[PATCH 4/5 v4] SPARC: Fatal_halt use source and exit codes
Daniel Hellstrom
daniel at gaisler.com
Mon Oct 6 11:35:17 UTC 2014
The Fatal_halt handler now have two options, either halt
as before or enter system error state to return to
debugger or simulator. The exit-code is now also
propagated to the debugger which is very useful for
testing.
The CPU_Fatal_halt handler was split up into two, since
the only the LEON3 support the CPU power down.
The LEON3 halt now uses the power-down instruction to save
CPU power. This doesn't stop a potential watch-dog timer
from expiring.
c/src/lib/libbsp/sparc/erc32/Makefile.am | 1 +
c/src/lib/libbsp/sparc/erc32/configure.ac | 5 +++
c/src/lib/libbsp/sparc/leon2/Makefile.am | 1 +
c/src/lib/libbsp/sparc/leon2/configure.ac | 5 +++
c/src/lib/libbsp/sparc/leon3/Makefile.am | 1 +
c/src/lib/libbsp/sparc/leon3/configure.ac | 5 +++
.../libbsp/sparc/leon3/startup/bsp_fatal_halt.c | 36 ++++++++++++++++++
.../libbsp/sparc/shared/startup/bsp_fatal_halt.c | 38 ++++++++++++++++++++
cpukit/score/cpu/sparc/rtems/score/cpu.h | 10 +----
9 files changed, 94 insertions(+), 8 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index b9f1c53..00e398b 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -46,6 +46,7 @@ libbsp_a_SOURCES += startup/bspidle.c
libbsp_a_SOURCES += startup/bspdelay.c
libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
+libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_halt.c
# ISR Handler
libbsp_a_SOURCES += ../../sparc/shared/cpu.c
libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
index 4cbfb7e..72a75d1 100644
--- a/c/src/lib/libbsp/sparc/erc32/configure.ac
+++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
@@ -43,6 +43,11 @@ RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
BSP will be enabled. In particular, SIS requires special
initialization not used on real ERC32 hardware.])
+RTEMS_BSPOPTS_SET([BSP_POWER_DOWN_AT_FATAL_HALT],[*],[])
+RTEMS_BSPOPTS_HELP([BSP_POWER_DOWN_AT_FATAL_HALT],
+[If defined, CPU is spinning on fatal exit. Otherwise generate system
+ error which will hand over to debugger, simulator, etc.])
RTEMS_BSP_CLEANUP_OPTIONS(0,1,1)
# Explicitly list all Makefiles here
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 3f8edf4..ac6f327 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -61,6 +61,7 @@ libbsp_a_SOURCES += ../../shared/bspinit.c
# ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
index 610a049..dd49a17 100644
--- a/c/src/lib/libbsp/sparc/leon2/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
@@ -36,6 +36,11 @@ RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
time spent in the idle task is minimized. This significantly reduces
the wall time required to execute the RTEMS test suites.])
RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index b8079c6..fa297ac 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -42,6 +42,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
libbsp_a_SOURCES += startup/bspreset.c
libbsp_a_SOURCES += startup/cpucounter.c
+libbsp_a_SOURCES += startup/bsp_fatal_halt.c
# ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
index 3fe1e48..8ace8a3 100644
--- a/c/src/lib/libbsp/sparc/leon3/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
@@ -38,6 +38,11 @@ RTEMS_BSPOPTS_HELP([BSP_LEON3_SMP],
[Always defined when on a LEON3 to enable the LEON3 support for
determining the CPU core number in an SMP configuration.])
+[If defined, CPU is powered down on fatal exit. Otherwise generate system
RTEMS_BSP_LINKCMDS
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
new file mode 100644
index 0000000..2f4bd3a
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
@@ -0,0 +1,36 @@
+ * @file
+ * @ingroup sparc_leon3
+ * @brief LEON3 BSP Fatal_halt handler.
+ * COPYRIGHT (c) 2014.
+ * Aeroflex Gaisler AB.
+#include <leon.h>
+#include <rtems/score/sparc.h>
+#ifdef BSP_POWER_DOWN_AT_FATAL_HALT
+/* Power down LEON CPU on fatal error exit */
+void _CPU_Fatal_halt(uint32_t source, uint32_t error)
+ sparc_disable_interrupts();
+ leon3_power_down_loop();
+#else
+/* return to debugger, simulator, hypervisor or similar by exiting
+ * with an error code. g1=1, g2=FATAL_SOURCE, G3=error-code.
+ sparc_syscall_exit(source, error);
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
index 0000000..2cc7b6d
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
@@ -0,0 +1,38 @@
+ * @file
+ * @ingroup sparc_bsp
+ * @brief ERC32/LEON2 BSP Fatal_halt handler.
+/* Spin CPU on fatal error exit */
+ uint32_t level = sparc_disable_interrupts();
+ __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) );
+ while (1) ; /* loop forever */
+#else
+#endif
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 70d1785..6ce065c 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1080,14 +1080,8 @@ void _CPU_Context_Initialize(
* location or a register, optionally disables interrupts, and
* halts/stops the CPU.
-#define _CPU_Fatal_halt( _source, _error ) \
- do { \
- uint32_t level; \
- level = sparc_disable_interrupts(); \
- __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \
- while (1); /* loop forever */ \
- } while (0)
+extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
+ RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
/* end of Fatal Error manager macros */
1.7.0.4
