[PATCH 4/5 v3] SPARC: Fatal_halt use source and exit codes
Mon Oct 6 11:01:14 UTC 2014
On 06/10/14 11:56, Daniel Hellstrom wrote:
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index 70d1785..65966b7 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1075,19 +1075,15 @@ void _CPU_Context_Initialize(
>   /* Fatal Error manager macros */
> +extern void _BSP_Fatal_halt(uint32_t source, uint32_t error)
> +  RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
>    * This routine copies _error into a known place -- typically a stack
>    * location or a register, optionally disables interrupts, and
>    * halts/stops the CPU.
> -#define _CPU_Fatal_halt( _source, _error ) \
> -  do { \
> -    uint32_t   level; \
> -    level = sparc_disable_interrupts(); \
> -    __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) ); \
> -    while (1); /* loop forever */ \
> -  } while (0)
> +#define _CPU_Fatal_halt( _source, _error ) _BSP_Fatal_halt( _source, _error )
I removed the other _BSP_* functions in the cpu.h files recently, so please use
_CPU_Fatal_halt() only.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
