[rtems commit] libmisc/shell: Remove the need for -lm when linking from the ping command.
Sat Oct 4 00:04:15 UTC 2014
On Fri, Oct 3, 2014 at 6:48 PM, Chris Johns <chrisj at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    56ed56a641b69be42f5a38046307b33096014c84
> Changeset: http://git.rtems.org/rtems/commit/?id=56ed56a641b69be42f5a38046307b33096014c84
> Author:    Chris Johns <chrisj at rtems.org>
> Date:      Sat Oct  4 08:55:12 2014 +1000
> Remove the use of sqrt and so the need to link to -lm.
> Clean up some warnings.
>  cpukit/libmisc/shell/main_ping.c |   17 ++++++++++++-----
>  1 files changed, 12 insertions(+), 5 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_ping.c b/cpukit/libmisc/shell/main_ping.c
> index a13d726..f13f241 100644
> --- a/cpukit/libmisc/shell/main_ping.c
> +++ b/cpukit/libmisc/shell/main_ping.c
> @@ -86,7 +86,9 @@ __FBSDID("$FreeBSD$");
>  #include <ctype.h>
>  //#include <err.h>
>  #include <errno.h>
> +#if !defined(__rtems__)
>  #include <math.h>
> +#endif
>  #include <netdb.h>
>  #include <signal.h>
>  #include <stdio.h>
> @@ -333,7 +335,6 @@ static char *pr_ntime(n_time);
>  static void pr_icmph(struct icmp *);
>  static void pr_iph(struct ip *);
>  static void pr_retip(struct ip *);
> -static void status(int);
>  static void stopit(int);
>  static void tvsub(struct timeval *, struct timeval *);
> @@ -358,7 +359,7 @@ static void g_pr_pack(char *, int, struct sockaddr_in *, struct timeval *, rtems
>  #define usage() g_usage(globals)
>  static void g_usage(rtems_shell_globals_t* globals) __dead2;
> -void
> +static void
>  rtems_shell_ping_exit (rtems_shell_globals_t* globals, int code)
>    globals->exit_code = code;
> @@ -1581,14 +1582,14 @@ tvsub(out, in)
>   *     Print out statistics when SIGINFO is received.
>  static void
>  status(sig)
>         int sig __unused;
> -#if !__rtems__
>         siginfo_p = 1;
> -#endif
> +#endif
>  static void
>  g_check_status(globals)
> @@ -1638,10 +1639,16 @@ g_finish(globals)
>         if (nreceived && timing) {
>                 double n = nreceived + nrepeats;
>                 double avg = tsum / n;
> +#if defined(__rtems__)
> +               (void) printf(
> +                   "round-trip min/avg/max/stddev = %.3f/%.3f/%.3f ms\n",
Remove "/stddev"?
> +                   tmin, avg, tmax);
> +#else
>                 double vari = tsumsq / n - avg * avg;
>                 (void)printf(
>                     "round-trip min/avg/max/stddev = %.3f/%.3f/%.3f/%.3f ms\n",
>                     tmin, avg, tmax, sqrt(vari));
> +#endif
>         if (nreceived)
>                 exit(0);
> @@ -1917,7 +1924,7 @@ g_fill(bp, patp, globals)
>         u_int ii, jj, kk;
>         for (cp = patp; *cp; cp++) {
> -               if (!isxdigit(*cp))
> +               if (!isxdigit((int)*cp))
>                         errx(&globals->exit_jmp, EX_USAGE,
>                             "patterns must be specified as hex digits");
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
