 15/20] chainimpl.h: Add _Assert() to _Chain_Initialize_empty()
Peter Dufault dufault at hda.com
Fri Nov 28 20:48:14 UTC 2014
> On Nov 26, 2014, at 13:55 , Gedare Bloom <gedare at rtems.org> wrote:
> I guess the difference is whether the assert implies a local
> assumption (I require this var is not NULL) or a global one (This var
> has been previously verified to be not NULL). It may be worth
> classifying asserts in those two categories.
Yes, it is important that as RTEMS puts assertions in to satisfy automated code verification processes that we don't lose information as to why a given assertion is added.
Do we know that a pointer can't possibly NULL (oh-oh, what happened?  We checked that!) or is it a library function that we need to use and we want to tell the code verifier to shut-up.
The base part of RTEMS needs to protect against the first situation, especially if it is made easier (RSB) to add third part libraries.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
