RTEMS toolchain for Epiphany?
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Nov 13 21:01:33 UTC 2014
On 11/13/2014 2:46 PM, Hesham Moustafa wrote:
> Hi,
> Thanks a lot for the patches. I will let you know with the status.
> One thing I want someone to confirm about is that I will not be
> able to use/copy any of the GPL licensed code there [1], right?
Not as part of anything that you submit for inclusion in RTEMS.
I don't know how this particular setup works. I can see host
utilities that you would just get from there and I don't know that
we care about those licenses.
And there might be libraries you want to use with your experiments
that is GPL but not submit to RTEMS. That is OK if you manage how
it comes in contact with your own application code.
Please avoid it wherever possible. If there is some run-time library
we need to ask for relicensing, then we can go that round.
> [1] https://github.com/adapteva/epiphany-libs
> Regards,
> Hesham
> On Thu Nov 13 2014 at 6:47:28 PM Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> Hi
> I couldn't get gdb og gcc to build even for epiphany-elf but I did
> include patch that I think is all that is needed for RTEMS.
> I did manage to build binutils from their repo for both elf
> and rtems variants.
> At least it is a starting point. You can work with their
> community to get their tools built as epiphany-elf and
> then just change the target.
> --joel
> On 11/13/2014 12:22 PM, Hesham Moustafa wrote:
>> On Thu Nov 13 2014 at 5:58:25 PM Joel Sherrill
>> On November 13, 2014 11:56:32 AM CST, Hesham Moustafa
>> <heshamelmatary at gmail.com <mailto:heshamelmatary at gmail.com>>
>> wrote:
>> >Hi,
>> >I want to let you know that I found their main repos [1] Can
>> I start
>> >from there? Imitating what has been done with OpenRISC?
>> Basically. Except you only need their repos for binutils and
>> gdb. We use GCC and Newlib from upstream.
>> Great, I am waiting for these patches.
>> I have binutils patches
>> >Regards,
>> >Hesham
>> >On Thu Nov 13 2014 at 3:29:14 PM Hesham Moustafa
>> wrote:
>> >On Thu Nov 13 2014 at 2:59:33 PM Joel Sherrill
>> >On 11/13/2014 8:07 AM, Joel Sherrill wrote:
>> >> On November 13, 2014 6:30:48 AM CST, Hesham Moustafa
>> wrote:
>> >>> Hi all,
>> >>> I want to ask about the status of RTEMS toolchain for
>> Epiphany
>> >>> architecture. I think Joel mentioned that there are some
>> previous
>> >>> support for it; and if yes, does the toolchain need some
>> additional
>> >>> work?
>> >> To give you a quick answer, I emailed the people who did
>> the port.
>> >There apparently is a github repo with some of it and some
>> is merged. I
>> >will dig through the emails and post the proper links.
>> >> One issue they mentioned was that the gdb port had many
>> core/thread
>> >support that made it more than a simple port.
>> >From Jeremy Bennett:
>> >> piphany tool chain development runs on quite a tight
>> budget, and its
>> >> GDB implementation is quite complex (it has to pretend
>> cores are
>> >> threads, when they don't completely share an address
>> space). So we
>> >> haven't had the effort to devote to upstreaming. And we were
>> >> reluctant to push the simulator upstream without a GDB
>> implementation
>> >> to go with it. You can of course access the code here:
>> >> https://github.com/adapteva/epiphany-binutils-gdb
>> >> Epiphany GDB is still in quite substantial flux, due to
>> the need to
>> >> support the Eclipse multicore visualizer with asynchronous and
>> >> non-stop support.
>> >The upstream gcc and newlib are OK. But since binutils and
>> gdb are
>> >now in a single repo, it will need to come from the github
>> site until
>> >it is merged upstream. And obviously patches just need to go
>> upstream
>> >to whereever the code is. :)
>> >Jeremy also encouraged you to openly discuss things on their
>> forums.
>> >He thought you would get good insight and advice there. And
>> I don't
>> >doubt that.
>> >Thank you, I will.
>> >If it is a relatively low volume place, I may track it. But
>> my email
>> >volume
>> >is already high and I don't have time to poke around on a
>> bulletin
>> >board.
>> >> It will not have RTEMS as a target but that shouldn't be
>> hard to
>> >address once we know where the master binutils, GCC, Newlib,
>> and gdb
>> >are.
>> >So do you want me to try to build a toolchain and get you
>> some starting
>> >patches?
>> >Sure that will definitely help as a starting point. And if
>> you are so
>> >busy, you can just drop me HOWTO instructions.
>> >> Then you are porting.
>> >>> Regards,
>> >>> Hesham
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org <mailto:devel at rtems.org>
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >Joel Sherrill, Ph.D. Director of Research &
>> Development
>> >joel.sherrill at OARcorp.com
>> <mailto:joel.sherrill at OARcorp.com> On-Line
>> Applications Research
>> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> >Support Available (256) 722-9985
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141113/10888147/attachment-0002.html>
