[PATCH 2/2] shell: Add an editor to the shell.
Sat Oct 4 05:14:04 UTC 2014
This is a small (21K on sparc) editor that provides some powerful
features useful when a file needs editing on an embedded
board. No need for copy off, edit, copy back
 cpukit/libmisc/Makefile.am         |    2 +-
 cpukit/libmisc/shell/main_edit.c   | 2255 ++++++++++++++++++++++++++++++++++++
 cpukit/libmisc/shell/shellconfig.h |    6 +
 3 files changed, 2262 insertions(+), 1 deletion(-)
 create mode 100644 cpukit/libmisc/shell/main_edit.c
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 820a838..2f41ffa 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -109,7 +109,7 @@ libshell_a_SOURCES = shell/cat_file.c shell/cmds.c shell/internal.h \
     shell/main_time.c shell/main_mknod.c \
     shell/main_setenv.c shell/main_getenv.c shell/main_unsetenv.c \
     shell/main_mkrfs.c shell/main_debugrfs.c shell/main_df.c \
-    shell/main_lsof.c \
+    shell/main_lsof.c shell/main_edit.c \
     shell/main_blkstats.c \
     shell/shell-wait-for-input.c
diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
new file mode 100644
index 0000000..3097eeb
--- /dev/null
+++ b/cpukit/libmisc/shell/main_edit.c
@@ -0,0 +1,2255 @@
+// edit.c
+// Text editor
+// Copyright (C) 2002 Michael Ringgaard. All rights reserved.
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions
+// are met:
+// 1. Redistributions of source code must retain the above copyright
+//    notice, this list of conditions and the following disclaimer.
+// 2. Redistributions in binary form must reproduce the above copyright
+//    notice, this list of conditions and the following disclaimer in the
+//    documentation and/or other materials provided with the distribution.
+// 3. Neither the name of the project nor the names of its contributors
+//    may be used to endorse or promote products derived from this software
+//    without specific prior written permission.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+// ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+// ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE
+// FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+// DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+// OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+// LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+// OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+// SUCH DAMAGE.
+#include <signal.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <stdarg.h>
+#include <string.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <sys/stat.h>
+#ifdef SANOS
+#include <os.h>
+#endif
+#ifdef __rtems__
+#include <rtems.h>
+#include <rtems/shell.h>
+#endif
+#if defined(__linux__) || defined(__rtems__)
+#include <sys/ioctl.h>
+#include <termios.h>
+#define O_BINARY 0
+static int linux_console;
+#endif
+#define MINEXTEND      32768
+#define LINEBUF_EXTRA  32
+#ifndef TABSIZE
+#define TABSIZE        8
+#endif
+#ifndef INDENT
+#define INDENT "  "
+#endif
+#define CLRSCR           "\033[0J\x1b[H\x1b[J"
+#define CLREOL           "\033[K"
+#define GOTOXY           "\033[%d;%dH"
+#define RESET_COLOR      "\033[0m"
+#ifdef COLOR
+#define TEXT_COLOR       "\033[44m\033[37m\033[1m"
+#define SELECT_COLOR     "\033[47m\033[37m\033[1m"
+#define STATUS_COLOR     "\033[0m\033[47m\033[30m"
+#else
+#define TEXT_COLOR       "\033[0m"
+#define SELECT_COLOR     "\033[7m\033[1m"
+#define STATUS_COLOR     "\033[1m\033[7m"
+#endif
+// Key codes
+#define KEY_BACKSPACE        0x101
+#define KEY_ESC              0x102
+#define KEY_INS              0x103
+#define KEY_DEL              0x104
+#define KEY_LEFT             0x105
+#define KEY_RIGHT            0x106
+#define KEY_UP               0x107
+#define KEY_DOWN             0x108
+#define KEY_HOME             0x109
+#define KEY_END              0x10A
+#define KEY_ENTER            0x10B
+#define KEY_TAB              0x10C
+#define KEY_PGUP             0x10D
+#define KEY_PGDN             0x10E
+#define KEY_CTRL_LEFT        0x10F
+#define KEY_CTRL_RIGHT       0x110
+#define KEY_CTRL_UP          0x111
+#define KEY_CTRL_DOWN        0x112
+#define KEY_CTRL_HOME        0x113
+#define KEY_CTRL_END         0x114
+#define KEY_CTRL_TAB         0x115
+#define KEY_SHIFT_LEFT       0x116
+#define KEY_SHIFT_RIGHT      0x117
+#define KEY_SHIFT_UP         0x118
+#define KEY_SHIFT_DOWN       0x119
+#define KEY_SHIFT_PGUP       0x11A
+#define KEY_SHIFT_PGDN       0x11B
+#define KEY_SHIFT_HOME       0x11C
+#define KEY_SHIFT_END        0x11D
+#define KEY_SHIFT_TAB        0x11E
+#define KEY_SHIFT_CTRL_LEFT  0x11F
+#define KEY_SHIFT_CTRL_RIGHT 0x120
+#define KEY_SHIFT_CTRL_UP    0x121
+#define KEY_SHIFT_CTRL_DOWN  0x122
+#define KEY_SHIFT_CTRL_HOME  0x123
+#define KEY_SHIFT_CTRL_END   0x124
+#define KEY_F1               0x125
+#define KEY_F2               0x126
+#define KEY_F3               0x127
+#define KEY_F4               0x128
+#define KEY_F5               0x129
+#define KEY_F6               0x12a
+#define KEY_F7               0x12b
+#define KEY_F8               0x12c
+#define KEY_F9               0x12d
+#define KEY_F10              0x12e
+#define KEY_UNKNOWN          0xFFF
+#define ctrl(c) ((c) - 0x60)
+// Editor data block
+// Structure of split buffer:
+//    | text before gap  |        gap       |  text after gap  |
+//  start               gap                rest               end
+struct env;
+struct undo {
+  int pos;                 // Editor position
+  int erased;              // Size of erased contents
+  int inserted;            // Size of inserted contents
+  unsigned char *undobuf;  // Erased contents for undo
+  unsigned char *redobuf;  // Inserted contents for redo
+  struct undo *next;       // Next undo buffer
+  struct undo *prev;       // Previous undo buffer
+struct editor {
+  unsigned char *start;      // Start of text buffer
+  unsigned char *gap;        // Start of gap
+  unsigned char *rest;       // End of gap
+  unsigned char *end;        // End of text buffer
+  int toppos;                // Text position for current top screen line
+  int topline;               // Line number for top of screen
+  int margin;                // Position for leftmost column on screen
+  int linepos;               // Text position for current line
+  int line;                  // Current document line
+  int col;                   // Current document column
+  int lastcol;               // Remembered column from last horizontal navigation
+  int anchor;                // Anchor position for selection
+  struct undo *undohead;     // Start of undo buffer list
+  struct undo *undotail;     // End of undo buffer list
+  struct undo *undo;         // Undo/redo boundary
+  int refresh;               // Flag to trigger screen redraw
+  int lineupdate;            // Flag to trigger redraw of current line
+  int dirty;                 // Dirty flag is set when the editor buffer has been changed
+  int newfile;               // File is a new file
+  int permissions;           // File permissions
+  int selecting;             // Selecting active in the edtor.
+  struct env *env;           // Reference to global editor environment
+  struct editor *next;       // Next editor
+  struct editor *prev;       // Previous editor
+  char filename[FILENAME_MAX];
+struct env {
+  struct editor *current;   // Current editor
+  unsigned char *clipboard; // Clipboard
+  int clipsize;             // Clipboard size
+  unsigned char *search;    // Search text
+  unsigned char *linebuf;   // Scratch buffer
+  int cols;                 // Console columns
+  int lines;                // Console lines
+  int untitled;             // Counter for untitled files
+ * This is a hack to allow a simple way to inspect the keys to
+ * add extar decoding. It is not multi-user safe.
+#define KEY_HISTORY 1
+#if KEY_HISTORY
+int key_history[32];
+size_t key_history_in;
+#endif
+// Editor buffer functions
+static void clear_undo(struct editor *ed) {
+  struct undo *undo = ed->undohead;
+  while (undo) {
+    struct undo *next = undo->next;
+    free(undo->undobuf);
+    free(undo->redobuf);
+    free(undo);
+    undo = next;
+  ed->undohead = ed->undotail = ed->undo = NULL;
+static void reset_undo(struct editor *ed) {
+  while (ed->undotail != ed->undo) {
+    struct undo *undo = ed->undotail;
+    if (!undo) {
+      ed->undohead = NULL;
+      ed->undotail = NULL;
+      break;
+    ed->undotail = undo->prev;
+    if (undo->prev) undo->prev->next = NULL;
+    free(undo);
+  ed->undo = ed->undotail;
+static struct editor *create_editor(struct env *env) {
+  struct editor *ed = (struct editor *) malloc(sizeof(struct editor));
+  memset(ed, 0, sizeof(struct editor));
+  if (env->current) {
+    ed->next = env->current->next;
+    ed->prev = env->current;
+    env->current->next->prev = ed;
+    env->current->next = ed;
+  } else {
+    ed->next = ed->prev = ed;
+  ed->env = env;
+  env->current = ed;
+  return ed;
+static void delete_editor(struct editor *ed) {
+  if (ed->next == ed) {
+    ed->env->current = NULL;
+  } else {
+    ed->env->current = ed->prev;
+  ed->next->prev = ed->prev;
+  ed->prev->next = ed->next;
+  if (ed->start) free(ed->start);
+  clear_undo(ed);
+  free(ed);
+static struct editor *find_editor(struct env *env, char *filename) {
+  char fn[FILENAME_MAX];
+  struct editor *ed = env->current;
+  struct editor *start = ed;
+  if (!realpath(filename, fn)) strcpy(fn, filename);
+  do {
+    if (strcmp(fn, ed->filename) == 0) return ed;
+    ed = ed->next;
+  } while (ed != start);
+  return NULL;
+static int new_file(struct editor *ed, char *filename) {
+  if (*filename) {
+    strcpy(ed->filename, filename);
+  } else {
+    sprintf(ed->filename, "Untitled-%d", ++ed->env->untitled);
+    ed->newfile = 1;
+  ed->permissions = 0644;
+  ed->start = (unsigned char *) malloc(MINEXTEND);
+  if (!ed->start) return -1;
+#ifdef DEBUG
+  memset(ed->start, 0, MINEXTEND);
+#endif
+  ed->gap = ed->start;
+  ed->rest = ed->end = ed->gap + MINEXTEND;
+  ed->anchor = -1;
+  return 0;
+static int load_file(struct editor *ed, char *filename) {
+  struct stat statbuf;
+  int length;
+  int f;
+  if (!realpath(filename, ed->filename)) return -1;
+  f = open(ed->filename, O_RDONLY | O_BINARY);
+  if (f < 0) return -1;
+  if (fstat(f, &statbuf) < 0) goto err;
+  length = statbuf.st_size;
+  ed->permissions = statbuf.st_mode & 0777;
+  ed->start = (unsigned char *) malloc(length + MINEXTEND);
+  if (!ed->start) goto err;
+#ifdef DEBUG
+  memset(ed->start, 0, length + MINEXTEND);
+#endif
+  if (read(f, ed->start, length) != length) goto err;
+  ed->gap = ed->start + length;
+  ed->anchor = -1;
+  close(f);
+  return 0;
+err:
+  close(f);
+  if (ed->start) {
+    free(ed->start);
+    ed->start = NULL;
+  return -1;
+static int save_file(struct editor *ed) {
+  int f;
+  f = open(ed->filename, O_CREAT | O_TRUNC | O_WRONLY, ed->permissions);
+  if (write(f, ed->start, ed->gap - ed->start) != ed->gap - ed->start) goto err;
+  if (write(f, ed->rest, ed->end - ed->rest) != ed->end - ed->rest) goto err;
+  close(f);
+  ed->dirty = 0;
+  clear_undo(ed);
+  return 0;
+err:
+  close(f);
+  return -1;
+static int text_length(struct editor *ed) {
+  return (ed->gap - ed->start) + (ed->end - ed->rest);
+static unsigned char *text_ptr(struct editor *ed, int pos) {
+  unsigned char *p = ed->start + pos;
+  if (p >= ed->gap) p += (ed->rest - ed->gap);
+  return p;
+static void move_gap(struct editor *ed, int pos, int minsize) {
+  int gapsize = ed->rest - ed->gap;
+  unsigned char *p = text_ptr(ed, pos);
+  if (minsize < 0) minsize = 0;
+  if (minsize <= gapsize) {
+    if (p != ed->rest) {
+      if (p < ed->gap) {
+        memmove(p + gapsize, p, ed->gap - p);
+      } else {
+        memmove(ed->gap, ed->rest, p - ed->rest);
+      ed->gap = ed->start + pos;
+      ed->rest = ed->gap + gapsize;
+  } else {
+    int newsize;
+    if (gapsize + MINEXTEND > minsize) minsize = gapsize + MINEXTEND;
+    newsize = (ed->end - ed->start) - gapsize + minsize;
+    start = (unsigned char *) malloc(newsize); // TODO check for out of memory
+    gap = start + pos;
+    rest = gap + minsize;
+    end = start + newsize;
+      memcpy(start, ed->start, pos);
+      memcpy(rest, p, ed->gap - p);
+      memcpy(end - (ed->end - ed->rest), ed->rest, ed->end - ed->rest);
+    } else {
+      memcpy(start, ed->start, ed->gap - ed->start);
+      memcpy(start + (ed->gap - ed->start), ed->rest, p - ed->rest);
+      memcpy(rest, p, ed->end - p);
+    free(ed->start);
+    ed->start = start;
+    ed->gap = gap;
+    ed->rest = rest;
+    ed->end = end;
+#ifdef DEBUG
+  memset(ed->gap, 0, ed->rest - ed->gap);
+#endif
+static void close_gap(struct editor *ed) {
+  int len = text_length(ed);
+  move_gap(ed, len, 1);
+  ed->start[len] = 0;
+static int get(struct editor *ed, int pos) {
+  if (p >= ed->end) return -1;
+  return *p;
+static int compare(struct editor *ed, unsigned char *buf, int pos, int len) {
+  unsigned char *bufptr = buf;
+  while (len > 0) {
+    if (p == ed->end) return 0;
+    if (*bufptr++ != *p) return 0;
+    len--;
+    if (++p == ed->gap) p = ed->rest;
+  return 1;
+static int copy(struct editor *ed, unsigned char *buf, int pos, int len) {
+  while (len > 0) {
+    if (p == ed->end) break;
+    *bufptr++ = *p;
+    len--;
+  return bufptr - buf;
+static void replace(struct editor *ed, int pos, int len, unsigned char *buf, int bufsize, int doundo) {
+  unsigned char *p;
+  // Store undo information
+  if (doundo) {
+    reset_undo(ed);
+    undo = ed->undotail;
+    if (undo && len == 0 && bufsize == 1 && undo->erased == 0 && pos == undo->pos + undo->inserted) {
+      // Insert character at end of current redo buffer
+      undo->redobuf = realloc(undo->redobuf, undo->inserted + 1);
+      undo->redobuf[undo->inserted] = *buf;
+      undo->inserted++;
+    } else if (undo && len == 1 && bufsize == 0 && undo->inserted == 0 && pos == undo->pos) {
+      // Erase character at end of current undo buffer
+      undo->undobuf = realloc(undo->undobuf, undo->erased + 1);
+      undo->undobuf[undo->erased] = get(ed, pos);
+      undo->erased++;
+    } else if (undo && len == 1 && bufsize == 0 && undo->inserted == 0 && pos == undo->pos - 1) {
+      // Erase character at beginning of current undo buffer
+      undo->pos--;
+      memmove(undo->undobuf + 1, undo->undobuf, undo->erased);
+      undo->undobuf[0] = get(ed, pos);
+      undo->erased++;
+    } else {
+      // Create new undo buffer
+      undo = (struct undo *) malloc(sizeof(struct undo));
+      if (ed->undotail) ed->undotail->next = undo;
+      undo->prev = ed->undotail;
+      undo->next = NULL;
+      ed->undotail = ed->undo = undo;
+      if (!ed->undohead) ed->undohead = undo;
+      undo->pos = pos;
+      undo->erased = len;
+      undo->inserted = bufsize;
+      undo->undobuf = undo->redobuf = NULL;
+      if (len > 0) {
+        undo->undobuf = malloc(len);
+        copy(ed, undo->undobuf, pos, len);
+      if (bufsize > 0) {
+        undo->redobuf = malloc(bufsize);
+        memcpy(undo->redobuf, buf, bufsize);
+  p = ed->start + pos;
+  if (bufsize == 0 && p <= ed->gap && p + len >= ed->gap) {
+    // Handle deletions at the edges of the gap
+    ed->rest += len - (ed->gap - p);
+    ed->gap = p;
+  } else {
+    // Move the gap
+    move_gap(ed, pos + len, bufsize - len);
+    // Replace contents
+    memcpy(ed->start + pos, buf, bufsize);
+    ed->gap = ed->start + pos + bufsize;
+  // Mark buffer as dirty
+  ed->dirty = 1;
+static void insert(struct editor *ed, int pos, unsigned char *buf, int bufsize) {
+  replace(ed, pos, 0, buf, bufsize, 1);
+static void erase(struct editor *ed, int pos, int len) {
+  replace(ed, pos, len, NULL, 0, 1);
+// Navigation functions
+static int line_length(struct editor *ed, int linepos) {
+  int pos = linepos;
+  while (1) {
+    int ch = get(ed, pos);
+    if (ch < 0 || ch == '\n' || ch == '\r') break;
+    pos++;
+  return pos - linepos;
+static int line_start(struct editor *ed, int pos) {
+  while (1) {
+    if (pos == 0) break;
+    if (get(ed, pos - 1) == '\n') break;
+    pos--;
+  return pos;
+static int next_line(struct editor *ed, int pos) {
+  while (1) {
+    if (ch < 0) return -1;
+    pos++;
+    if (ch == '\n') return pos;
+static int prev_line(struct editor *ed, int pos) {
+  if (pos == 0) return -1;
+  while (pos > 0) {
+    int ch = get(ed, --pos);
+    if (ch == '\n') break;
+  while (pos > 0) {
+    if (ch == '\n') return pos + 1;
+  return 0;
+static int column(struct editor *ed, int linepos, int col) {
+  unsigned char *p = text_ptr(ed, linepos);
+  int c = 0;
+  while (col > 0) {
+    if (*p == '\t') {
+      int spaces = TABSIZE - c % TABSIZE;
+      c += spaces;
+    } else {
+      c++;
+    col--;
+  return c;
+static void moveto(struct editor *ed, int pos, int center) {
+  int scroll = 0;
+  for (;;) {
+    int cur = ed->linepos + ed->col;
+    if (pos < cur) {
+      if (pos >= ed->linepos) {
+        ed->col = pos - ed->linepos;
+      } else {
+        ed->col = 0;
+        ed->linepos = prev_line(ed, ed->linepos);
+        ed->line--;
+        if (ed->topline > ed->line) {
+          ed->toppos = ed->linepos;
+          ed->topline--;
+          ed->refresh = 1;
+          scroll = 1;
+    } else if (pos > cur) {
+      int next = next_line(ed, ed->linepos);
+      if (next == -1) {
+        ed->col = line_length(ed, ed->linepos);
+        break;
+      } else if (pos < next) {
+      } else {
+        ed->col = 0;
+        ed->linepos = next;
+        ed->line++;
+        if (ed->line >= ed->topline + ed->env->lines) {
+          ed->toppos = next_line(ed, ed->toppos);
+          ed->topline++;
+          ed->refresh = 1;
+          scroll = 1;
+    } else {
+      break;
+  if (scroll && center) {
+    int tl = ed->line - ed->env->lines / 2;
+    if (tl < 0) tl = 0;
+    for (;;) {
+      if (ed->topline > tl) {
+        ed->toppos = prev_line(ed, ed->toppos);
+        ed->topline--;
+      } else if (ed->topline < tl) {
+        ed->topline++;
+      } else {
+        break;
+// Text selection
+static int get_selection(struct editor *ed, int *start, int *end) {
+  if (ed->anchor == -1) {
+    *start = *end = -1;
+    return 0;
+  } else {
+    int pos = ed->linepos + ed->col;
+    if (pos == ed->anchor) {
+      return 0;
+    } else if (pos < ed->anchor) {
+      *start = pos;
+      *end = ed->anchor;
+    } else {
+      *start = ed->anchor;
+      *end = pos;
+  return 1;
+static int get_selected_text(struct editor *ed, char *buffer, int size) {
+  int selstart, selend, len;
+  if (!get_selection(ed, &selstart, &selend)) return 0;
+  len = selend - selstart;
+  if (len >= size) return 0;
+  copy(ed, (unsigned char*) buffer, selstart, len);
+  buffer[len] = 0;
+  return len;
+static void update_selection(struct editor *ed, int select) {
+  if (select) {
+    if (ed->anchor == -1) ed->anchor = ed->linepos + ed->col;
+    ed->refresh = 1;
+  } else {
+    if (ed->anchor != -1) ed->refresh = 1;
+    ed->anchor = -1;
+static int erase_selection(struct editor *ed) {
+  int selstart, selend;
+  moveto(ed, selstart, 0);
+  erase(ed, selstart, selend - selstart);
+  ed->anchor = -1;
+  ed->refresh = 1;
+  return 1;
+static void select_all(struct editor *ed) {
+  ed->anchor = 0;
+  ed->refresh = 1;
+  moveto(ed, text_length(ed), 0);
+// Screen functions
+static void get_console_size(struct env *env) {
+#ifdef __linux__
+  struct winsize ws;
+  ioctl(0, TIOCGWINSZ, &ws);
+  env->cols = ws.ws_col;
+  env->lines = ws.ws_row - 1;
+#elif defined(__rtems__)
+  env->cols = 80;
+  env->lines = 25;
+#else
+  struct term *term = gettib()->proc->term;
+  env->cols = term->cols;
+  env->lines = term->lines - 1;
+#endif
+  env->linebuf = realloc(env->linebuf, env->cols + LINEBUF_EXTRA);
+static void outch(char c) {
+  putchar(c);
+static void outbuf(unsigned char *buf, int len) {
+  fwrite(buf, 1, len, stdout);
+static void outstr(char *str) {
+  fputs(str, stdout);
+static void clear_screen() {
+  outstr(CLRSCR);
+static void gotoxy(int col, int line) {
+  char buf[32];
+  sprintf(buf, GOTOXY, line + 1, col + 1);
+  outstr(buf);
+// Keyboard functions
+static void get_modifier_keys(int *shift, int *ctrl) {
+  *shift = *ctrl = 0;
+#ifdef __linux__
+  if (linux_console) {
+    char modifiers = 6;
+    if (ioctl(0, TIOCLINUX, &modifiers) >= 0) {
+      if (modifiers & 1) *shift = 1;
+      if (modifiers & 4) *ctrl = 1;
+#endif
+static int getachar()
+  int ch = getchar();
+#if KEY_HISTORY
+  if (key_history_in < sizeof(key_history)) {
+      key_history[key_history_in++] = ch;
+  } else {
+    memmove(&key_history[0], &key_history[1], sizeof(key_history) - sizeof(key_history[0]));
+    key_history[key_history_in - 1] = ch;
+#endif
+  return ch;
+static int getkey() {
+  int ch, shift, ctrl;
+  ch = getachar();
+  if (ch < 0) return ch;
+  switch (ch) {
+    case 0x08: return KEY_BACKSPACE;
+    case 0x09:
+      get_modifier_keys(&shift, &ctrl);
+      if (shift) return KEY_SHIFT_TAB;
+      if (ctrl) return KEY_CTRL_TAB;
+      return KEY_TAB;
+#ifdef SANOS
+    case 0x0D: return gettib()->proc->term->type == TERM_CONSOLE ? KEY_ENTER : KEY_UNKNOWN;
+    case 0x0A: return gettib()->proc->term->type != TERM_CONSOLE ? KEY_ENTER : KEY_UNKNOWN;
+#else
+    case 0x0D: return KEY_ENTER;
+    case 0x0A: return KEY_ENTER;
+#endif
+    case 0x1B:
+      ch = getachar();
+      switch (ch) {
+        case 0x1B: return KEY_ESC;
+        case 0x4F:
+          ch = getachar();
+          switch (ch) {
+            case 0x46: return KEY_END;
+            case 0x48: return KEY_HOME;
+            case 0x50: return KEY_F1;
+            case 0x51: return KEY_F2;
+            case 0x52: return KEY_F3;
+            case 0x53: return KEY_F4;
+            case 0x54: return KEY_F5;
+            default: return KEY_UNKNOWN;
+          break;
+        case 0x5B:
+          ch = getachar();
+          if (ch == 0x31) {
+            ch = getachar();
+            switch (ch) {
+              case 0x35:
+                return getachar() == 0x7E ? KEY_F5 : KEY_UNKNOWN;
+              case 0x37:
+                return getachar() == 0x7E ? KEY_F6 : KEY_UNKNOWN;
+              case 0x3B:
+                ch = getachar();
+                if (ch == 0x7E) return KEY_F7;
+                if (ch == 0x32) shift = 1;
+                if (ch == 0x35) ctrl = 1;
+                if (ch == 0x36) shift = ctrl = 1;
+                ch = getachar();
+                break;
+              case 0x39:
+                return getachar() == 0x7E ? KEY_F8 : KEY_UNKNOWN;
+              case 0x7E:
+                if (shift && ctrl) return KEY_SHIFT_CTRL_HOME;
+                if (shift) return KEY_SHIFT_HOME;
+                if (ctrl) return KEY_CTRL_HOME;
+                return KEY_HOME;
+              default:
+                return KEY_UNKNOWN;
+          switch (ch) {
+            case 0x31:
+              ch = getachar();
+              if (ch != 0x7E) return KEY_UNKNOWN;
+              return KEY_HOME;
+            case 0x32:
+              ch = getachar();
+              switch (ch) {
+                case 0x30: ch = getachar(); return KEY_F9;
+                case 0x31: ch = getachar(); return KEY_F10;
+                case 0x7E: return KEY_INS;
+                default: break;
+            case 0x33: return getachar() == 0x7E ? KEY_DEL : KEY_UNKNOWN;
+            case 0x34:
+              if (getachar() != 0x7E) return KEY_UNKNOWN;
+              if (shift && ctrl) return KEY_SHIFT_CTRL_END;
+              if (shift) return KEY_SHIFT_END;
+              if (ctrl) return KEY_CTRL_END;
+              return KEY_END;
+            case 0x35:
+              if (shift) return KEY_SHIFT_PGUP;
+              return KEY_PGUP;
+            case 0x36:
+              if (shift) return KEY_SHIFT_PGDN;
+              return KEY_PGDN;
+            case 0x41:
+              if (shift && ctrl) return KEY_SHIFT_CTRL_UP;
+              if (shift) return KEY_SHIFT_UP;
+              if (ctrl) return KEY_CTRL_UP;
+              return KEY_UP;
+            case 0x42:
+              if (shift && ctrl) return KEY_SHIFT_CTRL_DOWN;
+              if (shift) return KEY_SHIFT_DOWN;
+              if (ctrl) return KEY_CTRL_DOWN;
+              return KEY_DOWN;
+            case 0x43:
+              if (shift && ctrl) return KEY_SHIFT_CTRL_RIGHT;
+              if (shift) return KEY_SHIFT_RIGHT;
+              if (ctrl) return KEY_CTRL_RIGHT;
+              return KEY_RIGHT;
+            case 0x44:
+              if (shift && ctrl) return KEY_SHIFT_CTRL_LEFT;
+              if (shift) return KEY_SHIFT_LEFT;
+              if (ctrl) return KEY_CTRL_LEFT;
+              return KEY_LEFT;
+            case 0x46:
+              return KEY_END;
+            case 0x48:
+              return KEY_HOME;
+            case 0x5A:
+              return KEY_SHIFT_TAB;
+            case 0x5B:
+              ch = getachar();
+              switch (ch) {
+                case 0x41: return KEY_F1;
+                case 0x43: return KEY_F3;
+                case 0x45: return KEY_F5;
+          break;
+      break;
+    case 0x00:
+    case 0xE0:
+      ch = getachar();
+      switch (ch) {
+        case 0x0F: return KEY_SHIFT_TAB;
+        case 0x3B: return KEY_F1;
+        case 0x3D: return KEY_F3;
+        case 0x3F: return KEY_F5;
+        case 0x47: return KEY_HOME;
+        case 0x48: return KEY_UP;
+        case 0x49: return KEY_PGUP;
+        case 0x4B: return KEY_LEFT;
+        case 0x4D: return KEY_RIGHT;
+        case 0x4F: return KEY_END;
+        case 0x50: return KEY_DOWN;
+        case 0x51: return KEY_PGDN;
+        case 0x52: return KEY_INS;
+        case 0x53: return KEY_DEL;
+        case 0x73: return KEY_CTRL_LEFT;
+        case 0x74: return KEY_CTRL_RIGHT;
+        case 0x75: return KEY_CTRL_END;
+        case 0x77: return KEY_CTRL_HOME;
+        case 0x8D: return KEY_CTRL_UP;
+        case 0x91: return KEY_CTRL_DOWN;
+        case 0x94: return KEY_CTRL_TAB;
+        case 0xB8: return KEY_SHIFT_UP;
+        case 0xB7: return KEY_SHIFT_HOME;
+        case 0xBF: return KEY_SHIFT_END;
+        case 0xB9: return KEY_SHIFT_PGUP;
+        case 0xBB: return KEY_SHIFT_LEFT;
+        case 0xBD: return KEY_SHIFT_RIGHT;
+        case 0xC0: return KEY_SHIFT_DOWN;
+        case 0xC1: return KEY_SHIFT_PGDN;
+        case 0xDB: return KEY_SHIFT_CTRL_LEFT;
+        case 0xDD: return KEY_SHIFT_CTRL_RIGHT;
+        case 0xD8: return KEY_SHIFT_CTRL_UP;
+        case 0xE0: return KEY_SHIFT_CTRL_DOWN;
+        case 0xD7: return KEY_SHIFT_CTRL_HOME;
+        case 0xDF: return KEY_SHIFT_CTRL_END;
+      break;
+    case 0x7F: return KEY_BACKSPACE;
+    default: return ch;
+static int prompt(struct editor *ed, char *msg, int selection) {
+  int maxlen, len, ch;
+  char *buf = (char*) ed->env->linebuf;
+  gotoxy(0, ed->env->lines);
+  outstr(STATUS_COLOR);
+  outstr(msg);
+  outstr(CLREOL);
+  len = 0;
+  maxlen = ed->env->cols - strlen(msg) - 1;
+  if (selection) {
+    len = get_selected_text(ed, buf, maxlen);
+    outbuf((unsigned char*) buf, len);
+  for (;;) {
+    fflush(stdout);
+    ch = getkey();
+    if (ch == KEY_ESC) {
+      return 0;
+    } else if (ch == KEY_ENTER) {
+      buf[len] = 0;
+      return len > 0;
+    } else if (ch == KEY_BACKSPACE) {
+      if (len > 0) {
+        outstr("\b \b");
+        len--;
+    } else if (ch >= ' ' && ch < 0x100 && len < maxlen) {
+      outch(ch);
+      buf[len++] = ch;
+static int ask() {
+  int ch = getachar();
+  return ch == 'y' || ch == 'Y';
+// Display functions
+static void display_message(struct editor *ed, char *fmt, ...) {
+  va_list args;
+  va_start(args, fmt);
+  vprintf(fmt, args);
+  outstr(CLREOL TEXT_COLOR);
+  fflush(stdout);
+  va_end(args);
+static void draw_full_statusline(struct editor *ed) {
+  struct env *env = ed->env;
+  int namewidth = env->cols - 29;
+  gotoxy(0, env->lines);
+  sprintf((char*) env->linebuf, STATUS_COLOR "%*.*sF1=Help %c%c Ln %-6dCol %-4d" CLREOL TEXT_COLOR, -namewidth, namewidth, ed->filename, ed->selecting ? '+' : ' ', ed->dirty ? '*' : ' ', ed->line + 1, column(ed, ed->linepos, ed->col) + 1);
+  outstr((char*) env->linebuf);
+static void draw_statusline(struct editor *ed) {
+  gotoxy(ed->env->cols - 20, ed->env->lines);
+  sprintf((char*) ed->env->linebuf, STATUS_COLOR "%c Ln %-6dCol %-4d" CLREOL TEXT_COLOR, ed->dirty ? '*' : ' ', ed->line + 1, column(ed, ed->linepos, ed->col) + 1);
+  outstr((char*) ed->env->linebuf);
+static void display_line(struct editor *ed, int pos, int fullline) {
+  int hilite = 0;
+  int col = 0;
+  int margin = ed->margin;
+  int maxcol = ed->env->cols + margin;
+  unsigned char *bufptr = ed->env->linebuf;
+  int selstart, selend, ch;
+  char *s;
+  get_selection(ed, &selstart, &selend);
+  while (col < maxcol) {
+    if (margin == 0) {
+      if (!hilite && pos >= selstart && pos < selend) {
+        for (s = SELECT_COLOR; *s; s++) *bufptr++ = *s;
+        hilite = 1;
+      } else if (hilite && pos >= selend) {
+        for (s = TEXT_COLOR; *s; s++) *bufptr++ = *s;
+        hilite = 0;
+    ch = *p;
+    if (ch == '\r' || ch == '\n') break;
+    if (ch == '\t') {
+      int spaces = TABSIZE - col % TABSIZE;
+      while (spaces > 0 && col < maxcol) {
+        if (margin > 0) {
+          margin--;
+        } else {
+          *bufptr++ = ' ';
+        col++;
+        spaces--;
+    } else {
+      if (margin > 0) {
+        margin--;
+      } else {
+        *bufptr++ = ch;
+      col++;
+    pos++;
+  if (hilite) {
+      *bufptr++ = ' ';
+      col++;
+  } else {
+    if (col == margin) *bufptr++ = ' ';
+#endif
+  if (col < maxcol) {
+    for (s = CLREOL; *s; s++) *bufptr++ = *s;
+    if (fullline) {
+      memcpy(bufptr, "\r\n", 2);
+      bufptr += 2;
+  if (hilite) {
+  outbuf(ed->env->linebuf, bufptr - ed->env->linebuf);
+static void update_line(struct editor *ed) {
+  gotoxy(0, ed->line - ed->topline);
+  display_line(ed, ed->linepos, 0);
+static void draw_screen(struct editor *ed) {
+  int pos;
+  int i;
+  gotoxy(0, 0);
+  outstr(TEXT_COLOR);
+  pos = ed->toppos;
+  for (i = 0; i < ed->env->lines; i++) {
+    if (pos < 0) {
+      outstr(CLREOL "\r\n");
+    } else {
+      display_line(ed, pos, 1);
+      pos = next_line(ed, pos);
+static void position_cursor(struct editor *ed) {
+  int col = column(ed, ed->linepos, ed->col);
+  gotoxy(col - ed->margin, ed->line - ed->topline);
+// Cursor movement
+static void adjust(struct editor *ed) {
+  int col;
+  int ll = line_length(ed, ed->linepos);
+  ed->col = ed->lastcol;
+  if (ed->col > ll) ed->col = ll;
+  col = column(ed, ed->linepos, ed->col);
+  while (col < ed->margin) {
+    ed->margin -= 4;
+    if (ed->margin < 0) ed->margin = 0;
+    ed->refresh = 1;
+  while (col - ed->margin >= ed->env->cols) {
+    ed->margin += 4;
+    ed->refresh = 1;
+static void select_toggle(struct editor *ed) {
+  ed->selecting = ed->selecting ? 0 : 1;
+  update_selection(ed, ed->selecting);
+  adjust(ed);
+static void up(struct editor *ed, int select) {
+  int newpos;
+  update_selection(ed, select);
+  newpos = prev_line(ed, ed->linepos);
+  if (newpos < 0) return;
+  ed->linepos = newpos;
+  ed->line--;
+  if (ed->line < ed->topline) {
+    ed->topline = ed->line;
+    ed->refresh = 1;
+  adjust(ed);
+static void down(struct editor *ed, int select) {
+  int newpos;
+  newpos = next_line(ed, ed->linepos);
+  ed->line++;
+    ed->topline++;
+    ed->refresh = 1;
+  adjust(ed);
+static void left(struct editor *ed, int select) {
+  if (ed->col > 0) {
+    ed->col--;
+  } else {
+    int newpos = prev_line(ed, ed->linepos);
+    ed->col = line_length(ed, newpos);
+    ed->line--;
+      ed->refresh = 1;
+  ed->lastcol = ed->col;
+  adjust(ed);
+static void right(struct editor *ed, int select) {
+  if (ed->col < line_length(ed, ed->linepos)) {
+    ed->col++;
+  } else {
+    int newpos = next_line(ed, ed->linepos);
+    ed->col = 0;
+    ed->line++;
+      ed->topline++;
+      ed->refresh = 1;
+  adjust(ed);
+static int wordchar(int ch) {
+  return (ch >= 'A' && ch <= 'Z') || (ch >= 'a' && ch <= 'z') || (ch >= '0' && ch <= '9');
+static void wordleft(struct editor *ed, int select) {
+  int pos, phase;
+  pos = ed->linepos + ed->col;
+  phase = 0;
+  while (pos > 0) {
+    int ch = get(ed, pos - 1);
+    if (phase == 0) {
+      if (wordchar(ch)) phase = 1;
+    } else {
+      if (!wordchar(ch)) break;
+    pos--;
+    if (pos < ed->linepos) {
+      ed->line--;
+      ed->refresh = 1;
+  adjust(ed);
+static void wordright(struct editor *ed, int select) {
+  int pos, end, phase, next;
+  end = text_length(ed);
+  next = next_line(ed, ed->linepos);
+  phase = 0;
+  while (pos < end) {
+    if (phase == 0) {
+    } else {
+    pos++;
+    if (pos == next) {
+      ed->line++;
+      ed->refresh = 1;
+    ed->topline++;
+  adjust(ed);
+static void home(struct editor *ed, int select) {
+  ed->col = ed->lastcol = 0;
+  adjust(ed);
+static void end(struct editor *ed, int select) {
+  ed->col = ed->lastcol = line_length(ed, ed->linepos);
+  adjust(ed);
+static void top(struct editor *ed, int select) {
+  ed->toppos = ed->topline = ed->margin = 0;
+  ed->linepos = ed->line = ed->col = ed->lastcol = 0;
+  ed->refresh = 1;
+static void bottom(struct editor *ed, int select) {
+  for (;;) {
+    if (newpos < 0) break;
+    ed->line++;
+      ed->topline++;
+      ed->refresh = 1;
+  adjust(ed);
+static void pageup(struct editor *ed, int select) {
+  int i;
+  if (ed->line < ed->env->lines) {
+    ed->linepos = ed->toppos = 0;
+    ed->line = ed->topline = 0;
+  } else {
+      ed->line--;
+      if (ed->topline > 0) {
+        ed->topline--;
+  ed->refresh = 1;
+  adjust(ed);
+static void pagedown(struct editor *ed, int select) {
+  int i;
+    ed->line++;
+    ed->topline++;
+  ed->refresh = 1;
+  adjust(ed);
+// Text editing
+static void insert_char(struct editor *ed, unsigned char ch) {
+  erase_selection(ed);
+  insert(ed, ed->linepos + ed->col, &ch, 1);
+  ed->col++;
+  adjust(ed);
+  if (!ed->refresh) ed->lineupdate = 1;
+static void newline(struct editor *ed) {
+  int p;
+  unsigned char ch;
+  insert(ed, ed->linepos + ed->col, (unsigned char*) "\n", 1);
+#else
+  insert(ed, ed->linepos + ed->col, "\r\n", 2);
+#endif
+  ed->line++;
+  p = ed->linepos;
+  ed->linepos = next_line(ed, ed->linepos);
+  for (;;) {
+    ch = get(ed, p++);
+    if (ch == ' ' || ch == '\t') {
+      ed->col++;
+    } else {
+      break;
+  ed->refresh = 1;
+    ed->topline++;
+    ed->refresh = 1;
+  adjust(ed);
+static void backspace(struct editor *ed) {
+  if (erase_selection(ed)) return;
+  if (ed->linepos + ed->col == 0) return;
+  if (ed->col == 0) {
+    int pos = ed->linepos;
+    erase(ed, --pos, 1);
+    if (get(ed, pos - 1) == '\r') erase(ed, --pos, 1);
+    ed->line--;
+    ed->linepos = line_start(ed, pos);
+    ed->refresh = 1;
+  } else {
+    ed->col--;
+    erase(ed, ed->linepos + ed->col, 1);
+    ed->lineupdate = 1;
+  adjust(ed);
+static void del(struct editor *ed) {
+  int pos, ch;
+  ch = get(ed, pos);
+  if (ch < 0) return;
+  erase(ed, pos, 1);
+  if (ch == '\r') {
+    if (ch == '\n') erase(ed, pos, 1);
+  if (ch == '\n') {
+    ed->refresh = 1;
+  } else {
+static void indent(struct editor *ed, unsigned char *indentation) {
+  int start, end, i, lines, toplines, newline, ch;
+  unsigned char *buffer, *p;
+  int buflen;
+  int width = strlen((const char*) indentation);
+  if (!get_selection(ed, &start, &end)) {
+    insert_char(ed, '\t');
+    return;
+  lines = 0;
+  toplines = 0;
+  newline = 1;
+  for (i = start; i < end; i++) {
+    if (i == ed->toppos) toplines = lines;
+    if (newline) {
+      lines++;
+      newline = 0;
+    if (get(ed, i) == '\n') newline = 1;
+  buflen = end - start + lines * width;
+  buffer = malloc(buflen);
+  if (!buffer) return;
+  newline = 1;
+  p = buffer;
+    if (newline) {
+      memcpy(p, indentation, width);
+      p += width;
+      newline = 0;
+    ch = get(ed, i);
+    *p++ = ch;
+    if (ch == '\n') newline = 1;
+  replace(ed, start, end - start, buffer, buflen, 1);
+  free(buffer);
+  if (ed->anchor < pos) {
+    pos += width * lines;
+  } else {
+    ed->anchor += width * lines;
+  ed->toppos += width * toplines;
+  ed->col = ed->lastcol = pos - ed->linepos;
+  adjust(ed);
+  ed->refresh = 1;
+static void unindent(struct editor *ed, unsigned char *indentation) {
+  int start, end, i, newline, ch, shrinkage, topofs;
+  if (!get_selection(ed, &start, &end)) return;
+  buffer = malloc(end - start);
+  newline = 1;
+  p = buffer;
+  i = start;
+  shrinkage = 0;
+  topofs = 0;
+  while (i < end) {
+    if (newline) {
+      newline = 0;
+      if (compare(ed, indentation, i, width)) {
+        i += width;
+        shrinkage += width;
+        if (i < ed->toppos) topofs -= width;
+        continue;
+    ch = get(ed, i++);
+    *p++ = ch;
+  if (!shrinkage) {
+    free(buffer);
+    return;
+  replace(ed, start, end - start, buffer, p - buffer, 1);
+  free(buffer);
+    pos -= shrinkage;
+  } else {
+    ed->anchor -= shrinkage;
+  ed->toppos += topofs;
+  ed->refresh = 1;
+  adjust(ed);
+static void undo(struct editor *ed) {
+  if (!ed->undo) return;
+  moveto(ed, ed->undo->pos, 0);
+  replace(ed, ed->undo->pos, ed->undo->inserted, ed->undo->undobuf, ed->undo->erased, 0);
+  ed->undo = ed->undo->prev;
+  if (!ed->undo) ed->dirty = 0;
+  ed->anchor = -1;
+  ed->refresh = 1;
+static void redo(struct editor *ed) {
+  if (ed->undo) {
+    if (!ed->undo->next) return;
+    ed->undo = ed->undo->next;
+  } else {
+    if (!ed->undohead) return;
+    ed->undo = ed->undohead;
+  replace(ed, ed->undo->pos, ed->undo->erased, ed->undo->redobuf, ed->undo->inserted, 0);
+  ed->dirty = 1;
+  ed->anchor = -1;
+  ed->refresh = 1;
+// Clipboard
+static void copy_selection(struct editor *ed) {
+  if (!get_selection(ed, &selstart, &selend)) return;
+  ed->env->clipsize = selend - selstart;
+  ed->env->clipboard = (unsigned char *) realloc(ed->env->clipboard, ed->env->clipsize);
+  if (!ed->env->clipboard) return;
+  copy(ed, ed->env->clipboard, selstart, ed->env->clipsize);
+  select_toggle(ed);
+static void cut_selection(struct editor *ed) {
+  copy_selection(ed);
+static void paste_selection(struct editor *ed) {
+  insert(ed, ed->linepos + ed->col, ed->env->clipboard, ed->env->clipsize);
+  moveto(ed, ed->linepos + ed->col + ed->env->clipsize, 0);
+  ed->refresh = 1;
+// Editor Commands
+static void open_editor(struct editor *ed) {
+  int rc;
+  char *filename;
+  if (!prompt(ed, "Open file: ", 1)) {
+    ed->refresh = 1;
+    return;
+  filename = (char*) ed->env->linebuf;
+  ed = find_editor(ed->env, filename);
+  if (ed) {
+  } else {
+    ed = create_editor(env);
+    rc = load_file(ed, filename);
+    if (rc < 0) {
+      display_message(ed, "Error %d opening %s (%s)", errno, filename, strerror(errno));
+      sleep(5);
+      delete_editor(ed);
+      ed = env->current;
+  ed->refresh = 1;
+static void new_editor(struct editor *ed) {
+  ed = create_editor(ed->env);
+  new_file(ed, "");
+  ed->refresh = 1;
+static void read_from_stdin(struct editor *ed) {
+  char buffer[512];
+  int n, pos;
+  pos = 0;
+  while ((n = fread(buffer, 1, sizeof(buffer), stdin)) > 0) {
+    insert(ed, pos, (unsigned char*) buffer, n);
+    pos += n;
+  strcpy(ed->filename, "<stdin>");
+  ed->newfile = 1;
+  ed->dirty = 0;
+static void save_editor(struct editor *ed) {
+  int rc;
+  if (!ed->dirty && !ed->newfile) return;
+  if (ed->newfile) {
+    if (!prompt(ed, "Save as: ", 1)) {
+      ed->refresh = 1;
+      return;
+    if (access((const char*) ed->env->linebuf, F_OK) == 0) {
+      display_message(ed, "Overwrite %s (y/n)? ", ed->env->linebuf);
+      if (!ask()) {
+        ed->refresh = 1;
+        return;
+    strcpy(ed->filename, (const char*) ed->env->linebuf);
+    ed->newfile = 0;
+  rc = save_file(ed);
+  if (rc < 0) {
+    display_message(ed, "Error %d saving document (%s)", errno, strerror(errno));
+    sleep(5);
+  ed->refresh = 1;
+static void close_editor(struct editor *ed) {
+  if (ed->dirty) {
+    display_message(ed, "Close %s without saving changes (y/n)? ", ed->filename);
+    if (!ask()) {
+      ed->refresh = 1;
+      return;
+  if (!ed) {
+    new_file(ed, "");
+  ed->refresh = 1;
+static void pipe_command(struct editor *ed) {
+#ifdef __rtems__
+    display_message(ed, "Not supported");
+    sleep(3);
+#else
+  FILE *f;
+  char buffer[512];
+  int n;
+  int pos;
+  if (!prompt(ed, "Command: ", 1)) {
+    ed->refresh = 1;
+    return;
+#ifdef SANOS
+  f = popen(ed->env->linebuf, "r2");
+#else
+  f = popen(ed->env->linebuf, "r");
+#endif
+  if (!f) {
+    display_message(ed, "Error %d running command (%s)", errno, strerror(errno));
+    sleep(5);
+  } else {
+    while ((n = fread(buffer, 1, sizeof(buffer), f)) > 0) {
+      insert(ed, pos, buffer, n);
+      pos += n;
+    moveto(ed, pos, 0);
+    pclose(f);
+  ed->refresh = 1;
+#endif
+static void find_text(struct editor *ed, int next) {
+  int slen;
+  if (!next) {
+    if (!prompt(ed, "Find: ", 1)) {
+      ed->refresh = 1;
+      return;
+    if (ed->env->search) free(ed->env->search);
+    ed->env->search = (unsigned char*) strdup((const char*) ed->env->linebuf);
+  if (!ed->env->search) return;
+  slen = strlen((const char*) ed->env->search);
+  if (slen > 0) {
+    unsigned char *match;
+    close_gap(ed);
+    match = (unsigned char*) strstr((char*) ed->start + ed->linepos + ed->col, (char*) ed->env->search);
+    if (match != NULL) {
+      int pos = match - ed->start;
+      ed->anchor = pos;
+      moveto(ed, pos + slen, 1);
+    } else {
+      outch('\007');
+  ed->refresh = 1;
+static void goto_line(struct editor *ed) {
+  int lineno, l, pos;
+  ed->anchor = -1;
+  if (prompt(ed, "Goto line: ", 1)) {
+    lineno = atoi((char*) ed->env->linebuf);
+    if (lineno > 0) {
+      pos = 0;
+      for (l = 0; l < lineno - 1; l++) {
+        if (pos < 0) break;
+    } else {
+      pos = -1;
+    if (pos >= 0) {
+      moveto(ed, pos, 1);
+    } else {
+      outch('\007');
+  ed->refresh = 1;
+struct editor *next_file(struct editor *ed) {
+  ed = ed->env->current = ed->next;
+  ed->refresh = 1;
+  return ed;
+static void jump_to_editor(struct editor *ed) {
+  int lineno = 0;
+  if (!get_selected_text(ed, filename, FILENAME_MAX)) {
+    char *p = filename;
+    int left = FILENAME_MAX - 1;
+    while (left > 0) {
+      if (ch < 0) break;
+      if (strchr("!@\"'#%&()[]{}*?+:;\r\n\t ", ch)) break;
+      *p++ = ch;
+      left--;
+      pos++;
+    *p = 0;
+    if (get(ed, pos) == ':') {
+      pos++;
+      for (;;) {
+        if (ch >= '0' && ch <= '9') {
+          lineno = lineno * 10 + (ch - '0');
+        } else {
+          break;
+        pos++;
+  if (!*filename) return;
+  ed = find_editor(env, filename);
+  if (ed) {
+  } else {
+    if (load_file(ed, filename) < 0) {
+      outch('\007');
+  if (lineno > 0) {
+    int pos = 0;
+    while (--lineno > 0) {
+    if (pos >= 0) moveto(ed, pos, 1);
+  ed->refresh = 1;
+static void redraw_screen(struct editor *ed) {
+  get_console_size(ed->env);
+  draw_screen(ed);
+static int quit(struct env *env) {
+  do {
+    if (ed->dirty) {
+      if (!ask()) return 0;
+    ed = ed->next;
+  return 1;
+static void help(struct editor *ed) {
+  gotoxy(0, 0);
+  clear_screen();
+  outstr("Editor Command Summary\r\n");
+  outstr("======================\r\n\r\n");
+  outstr("<up>         Move one line up (*)         Ctrl+N  New editor\r\n");
+  outstr("<down>       Move one line down (*)       Ctrl+O  Open file\r\n");
+  outstr("<left>       Move one character left (*)  Ctrl+S  Save file\r\n");
+  outstr("<right>      Move one character right (*) Ctrl+W  Close file\r\n");
+  outstr("<pgup>       Move one page up (*)         Ctrl+Q  Quit\r\n");
+  outstr("<pgdn>       Move one page down (*)       Ctrl+P  Pipe command\r\n");
+  outstr("Ctrl+<left>  Move to previous word (*)    Ctrl+A  Select all\r\n");
+  outstr("Ctrl+<right> Move to next word (*)        Ctrl+C  Copy selection to clipboard\r\n");
+  outstr("<home>       Move to start of line (*)    Ctrl+X  Cut selection to clipboard\r\n");
+  outstr("<end>        Move to end of line (*)      Ctrl+V  Paste from clipboard\r\n");
+  outstr("Ctrl+<home>  Move to start of file (*)    Ctrl+Z  Undo\r\n");
+  outstr("Ctrl+<end>   Move to end of file (*)      Ctrl+R  Redo\r\n");
+  outstr("<backspace>  Delete previous character    Ctrl+F  Find text\r\n");
+  outstr("<delete>     Delete current character     Ctrl+G  Find next\r\n");
+  outstr("Ctrl+<tab>   Next editor                  Ctrl+L  Goto line\r\n");
+  outstr("<tab>        Indent selection             F1      Help\r\n");
+  outstr("Shift+<tab>  Unindent selection           F3      Navigate to file\r\n");
+  outstr("                                          F5      Redraw screen\r\n");
+  outstr("\r\n(*) Extends selection if combined with Shift");
+  outstr("\r\nPress any key to continue...");
+  fflush(stdout);
+  getkey();
+  draw_screen(ed);
+  draw_full_statusline(ed);
+// Editor
+static void edit(struct editor *ed) {
+  int done = 0;
+  int key;
+  ed->refresh = 1;
+  while (!done) {
+    if (ed->refresh) {
+      draw_screen(ed);
+      ed->refresh = 0;
+      ed->lineupdate = 0;
+    } else if (ed->lineupdate) {
+      update_line(ed);
+      draw_statusline(ed);
+    } else {
+    position_cursor(ed);
+    fflush(stdout);
+    key = getkey();
+    if (key >= ' ' && key <= 0x7F) {
+#ifdef LESS
+      switch (key) {
+        case 'q': done = 1; break;
+        case '/': find_text(ed, 0); break;
+#else
+      insert_char(ed, (unsigned char) key);
+#endif
+    } else {
+      switch (key) {
+        case KEY_F1: help(ed); break;
+        case KEY_F2: select_toggle(ed); break;
+        case KEY_F3: jump_to_editor(ed); ed = ed->env->current; break;
+        case KEY_F5: redraw_screen(ed); break;
+        case KEY_F9: save_editor(ed); break;
+        case KEY_F10: done = 1; break;
+        case ctrl('y'): help(ed); break;
+        case ctrl('t'): top(ed, 0); break;
+        case ctrl('b'): bottom(ed, 0); break;
+#endif
+        case KEY_UP: up(ed, ed->selecting); break;
+        case KEY_DOWN: down(ed, ed->selecting); break;
+        case KEY_LEFT: left(ed, ed->selecting); break;
+        case KEY_RIGHT: right(ed, ed->selecting); break;
+        case KEY_HOME: home(ed, ed->selecting); break;
+        case KEY_END: end(ed, ed->selecting); break;
+        case KEY_PGUP: pageup(ed, ed->selecting); break;
+        case KEY_PGDN: pagedown(ed, ed->selecting); break;
+        case KEY_CTRL_RIGHT: wordright(ed, ed->selecting); break;
+        case KEY_CTRL_LEFT: wordleft(ed, ed->selecting); break;
+        case KEY_CTRL_HOME: top(ed, ed->selecting); break;
+        case KEY_CTRL_END: bottom(ed, ed->selecting); break;
+#if SHIFT_SELECT
+        case KEY_SHIFT_UP: up(ed, 1); break;
+        case KEY_SHIFT_DOWN: down(ed, 1); break;
+        case KEY_SHIFT_LEFT: left(ed, 1); break;
+        case KEY_SHIFT_RIGHT: right(ed, 1); break;
+        case KEY_SHIFT_PGUP: pageup(ed, 1); break;
+        case KEY_SHIFT_PGDN: pagedown(ed, 1); break;
+        case KEY_SHIFT_HOME: home(ed, 1); break;
+        case KEY_SHIFT_END: end(ed, 1); break;
+        case KEY_SHIFT_CTRL_RIGHT: wordright(ed, 1); break;
+        case KEY_SHIFT_CTRL_LEFT: wordleft(ed, 1); break;
+        case KEY_SHIFT_CTRL_HOME: top(ed, 1); break;
+        case KEY_SHIFT_CTRL_END: bottom(ed, 1); break;
+#endif
+        case KEY_CTRL_TAB: ed = next_file(ed); break;
+        case ctrl('e'): select_toggle(ed); break;
+        case ctrl('a'): select_all(ed); break;
+        case ctrl('c'): copy_selection(ed); break;
+        case ctrl('f'): find_text(ed, 0); break;
+        case ctrl('l'): goto_line(ed); break;
+        case ctrl('g'): find_text(ed, 1); break;
+        case ctrl('q'): done = 1; break;
+#ifdef LESS
+        case KEY_ESC: done = 1; break;
+#else
+        case KEY_TAB: indent(ed, (unsigned char*) INDENT); break;
+        case KEY_SHIFT_TAB: unindent(ed, (unsigned char*) INDENT); break;
+        case KEY_ENTER: newline(ed); break;
+        case KEY_BACKSPACE: backspace(ed); break;
+        case KEY_DEL: del(ed); break;
+        case ctrl('x'): cut_selection(ed); break;
+        case ctrl('z'): undo(ed); break;
+        case ctrl('r'): redo(ed); break;
+        case ctrl('v'): paste_selection(ed); break;
+        case ctrl('o'): open_editor(ed); ed = ed->env->current; break;
+        case ctrl('n'): new_editor(ed); ed = ed->env->current; break;
+        case ctrl('s'): save_editor(ed); break;
+        case ctrl('p'): pipe_command(ed); break;
+#endif
+        case ctrl('w'): close_editor(ed); ed = ed->env->current; break;
+// main
+int rtems_shell_main_edit(int argc, char *argv[]) {
+  struct env env;
+  int rc;
+  int i;
+  sigset_t blocked_sigmask, orig_sigmask;
+  struct termios tio;
+  struct termios orig_tio;
+#endif
+#ifdef SANOS
+  struct term *term;
+#endif
+  memset(&env, 0, sizeof(env));
+  for (i = 1; i < argc; i++) {
+    struct editor *ed = create_editor(&env);
+    rc = load_file(ed, argv[i]);
+    if (rc < 0 && errno == ENOENT) rc = new_file(ed, argv[i]);
+    if (rc < 0) {
+      perror(argv[i]);
+      return 0;
+  if (env.current == NULL) {
+    if (isatty(fileno(stdin))) {
+      new_file(ed, "");
+    } else {
+      read_from_stdin(ed);
+  env.current = env.current->next;
+#ifdef SANOS
+  term = gettib()->proc->term;
+  if (fdin != term->ttyin) dup2(term->ttyin, fdin);
+  if (fdout != term->ttyout) dup2(term->ttyout, fdout);
+#elif !defined(__rtems__)
+  if (!isatty(fileno(stdin))) {
+    if (!freopen("/dev/tty", "r", stdin)) perror("/dev/tty");
+#endif
+  setvbuf(stdout, NULL, 0, 8192);
+  tcgetattr(0, &orig_tio);
+#if !defined(__rtems__)
+  cfmakeraw(&tio);
+  tcsetattr(0, TCSANOW, &tio);
+#endif
+  if (getenv("TERM") && strcmp(getenv("TERM"), "linux") == 0) {
+    linux_console = 1;
+  } else {
+    outstr(CLRSCR);
+    outstr("\033[3 q");  // xterm
+    outstr("\033]50;CursorShape=2\a");  // KDE
+#endif
+  get_console_size(&env);
+  sigemptyset(&blocked_sigmask);
+  sigaddset(&blocked_sigmask, SIGINT);
+  sigaddset(&blocked_sigmask, SIGTSTP);
+  sigaddset(&blocked_sigmask, SIGABRT);
+  sigprocmask(SIG_BLOCK, &blocked_sigmask, &orig_sigmask);
+  for (;;) {
+    if (!env.current) break;
+    edit(env.current);
+    if (quit(&env)) break;
+  gotoxy(0, env.lines + 1);
+  outstr(RESET_COLOR CLREOL);
+  tcsetattr(0, TCSANOW, &orig_tio);
+#endif
+  while (env.current) delete_editor(env.current);
+  if (env.clipboard) free(env.clipboard);
+  if (env.search) free(env.search);
+  if (env.linebuf) free(env.linebuf);
+  setbuf(stdout, NULL);
+  sigprocmask(SIG_SETMASK, &orig_sigmask, NULL);
+  return 0;
+rtems_shell_cmd_t rtems_shell_EDIT_Command = {
+  "edit",                /* name */
+  "edit [file ...]",     /* usage */
+  "files",               /* topic */
+  rtems_shell_main_edit, /* command */
+  NULL,                  /* alias */
+  NULL                   /* next */
diff --git a/cpukit/libmisc/shell/shellconfig.h b/cpukit/libmisc/shell/shellconfig.h
index eacfac2..3776952 100644
--- a/cpukit/libmisc/shell/shellconfig.h
+++ b/cpukit/libmisc/shell/shellconfig.h
@@ -39,6 +39,7 @@ extern rtems_shell_cmd_t rtems_shell_MMOVE_Command;
 extern rtems_shell_cmd_t rtems_shell_JOEL_Command;
 extern rtems_shell_cmd_t rtems_shell_DATE_Command;
 extern rtems_shell_cmd_t rtems_shell_ECHO_Command;
+extern rtems_shell_cmd_t rtems_shell_EDIT_Command;
 extern rtems_shell_cmd_t rtems_shell_SLEEP_Command;
 extern rtems_shell_cmd_t rtems_shell_ID_Command;
 extern rtems_shell_cmd_t rtems_shell_TTY_Command;
@@ -175,6 +176,11 @@ extern rtems_shell_alias_t *rtems_shell_Initial_aliases[];
       &rtems_shell_ECHO_Command,
     #endif
     #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
+         !defined(CONFIGURE_SHELL_NO_COMMAND_EDIT)) || \
+        defined(CONFIGURE_SHELL_COMMAND_EDIT)
+      &rtems_shell_EDIT_Command,
+    #endif
+    #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
          !defined(CONFIGURE_SHELL_NO_COMMAND_SLEEP)) || \
         defined(CONFIGURE_SHELL_COMMAND_SLEEP)
       &rtems_shell_SLEEP_Command,
1.9.3 (Apple Git-50)
