[rtems commit] libmisc/shell: Remove the need for -lm when linking from the ping command.
Sat Oct 4 00:05:24 UTC 2014
On Fri, Oct 3, 2014 at 8:04 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Oct 3, 2014 at 6:48 PM, Chris Johns <chrisj at rtems.org> wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    56ed56a641b69be42f5a38046307b33096014c84
>> Changeset: http://git.rtems.org/rtems/commit/?id=56ed56a641b69be42f5a38046307b33096014c84
>> Author:    Chris Johns <chrisj at rtems.org>
>> Date:      Sat Oct  4 08:55:12 2014 +1000
>> Remove the use of sqrt and so the need to link to -lm.
>> Clean up some warnings.
>>  cpukit/libmisc/shell/main_ping.c |   17 ++++++++++++-----
>>  1 files changed, 12 insertions(+), 5 deletions(-)
>> diff --git a/cpukit/libmisc/shell/main_ping.c b/cpukit/libmisc/shell/main_ping.c
>> index a13d726..f13f241 100644
>> --- a/cpukit/libmisc/shell/main_ping.c
>> +++ b/cpukit/libmisc/shell/main_ping.c
>> @@ -86,7 +86,9 @@ __FBSDID("$FreeBSD$");
>>  #include <ctype.h>
>>  //#include <err.h>
>>  #include <errno.h>
>> +#if !defined(__rtems__)
>>  #include <math.h>
>> +#endif
>>  #include <netdb.h>
>>  #include <signal.h>
>>  #include <stdio.h>
>> @@ -333,7 +335,6 @@ static char *pr_ntime(n_time);
>>  static void pr_icmph(struct icmp *);
>>  static void pr_iph(struct ip *);
>>  static void pr_retip(struct ip *);
>> -static void status(int);
>>  static void stopit(int);
>>  static void tvsub(struct timeval *, struct timeval *);
>> @@ -358,7 +359,7 @@ static void g_pr_pack(char *, int, struct sockaddr_in *, struct timeval *, rtems
>>  #define usage() g_usage(globals)
>>  static void g_usage(rtems_shell_globals_t* globals) __dead2;
>> -void
>> +static void
>>  rtems_shell_ping_exit (rtems_shell_globals_t* globals, int code)
>>    globals->exit_code = code;
>> @@ -1581,14 +1582,14 @@ tvsub(out, in)
>>   *     Print out statistics when SIGINFO is received.
>>  static void
>>  status(sig)
>>         int sig __unused;
>> -#if !__rtems__
>>         siginfo_p = 1;
>> -#endif
>> +#endif
>>  static void
>>  g_check_status(globals)
>> @@ -1638,10 +1639,16 @@ g_finish(globals)
>>         if (nreceived && timing) {
>>                 double n = nreceived + nrepeats;
>>                 double avg = tsum / n;
>> +#if defined(__rtems__)
>> +               (void) printf(
>> +                   "round-trip min/avg/max/stddev = %.3f/%.3f/%.3f ms\n",
> Remove "/stddev"?
Actually, I'd suggest to just print the variance as it can be computed
relatively cheaply (compared to sqrt).
>> +                   tmin, avg, tmax);
>> +#else
>>                 double vari = tsumsq / n - avg * avg;
>>                 (void)printf(
>>                     "round-trip min/avg/max/stddev = %.3f/%.3f/%.3f/%.3f ms\n",
>>                     tmin, avg, tmax, sqrt(vari));
>> +#endif
>>         if (nreceived)
>>                 exit(0);
>> @@ -1917,7 +1924,7 @@ g_fill(bp, patp, globals)
>>         u_int ii, jj, kk;
>>         for (cp = patp; *cp; cp++) {
>> -               if (!isxdigit(*cp))
>> +               if (!isxdigit((int)*cp))
>>                         errx(&globals->exit_jmp, EX_USAGE,
>>                             "patterns must be specified as hex digits");
>> vc mailing list
>> vc at rtems.org
>> http://lists.rtems.org/mailman/listinfo/vc
