[PATCH 2/2] score: Return heap stats via _Heap_Get_information
    Sebastian Huber
    Thu Nov 27 12:26:36 UTC 2014
Print out heap statistics via the MALLOC and WKSPACE shell commands.
 cpukit/libmisc/shell/internal.h         |  7 ++++--
 cpukit/libmisc/shell/main_mallocinfo.c  |  1 +
 cpukit/libmisc/shell/main_wkspaceinfo.c |  3 ++-
 cpukit/libmisc/shell/print_heapinfo.c   | 39 +++++++++++++++++++++++++++------
 cpukit/score/include/rtems/score/heap.h |  3 ++-
 cpukit/score/src/heapgetinfo.c          |  1 +
 doc/shell/memory.t                      | 31 +++++++++++++++++++++-----
 7 files changed, 68 insertions(+), 17 deletions(-)
diff --git a/cpukit/libmisc/shell/internal.h b/cpukit/libmisc/shell/internal.h
index 0187e5f..8ec2da0 100644
--- a/cpukit/libmisc/shell/internal.h
+++ b/cpukit/libmisc/shell/internal.h
@@ -32,10 +32,13 @@ int rtems_shell_execute_cmd(const char *cmd, int argc, char *argv[]);
 extern void rtems_shell_register_monitor_commands(void);
 extern void rtems_shell_print_heap_info(
-  const char       *c,
-  Heap_Information *h
+  const char             *c,
+  const Heap_Information *h
+extern void rtems_shell_print_heap_stats(
+  const Heap_Statistics *s
 extern void rtems_shell_print_unified_work_area_message(void);
diff --git a/cpukit/libmisc/shell/main_mallocinfo.c b/cpukit/libmisc/shell/main_mallocinfo.c
index 54c602a..43e9883 100644
--- a/cpukit/libmisc/shell/main_mallocinfo.c
+++ b/cpukit/libmisc/shell/main_mallocinfo.c
@@ -37,6 +37,7 @@ static int rtems_shell_main_malloc_info(
     malloc_info( &info );
     rtems_shell_print_heap_info( "free", &info.Free );
     rtems_shell_print_heap_info( "used", &info.Used );
+    rtems_shell_print_heap_stats( &info.Stats );
   return 0;
diff --git a/cpukit/libmisc/shell/main_wkspaceinfo.c b/cpukit/libmisc/shell/main_wkspaceinfo.c
index f4f6f4d..a990652 100644
--- a/cpukit/libmisc/shell/main_wkspaceinfo.c
+++ b/cpukit/libmisc/shell/main_wkspaceinfo.c
@@ -24,7 +24,7 @@
-  printf( "\nC Program Heap and RTEMS Workspace are %s.\n",
+  printf( "C Program Heap and RTEMS Workspace are %s.\n",
     rtems_configuration_get_unified_work_area() ? "the same" : "separate"
@@ -41,6 +41,7 @@ static int rtems_shell_main_wkspace_info(
   _Protected_heap_Get_information( &_Workspace_Area, &info );
   return 0;
diff --git a/cpukit/libmisc/shell/print_heapinfo.c b/cpukit/libmisc/shell/print_heapinfo.c
index 12bc363..4ac9c96 100644
--- a/cpukit/libmisc/shell/print_heapinfo.c
+++ b/cpukit/libmisc/shell/print_heapinfo.c
@@ -14,22 +14,47 @@
 #endif
 #include <inttypes.h>
+#include <stdio.h>
-#include <rtems.h>
-#include <rtems/shell.h>
 #include "internal.h"
-  const char       *c,
+  const char             *c,
   printf(
-    "Number of %s blocks: %" PRId32 "\n"
-    "Largest %s block:    %" PRId32 "\n"
-    "Total bytes %s:      %" PRId32 "\n",
+    "Number of %s blocks:                    %12" PRId32 "\n"
+    "Largest %s block:                       %12" PRId32 "\n"
+    "Total bytes %s:                         %12" PRId32 "\n",
     c, h->number,
     c, h->largest,
     c, h->total
+void rtems_shell_print_heap_stats(
+  printf(
+    "Instance number:                          %12" PRIu32 "\n"
+    "Size of the allocatable area in bytes:    %12" PRIuPTR "\n"
+    "Minimum free size ever in bytes:          %12" PRIuPTR "\n"
+    "Maximum number of free blocks ever:       %12" PRIu32 "\n"
+    "Maximum number of blocks searched ever:   %12" PRIu32 "\n"
+    "Total number of successful allocations:   %12" PRIu32 "\n"
+    "Total number of searches ever:            %12" PRIu32 "\n"
+    "Total number of successful calls to free: %12" PRIu32 "\n"
+    "Total number of successful resizes:       %12" PRIu32 "\n",
+    s->instance,
+    s->size,
+    s->min_free_size,
+    s->max_free_blocks,
+    s->max_search,
+    s->allocs,
+    s->searches,
+    s->frees,
+    s->resizes
diff --git a/cpukit/score/include/rtems/score/heap.h b/cpukit/score/include/rtems/score/heap.h
index 0120a2b..6042a13 100644
--- a/cpukit/score/include/rtems/score/heap.h
+++ b/cpukit/score/include/rtems/score/heap.h
@@ -313,7 +313,7 @@ typedef struct {
   uint32_t searches;
-   * @brief Total number of suceessful calls to free.
+   * @brief Total number of successful calls to free.
   uint32_t frees;
@@ -366,6 +366,7 @@ typedef struct {
 typedef struct {
   Heap_Information Free;
   Heap_Information Used;
+  Heap_Statistics Stats;
 } Heap_Information_block;
diff --git a/cpukit/score/src/heapgetinfo.c b/cpukit/score/src/heapgetinfo.c
index 8565be4..287d269 100644
--- a/cpukit/score/src/heapgetinfo.c
+++ b/cpukit/score/src/heapgetinfo.c
@@ -50,4 +50,5 @@ void _Heap_Get_information(
   memset( the_info, 0, sizeof(*the_info) );
   _Heap_Protection_free_all_delayed_blocks( the_heap );
   _Heap_Iterate( the_heap, _Heap_Get_information_visitor, the_info );
+  the_info->Stats = the_heap->stats;
diff --git a/doc/shell/memory.t b/doc/shell/memory.t
index 0fdf1f8..e8363ae 100644
--- a/doc/shell/memory.t
+++ b/doc/shell/memory.t
@@ -546,6 +546,15 @@ to the command.  This includes the following information:
 @item Number of used blocks
 @item Largest used block
 @item Total bytes used
+ at item Instance number
+ at item Size of the allocatable area in bytes
+ at item Minimum free size ever in bytes
+ at item Maximum number of free blocks ever
+ at item Maximum number of blocks searched ever
+ at item Total number of successful allocations
+ at item Total number of searches ever
+ at item Total number of successful calls to free
+ at item Total number of successful resizes
 @end itemize
 When the subcommand @code{walk} is specified, then a heap walk will be
@@ -565,12 +574,22 @@ The following is an example of how to use the @code{malloc} command.
 @example
 SHLL [/] $ malloc
-Number of free blocks: 3
-Largest free block:    3626672
-Total bytes free:      3627768
-Number of used blocks: 130
-Largest used block:    1048
-Total bytes used:      10136
+C Program Heap and RTEMS Workspace are the same.
+Number of free blocks:                              14
+Largest free block:                          266157192
+Total bytes free:                            266164928
+Number of used blocks:                             167
+Largest used block:                              16424
+Total bytes used:                                90888
+Instance number:                                     0
+Size of the allocatable area in bytes:       266255816
+Minimum free size ever in bytes:             266156136
+Maximum number of free blocks ever:                 15
+Maximum number of blocks searched ever:             15
+Total number of successful allocations:            186
+Total number of searches ever:                     186
+Total number of successful calls to free:           19
+Total number of successful resizes:                  0
 SHLL [/] $ malloc walk
 malloc walk
 PASS[0]: page size 8, min block size 48
1.8.4.5
