[PATCH 5/5 v2] LEON3: use CPU_Fatal_halt for halt
Daniel Hellstrom
daniel at gaisler.com
Mon Oct 6 12:53:56 UTC 2014
By removing the bsp_reset() mechanism and instead relying on the
CPU_Fatal_halt() routine SMP and single-core can halt by updating
the _Internal_errors_What_happened structure and set the state to
SYSTEM_STATE_TERMINATED (the generic way). This will be better
for test scripts and debugger that can generically look into why
the OS stopped.
For SMP systems, only the fatal-reporting CPU waits until all other
CPUs are powered down (with a time out of one clock tick). The
reason why a fatal stop happend may be because CPU0 was soft-locked
up so we can never trust that CPU0 should do the halt for us.
c/src/lib/libbsp/sparc/leon3/Makefile.am | 4 +-
c/src/lib/libbsp/sparc/leon3/configure.ac | 2 +-
c/src/lib/libbsp/sparc/leon3/startup/bspclean.c | 87 +++++++++++++++++++++++
c/src/lib/libbsp/sparc/leon3/startup/bspreset.c | 62 ----------------
4 files changed, 90 insertions(+), 65 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bspclean.c
delete mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index fa297ac..c5c9b77 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -32,14 +32,14 @@ noinst_LIBRARIES += libbsp.a
libbsp_a_SOURCES =
# startup
-libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
+libbsp_a_SOURCES += startup/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c \
../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c \
startup/setvec.c \
startup/spurious.c startup/bspidle.S startup/bspdelay.c \
../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
-libbsp_a_SOURCES += startup/bspreset.c
libbsp_a_SOURCES += startup/cpucounter.c
libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
libbsp_a_SOURCES += startup/bsp_fatal_halt.c
diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
index 8ace8a3..c29dc52 100644
--- a/c/src/lib/libbsp/sparc/leon3/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
@@ -43,7 +43,7 @@ RTEMS_BSPOPTS_HELP([BSP_POWER_DOWN_AT_FATAL_HALT],
[If defined, CPU is powered down on fatal exit. Otherwise generate system
error which will hand over to debugger, simulator, etc.])
-RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
+RTEMS_BSP_CLEANUP_OPTIONS(0, 0, 1)
RTEMS_BSP_LINKCMDS
# Explicitly list all Makefiles here
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspclean.c b/c/src/lib/libbsp/sparc/leon3/startup/bspclean.c
new file mode 100644
index 0000000..0d7d855
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspclean.c
@@ -0,0 +1,87 @@
+ * @file
+ * @ingroup sparc_leon3
+ * @brief LEON3 BSP fatal extension
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * COPYRIGHT (c) 2014
+ * Aeroflex Gaisler
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <rtems/bspIo.h>
+#include <rtems/score/smpimpl.h>
+#include <rtems/score/schedulerimpl.h>
+void bsp_fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code code
+ /* On SMP we must wait for all other CPUs not requesting a fatal halt, they
+ * are responding to another CPU's fatal request. These CPUs goes into
+ * power-down. The CPU requesting fatal halt waits for the others and then
+ * handles the system shutdown via the normal procedure.
+ #ifdef RTEMS_SMP
+ if ((source == RTEMS_FATAL_SOURCE_SMP) &&
+ (code == SMP_FATAL_SHUTDOWN_RESPONSE)) {
+ leon3_power_down_loop(); /* CPU didn't start shutdown sequence .. */
+ } else {
+ volatile struct irqmp_regs *irqmp = LEON3_IrqCtrl_Regs;
+ if (irqmp != NULL) {
+ * Value was choosen to get something in the magnitude of 1ms on a 200MHz
+ * processor.
+ uint32_t max_wait = 1234567;
+ uint32_t self_cpu = rtems_get_current_processor();
+ uint32_t cpu_count = rtems_get_processor_count();
+ uint32_t halt_mask = 0;
+ uint32_t i;
+ for (i = 0; i < cpu_count; ++i) {
+ const Scheduler_Assignment *assignment = _Scheduler_Get_assignment( i );
+ if ( (i != self_cpu) &&
+ _Scheduler_Should_start_processor( assignment ) ) {
+ halt_mask |= UINT32_C(1) << i;
+ /* Wait some time for secondary processors to halt */
+ i = 0;
+ while ((irqmp->mpstat & halt_mask) != halt_mask && i < max_wait) {
+ ++i;
+ #endif
+ #if (BSP_PRINT_EXCEPTION_CONTEXT)
+ if ( source == RTEMS_FATAL_SOURCE_EXCEPTION ) {
+ rtems_exception_frame_print( (const rtems_exception_frame *) code );
+ #endif
+ * If user wants to implement custom reset/reboot it can be done here
+ #if (BSP_RESET_BOARD_AT_EXIT)
+ bsp_reset();
+ #endif
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c b/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
deleted file mode 100644
index c642a75..0000000
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
+++ /dev/null
@@ -1,62 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <bsp/bootcard.h>
-#include <leon.h>
-#ifdef RTEMS_SMP
-void bsp_reset(void)
- uint32_t self_cpu = rtems_get_current_processor();
- if (self_cpu == 0) {
- volatile struct irqmp_regs *irqmp = LEON3_IrqCtrl_Regs;
- if (irqmp != NULL) {
- * Value was choosen to get something in the magnitude of 1ms on a 200MHz
- * processor.
- uint32_t max_wait = 1234567;
- uint32_t cpu_count = rtems_get_processor_count();
- uint32_t halt_mask = 0;
- uint32_t i;
- for (i = 0; i < cpu_count; ++i) {
- if (i != self_cpu) {
- halt_mask |= UINT32_C(1) << i;
- /* Wait some time for secondary processors to halt */
- i = 0;
- while ((irqmp->mpstat & halt_mask) != halt_mask && i < max_wait) {
- ++i;
- __asm__ volatile (
- "mov 1, %g1\n"
- "ta 0\n"
- "nop"
- leon3_power_down_loop();
-#endif /* RTEMS_SMP */
1.7.0.4
