Problem to resolve "sqrt" symbol from shell/main_ping.c for lpc17xx_ea_ram BSP
Thu Oct 2 03:34:25 UTC 2014
On 2/10/2014 11:57 am, Pavel Pisa wrote:
> Hello all,
> when have tested recent master branch (fbe59f7c6756edc2952b13167893b85fe6e7aecb)
> build configured for lpc17xx_ea_ram BSP, I am experiencing next error for my
> code with networking enabled. It seems to be related to add of ping command.
> Even addition of -lm to my LDFLAGS does not help
> GCC call from OMK based makefile
> arm-rtems4.11-gcc --pipe -B/opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/lib/ \
>    -specs bsp_specs -qrtems -march=armv7-m -mthumb \
>    -I /home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/omk-template/_compiled/lpc17xx_ea_ram/include \
>    -Wall -O2 -g init.o task_1.o \
>    -L/home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/omk-template/_compiled/lpc17xx_ea_ram/lib \
>    -lbar -lnfs -lm  -o /home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/omk-template/_compiled/lpc17xx_ea_ram/bin/appnet
> Error reported
> /opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/lib/librtemscpu.a(libshell_a-main_ping.o): In function `g_finish':
> /home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/rtems/arm-rtems4.11/c/lpc17xx_ea_ram/cpukit/libmisc/../../../../../../../../git/rtems/c/src/../../cpukit/libmisc/shell/main_ping.c:1642:
> undefined reference to `sqrt'
> collect2: error: ld returned 1 exit status
> make[3]: *** [/home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/omk-template/_compiled/lpc17xx_ea_ram/bin/appnet] Error 1
> make[2]: *** [binary-pass-this-dir] Error 2
> make[1]: *** [binary-pass-appnet-subdir] Error 2
> make: *** [binary-pass] Error 2
> I have investigated how collect is called and even tried to modify it by adding libm.a
> /usr/arm-rtems4.11/gcc/4.9.1/bin/../libexec/gcc/arm-rtems4.11/4.9.1/collect2 \
>    -dc -dp -N -o /home/pi/repo/rtems/build/arm-lpc17xx_ea_ram/omk-template/_compiled/lpc17xx_ea_ram/bin/appnet \
>    /opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/lib/start.o \
>    /usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/thumb/armv7-m/crti.o \
>    /usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/thumb/armv7-m/crtbegin.o \
>    -e _start \
>    -L/usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/thumb/armv7-m \
>    -L/usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/../../../../arm-rtems4.11/lib/thumb/armv7-m \
>    -L/opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/lib -L/usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1 \
>    -L/usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc \
>    -L/usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/../../../../arm-rtems4.11/lib \
>     init.o task_1.o -lbar -lnfs \
>     /usr/arm-rtems4.11/lib/thumb/armv7-m/libm.a \
>     --start-group -lgcc --start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group \
>     -T /opt/rtems4.11/arm-rtems4.11/lpc17xx_ea_ram/lib/linkcmds --end-group \
>     /usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/thumb/armv7-m/crtend.o \
>     /usr/arm-rtems4.11/gcc/4.9.1/bin/../lib/gcc/arm-rtems4.11/4.9.1/thumb/armv7-m/crtn.o
> What seems to be problem cause is the fact, that bsp_specs adds libraries
> group including librtemscpu.a after libm.a. Because libm.a is not in the group
> then repeated search for sqrt() is not run after ping inclussion.
> Adding libm at the end of manually crafted collect2 line helps
> Sequence of link specification
> %{qrtems: --start-group  -lrtemsbsp -lrtemscpu  -lc -lgcc --end-group %{!qn
> is compiled in GCC driver /usr/arm-rtems4.11/gcc/4.9.1/bin/gcc, which is
> defined in GCC sources
> gcc-4.9.1/gcc/config/rtems.h
> #undef LIB_SPEC
> #define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
> "%{!nostdlib: %{qrtems: --start-group \
>   -lrtemsbsp -lrtemscpu \
>   -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
> If float funtions support is needed by rtems core libraries then
> "-lm" or "libm.a" has to be included in this define.
This is a great summary of the issue. We really cannot change this as it
stands until after 4.11 is released.
> The problem is caused by "ping" statistic/standard deviation computation
> in there
It is and it was a mistake on my part. My zynq testing has a NEON and
-lm was being linked so I was not aware of the issue.
> 	if (nreceived && timing) {
> 		double n = nreceived + nrepeats;
> 		double avg = tsum / n;
> 		double vari = tsumsq / n - avg * avg;
> 		(void)printf(
> 		    "round-trip min/avg/max/stddev = %.3f/%.3f/%.3f/%.3f ms\n",
> 		    tmin, avg, tmax, sqrt(vari));
> I expect that problem can be hidden on hardware floating point
> targets because sqrt is inlined/translated directly to FPU
> instructions.
> If the politics is not to require/pull in FPU support for core
> libraries then I suggest to replace whole statistic computation
> by fixed point/fraction based code or at least use integer/long based
> sqrt replacement.
Or just remove the need for the stddev. Is it really needed ?
> May it be that problem is specific to my local toolchain build
> and makefiles used but my guess is that it is generic.
No it is not and it is on my list of things to clean up. There is
another unrelated issue in the ping I also wanted to look at.
