[PATCH 2/4] sys/mman.h: New file. Clean up and add supporting stubs
Thomas Kim thomas73.kim at gmail.com
Fri Nov 21 10:06:32 UTC 2014
Dear Joel,
I am sorry. please let me know how to download these patch codes(source
code, makefile.am, pre-install.am, etc) for mmap implementation.
At this time, I am modified makefile.am for integrating mmp source code in
 gsoc2011-rtems-mmu-support-project. but, I was failed in building process.
Please advise me.
Best Regards.
Thomas Kim
2014-11-20 11:37 GMT+09:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On November 19, 2014 8:31:46 PM CST, Gedare Bloom <gedare at rtems.org>
> wrote:
> >OK great
> I have an updated version of the patch. Something wasn't right with the
> mskefile that showed up later. Not sure how it built before. :(
> >On Wed, Nov 19, 2014 at 5:04 PM, Joel Sherrill
> ><joel.sherrill at oarcorp.com> wrote:
> >> On 11/19/2014 2:55 PM, Gedare Bloom wrote:
> >>> Is this the same one that Chris has had in use before? (I think that
> >>> is who had one in use..)
> >> Yes. You wanted it in rtems to avoid me having to add a prototype to
> >a file
> >> to avoid a warning.
> >> I didn't integrate his implementation but only his .h file and stubs.
> >His
> >> implementation will need the addition of tests and code in
> >confdefs.h.
> >> --joel
> >>> -Gedare
> >>> On Wed, Nov 19, 2014 at 2:59 PM, Joel Sherrill
> >>>>         * Makefile.am updated and preinstall.am regenerated.
> >>>>         * mprotect.c had a prototype removed now that we have
> >mman.h
> >>>>         * mmap.c, munmap.c: New stub files.
> >>>>  cpukit/posix/Makefile.am        |   5 ++
> >>>>  cpukit/posix/include/sys/mman.h | 189
> >>>>  cpukit/posix/preinstall.am      |   9 ++
> >>>>  cpukit/posix/src/mmap.c         |  26 ++++++
> >>>>  cpukit/posix/src/mprotect.c     |  10 +--
> >>>>  cpukit/posix/src/munmap.c       |  30 +++++++
> >>>>  6 files changed, 261 insertions(+), 8 deletions(-)
> >>>>  create mode 100644 cpukit/posix/include/sys/mman.h
> >>>>  create mode 100644 cpukit/posix/src/mmap.c
> >>>>  create mode 100644 cpukit/posix/src/munmap.c
> >>>> diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
> >>>> index 346b65a..b3be07c 100644
> >>>> --- a/cpukit/posix/Makefile.am
> >>>> +++ b/cpukit/posix/Makefile.am
> >>>> @@ -21,6 +21,9 @@ include_rtems_posix_HEADERS +=
> >include/rtems/posix/keyimpl.h
> >>>>  include_rtems_posix_HEADERS += include/rtems/posix/config.h
> >>>>  include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
> >>>> +include_sysdir = $(includedir)/sys
> >>>> +include_sys_HEADERS = include/sys/mman.h
> >>>>  if HAS_PTHREADS
> >>>>  # include
> >>>>  include_HEADERS = include/aio.h
> >>>> @@ -91,7 +94,9 @@ libposix_a_SOURCES += src/cond.c
> >src/condattrdestroy.c \
> >>>>      src/condtimedwait.c src/condwait.c src/condwaitsupp.c
> >src/condget.c
> >>>>  ## MEMORY_C_FILES
> >>>> +libposix_a_SOURCES += src/mmap.c
> >>>>  libposix_a_SOURCES += src/mprotect.c
> >>>> +libposix_a_SOURCES += src/munmap.c
> >>>>  ## MESSAGE_QUEUE_C_FILES
> >>>>  libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
> >>>> diff --git a/cpukit/posix/include/sys/mman.h
> >b/cpukit/posix/include/sys/mman.h
> >>>> new file mode 100644
> >>>> index 0000000..ddf34cc
> >>>> --- /dev/null
> >>>> +++ b/cpukit/posix/include/sys/mman.h
> >>>> @@ -0,0 +1,189 @@
> >>>> +/*     $NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $
> >>>> + * Copyright (c) 1982, 1986, 1993
> >>>> + *     The Regents of the University of California.  All rights
> >reserved.
> >>>> + * Redistribution and use in source and binary forms, with or
> >without
> >>>> + * modification, are permitted provided that the following
> >conditions
> >>>> + * are met:
> >>>> + * 1. Redistributions of source code must retain the above
> >copyright
> >>>> + *    notice, this list of conditions and the following
> >disclaimer.
> >>>> + * 2. Redistributions in binary form must reproduce the above
> >copyright
> >>>> + *    notice, this list of conditions and the following disclaimer
> >in the
> >>>> + *    documentation and/or other materials provided with the
> >distribution.
> >>>> + * 3. Neither the name of the University nor the names of its
> >contributors
> >>>> + *    may be used to endorse or promote products derived from this
> >software
> >>>> + *    without specific prior written permission.
> >>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS
> >IS'' AND
> >>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> >TO, THE
> >>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> >PARTICULAR PURPOSE
> >>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS
> >BE LIABLE
> >>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >CONSEQUENTIAL
> >>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >SUBSTITUTE GOODS
> >>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> >INTERRUPTION)
> >>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> >CONTRACT, STRICT
> >>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> >IN ANY WAY
> >>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> >POSSIBILITY OF
> >>>> + * SUCH DAMAGE.
> >>>> + *     @(#)mman.h      8.2 (Berkeley) 1/9/95
> >>>> +#ifndef _SYS_MMAN_H_
> >>>> +#define _SYS_MMAN_H_
> >>>> +#ifdef __rtems__
> >>>> +#include <inttypes.h>
> >>>> +#include <stddef.h>
> >>>> +#include <sys/types.h>
> >>>> +#else /* __rtems__ */
> >>>> +#include <sys/featuretest.h>
> >>>> +#include <machine/ansi.h>
> >>>> +#ifdef _BSD_SIZE_T_
> >>>> +typedef        _BSD_SIZE_T_    size_t;
> >>>> +#undef _BSD_SIZE_T_
> >>>> +#endif
> >>>> +#include <sys/ansi.h>
> >>>> +#ifndef        mode_t
> >>>> +typedef        __mode_t        mode_t;
> >>>> +#define        mode_t          __mode_t
> >>>> +#endif
> >>>> +#ifndef        off_t
> >>>> +typedef        __off_t         off_t;          /* file offset */
> >>>> +#define        off_t           __off_t
> >>>> +#endif
> >>>> +#endif /* __rtems__ */
> >>>> + * Protections are chosen from these bits, or-ed together
> >>>> +#define        PROT_NONE       0x00    /* no permissions */
> >>>> +#define        PROT_READ       0x01    /* pages can be read */
> >>>> +#define        PROT_WRITE      0x02    /* pages can be written */
> >>>> +#define        PROT_EXEC       0x04    /* pages can be executed */
> >>>> + * Flags contain sharing type and options.
> >>>> + * Sharing types; choose one.
> >>>> +#define        MAP_SHARED      0x0001  /* share changes */
> >>>> +#define        MAP_PRIVATE     0x0002  /* changes are private */
> >>>> +#ifdef _KERNEL
> >>>> + * Deprecated flag; these are treated as MAP_PRIVATE internally by
> >>>> + * the kernel.
> >>>> +#define        MAP_COPY        0x0004  /* "copy" region at mmap
> >time */
> >>>> +#endif
> >>>> + * Other flags
> >>>> +#define        MAP_FIXED        0x0010 /* map addr must be exactly
> >as requested */
> >>>> +#define        MAP_RENAME       0x0020 /* Sun: rename private
> >pages to file */
> >>>> +#define        MAP_NORESERVE    0x0040 /* Sun: don't reserve
> >needed swap area */
> >>>> +#define        MAP_INHERIT      0x0080 /* region is retained after
> >exec */
> >>>> +#define        MAP_HASSEMAPHORE 0x0200 /* region may contain
> >semaphores */
> >>>> +#define        MAP_TRYFIXED     0x0400 /* attempt hint address,
> >even within break */
> >>>> +#define        MAP_WIRED        0x0800 /* mlock() mapping when it
> >is established */
> >>>> + * Mapping type
> >>>> +#define        MAP_FILE        0x0000  /* map from file (default)
> >>>> +#define        MAP_ANON        0x1000  /* allocated from memory,
> >swap space */
> >>>> + * Alignment (expressed in log2).  Must be >= log2(PAGE_SIZE) and
> >>>> + * < # bits in a pointer (26 (acorn26), 32 or 64).
> >>>> +#define        MAP_ALIGNED(n)          ((n) <<
> >MAP_ALIGNMENT_SHIFT)
> >>>> +#define        MAP_ALIGNMENT_SHIFT     24
> >>>> +#define        MAP_ALIGNMENT_MASK      MAP_ALIGNED(0xff)
> >>>> +#define        MAP_ALIGNMENT_64KB      MAP_ALIGNED(16) /* 2^16 */
> >>>> +#define        MAP_ALIGNMENT_16MB      MAP_ALIGNED(24) /* 2^24 */
> >>>> +#define        MAP_ALIGNMENT_4GB       MAP_ALIGNED(32) /* 2^32 */
> >>>> +#define        MAP_ALIGNMENT_1TB       MAP_ALIGNED(40) /* 2^40 */
> >>>> +#define        MAP_ALIGNMENT_256TB     MAP_ALIGNED(48) /* 2^48 */
> >>>> +#define        MAP_ALIGNMENT_64PB      MAP_ALIGNED(56) /* 2^56 */
> >>>> + * Error indicator returned by mmap(2)
> >>>> +#define        MAP_FAILED      ((void *) -1)   /* mmap() failed */
> >>>> + * Flags to msync
> >>>> +#define        MS_ASYNC        0x01    /* perform asynchronous
> >writes */
> >>>> +#define        MS_INVALIDATE   0x02    /* invalidate cached data
> >>>> +#define        MS_SYNC         0x04    /* perform synchronous
> >writes */
> >>>> + * Flags to mlockall
> >>>> +#define        MCL_CURRENT     0x01    /* lock all pages currently
> >mapped */
> >>>> +#define        MCL_FUTURE      0x02    /* lock all pages mapped in
> >the future */
> >>>> +#if defined(_NETBSD_SOURCE)
> >>>> + * Advice to madvise
> >>>> +#define        MADV_NORMAL     0       /* no further special
> >treatment */
> >>>> +#define        MADV_RANDOM     1       /* expect random page
> >references */
> >>>> +#define        MADV_SEQUENTIAL 2       /* expect sequential page
> >references */
> >>>> +#define        MADV_WILLNEED   3       /* will need these pages */
> >>>> +#define        MADV_DONTNEED   4       /* dont need these pages */
> >>>> +#define        MADV_SPACEAVAIL 5       /* insure that resources
> >are reserved */
> >>>> +#define        MADV_FREE       6       /* pages are empty, free
> >them */
> >>>> + * Flags to minherit
> >>>> +#define        MAP_INHERIT_SHARE       0       /* share with child
> >>>> +#define        MAP_INHERIT_COPY        1       /* copy into child
> >>>> +#define        MAP_INHERIT_NONE        2       /* absent from
> >child */
> >>>> +#define        MAP_INHERIT_DONATE_COPY 3       /* copy and delete
> >-- not
> >>>> +                                          implemented in UVM */
> >>>> +#define        MAP_INHERIT_DEFAULT     MAP_INHERIT_COPY
> >>>> +#endif
> >>>> +#ifndef _KERNEL
> >>>> +#include <sys/cdefs.h>
> >>>> +__BEGIN_DECLS
> >>>> +void   *mmap(void *, size_t, int, int, int, off_t);
> >>>> +int    munmap(void *, size_t);
> >>>> +int    mprotect(void *, size_t, int);
> >>>> +#ifndef __LIBC12_SOURCE__
> >>>> +#if defined(__rtems__)
> >>>> +int    msync(void *, size_t, int);
> >>>> +#else
> >>>> +int    msync(void *, size_t, int) __RENAME(__msync13);
> >>>> +#endif
> >>>> +#endif
> >>>> +int    mlock(const void *, size_t);
> >>>> +int    munlock(const void *, size_t);
> >>>> +int    mlockall(int);
> >>>> +int    munlockall(void);
> >>>> +int    madvise(void *, size_t, int);
> >>>> +int    mincore(void *, size_t, char *);
> >>>> +int    minherit(void *, size_t, int);
> >>>> +#endif
> >>>> +__END_DECLS
> >>>> +#endif /* !_KERNEL */
> >>>> +#endif /* !_SYS_MMAN_H_ */
> >>>> diff --git a/cpukit/posix/preinstall.am
> >b/cpukit/posix/preinstall.am
> >>>> index 6e3f2a2..1b65213 100644
> >>>> --- a/cpukit/posix/preinstall.am
> >>>> +++ b/cpukit/posix/preinstall.am
> >>>> @@ -43,6 +43,15 @@ $(PROJECT_INCLUDE)/rtems/posix/posixapi.h:
> >include/rtems/posix/posixapi.h $(PROJ
> >>>>         $(INSTALL_DATA) $<
> >>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
> >>>> +$(PROJECT_INCLUDE)/sys/$(dirstamp):
> >>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/sys
> >>>> +       @: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
> >>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/sys/$(dirstamp)
> >>>> +$(PROJECT_INCLUDE)/sys/mman.h: include/sys/mman.h
> >>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/mman.h
> >>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/mman.h
> >>>>  if HAS_PTHREADS
> >>>>  $(PROJECT_INCLUDE)/aio.h: include/aio.h
> >$(PROJECT_INCLUDE)/$(dirstamp)
> >>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/aio.h
> >>>> diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
> >>>> index 0000000..2798326
> >>>> --- /dev/null
> >>>> +++ b/cpukit/posix/src/mmap.c
> >>>> @@ -0,0 +1,26 @@
> >>>> + * @file
> >>>> + *  COPYRIGHT (c) 2014.
> >>>> + *  On-Line Applications Research Corporation (OAR).
> >>>> + *  The license and distribution terms for this file may be
> >>>> + *  found in the file LICENSE in this distribution or at
> >>>> + *  http://www.rtems.org/license/LICENSE.
> >>>> +#if HAVE_CONFIG_H
> >>>> +#include "config.h"
> >>>> +#endif
> >>>> +#include <sys/mman.h>
> >>>> +int munmap(
> >>>> +  void   *addr __attribute__((unused)),
> >>>> +  size_t  length __attribute__((unused))
> >>>> +  return -1;
> >>>> diff --git a/cpukit/posix/src/mprotect.c
> >b/cpukit/posix/src/mprotect.c
> >>>> index 51b565e..94bd316 100644
> >>>> --- a/cpukit/posix/src/mprotect.c
> >>>> +++ b/cpukit/posix/src/mprotect.c
> >>>> @@ -28,16 +28,10 @@
> >>>>  #endif
> >>>>  #include <unistd.h>
> >>>> - * RTEMS does not have <sys/mman.h> so we need a prototype here to
> >>>> - * avoid warnings.
> >>>> -int mprotect( const void *, size_t, int );
> >>>>  int mprotect(
> >>>> -  const void *addr __attribute__((unused)),
> >>>>    size_t len __attribute__((unused)),
> >>>>    int prot __attribute__((unused)) )
> >>>> diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
> >>>> index 0000000..3ebb2f4
> >>>> --- /dev/null
> >>>> +++ b/cpukit/posix/src/munmap.c
> >>>> @@ -0,0 +1,30 @@
> >>>> + * @file
> >>>> +#if HAVE_CONFIG_H
> >>>> +#endif
> >>>> +void *mmap(
> >>>> +  size_t  lenhth __attribute__((unused)),
> >>>> +  int     prot __attribute__((unused)),
> >>>> +  int     flags __attribute__((unused)),
> >>>> +  int     fildes __attribute__((unused)),
> >>>> +  off_t   off
> >>>> +  return NULL;
> >>>> 1.9.3
> >>>> _______________________________________________
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> >> Joel Sherrill, Ph.D.             Director of Research & Development
> >> joel.sherrill at OARcorp.com        On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141121/4b5a6b84/attachment-0002.html>
