[PATCH 7/9] bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK
    Sebastian Huber
    Thu Nov 13 09:30:25 UTC 2014
Rename BSP_ARM_A9MPCORE_UARTCLK to ZYNQ_CLOCK_UART since this clock has
nothing to do with the Cortex-A9 MPCore.
 c/src/lib/libbsp/arm/xilinx-zynq/configure.ac        | 8 ++++----
 c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c | 2 +-
 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
index cc95850..a6f16cc 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
@@ -29,10 +29,10 @@ RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[xilinx_zynq_zedboard*],[66666666
 RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[*],[100000000U])
 RTEMS_BSPOPTS_HELP([BSP_ARM_A9MPCORE_PERIPHCLK],[ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz])
-RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_UARTCLK],[xilinx_zynq_zc702*],[50000000UL])
-RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_UARTCLK],[xilinx_zynq_zedboard*],[50000000UL])
-RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_UARTCLK],[*],[50000000UL])
-RTEMS_BSPOPTS_HELP([BSP_ARM_A9MPCORE_UARTCLK],[ARM Cortex-A9 MPCore UART 0 clock frequency in Hz])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[xilinx_zynq_zc702*],[50000000UL])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[xilinx_zynq_zedboard*],[50000000UL])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[*],[50000000UL])
+RTEMS_BSPOPTS_HELP([ZYNQ_CLOCK_UART],[Zynq UART clock frequency in Hz])
 USE_FAST_IDLE=0
 AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_a9_qemu], [USE_FAST_IDLE=1])
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c b/c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c
index 92c9b21..aa96eba 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c
@@ -34,7 +34,7 @@ uint32_t zynq_uart_input_clock(void) __attribute__ ((weak));
-  return BSP_ARM_A9MPCORE_UARTCLK;
+  return ZYNQ_CLOCK_UART;
 static int zynq_cal_baud_rate(uint32_t  baudrate,
1.8.4.5
