[PATCH 2/3] LEON3 SMP: support static interrupt affinity
Daniel Hellstrom daniel at gaisler.com
Tue Oct 7 09:10:45 UTC 2014
 c/src/lib/libbsp/sparc/leon3/include/bsp.h     |   11 +++++++
 c/src/lib/libbsp/sparc/shared/irq/irq-shared.c |   38 ++++++++++++++++++++----
 2 files changed, 43 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index a4a4a6f..f398499 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -222,6 +222,17 @@ extern void BSP_shared_interrupt_mask(int irq);
 extern unsigned char LEON3_mp_irq;
+#ifdef RTEMS_SMP
+/* Weak table used to implement static interrupt CPU affinity in a SMP
+ * configuration. The array index is the interrupt to be looked up, and
+ * the array[INTERRUPT] content is the CPU number relative to boot CPU
+ * index that will be servicing the interrupts from the IRQ source. The
+ * default is to let the first CPU (the boot cpu) to handle all
+ * interrupts (all zeros).
+extern unsigned char bsp_irq2cpu[32];
+#endif
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
index b49621f..af1ce44 100644
--- a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
+++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
@@ -2,6 +2,30 @@
 #include <bsp.h>
 #include <bsp/irq-generic.h>
+#if defined(RTEMS_SMP) && defined(LEON3)
+/* Interrupt to CPU map. Default to CPU0 since in BSS. */
+unsigned char bsp_irq2cpu[32] __attribute__((weak));
+/* On SMP use map table above relative to SMP Boot CPU (normally CPU0) */
+static inline int bsp_irq_cpu(int irq)
+  /* protect from bad user configuration, default to boot cpu */
+  if (rtems_configuration_get_maximum_processors() <= bsp_irq2cpu[irq])
+    bsp_irq2cpu[irq] = 0;
+  return LEON3_Cpu_Index + bsp_irq2cpu[irq];
+#else
+/* when not SMP the local CPU is returned */
+#ifdef LEON3
+  return _LEON3_Get_current_processor();
+#else
+  return 0;
+#endif
+#endif
 static inline void bsp_dispatch_irq(int irq)
        bsp_interrupt_handler_entry *e =
@@ -54,26 +78,28 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
 rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
-       BSP_Unmask_interrupt((int)vector);
+  int irq = (int)vector;
+  BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
-       return RTEMS_SUCCESSFUL;
+  return RTEMS_SUCCESSFUL;
 rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
-       BSP_Mask_interrupt((int)vector);
+  BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
-       BSP_Mask_interrupt(irq);
 void BSP_shared_interrupt_unmask(int irq)
-       BSP_Unmask_interrupt(irq);
 void BSP_shared_interrupt_clear(int irq)
1.7.0.4
