[PATCH] LEON3: use interrupt layer in clock driver
Daniel Hellstrom
daniel at gaisler.com
Tue Oct 7 09:25:56 UTC 2014
Manupilating the interrupt control registers directly instead
of going through the interrupt layer can be deceiving.
c/src/lib/libbsp/shared/include/fatal.h | 1 +
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 23 ++++++++++++++++++++---
2 files changed, 21 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/shared/include/fatal.h b/c/src/lib/libbsp/shared/include/fatal.h
index e928bba..c650a91 100644
--- a/c/src/lib/libbsp/shared/include/fatal.h
+++ b/c/src/lib/libbsp/shared/include/fatal.h
@@ -49,6 +49,7 @@ typedef enum {
/* LEON3 fatal codes */
LEON3_FATAL_NO_IRQMP_CONTROLLER = BSP_FATAL_CODE_BLOCK(2),
LEON3_FATAL_CONSOLE_REGISTER_DEV,
+ LEON3_FATAL_CLOCK_INITIALIZATION,
/* LPC24XX fatal codes */
LPC24XX_FATAL_PL111_SET_UP = BSP_FATAL_CODE_BLOCK(3),
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index 5faf72d..f382f1a 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -20,6 +20,8 @@
#include <bsp.h>
#include <bspopts.h>
+#include <bsp/fatal.h>
+#include <rtems/rtems/intr.h>
#include <ambapp.h>
#include <rtems/score/profiling.h>
@@ -34,8 +36,6 @@
volatile struct gptimer_regs *LEON3_Timer_Regs = 0;
static int clkirq;
-#define CLOCK_VECTOR LEON_TRAP_TYPE( clkirq )
static void leon3_clock_profiling_interrupt_delay(void)
#ifdef RTEMS_PROFILING
@@ -104,9 +104,26 @@ static void leon3_clock_profiling_interrupt_delay(void)
#define Clock_driver_support_install_isr( _new, _old ) \
do { \
- _old = set_vector( _new, CLOCK_VECTOR, 1 ); \
+ (_old) = NULL; \
+ bsp_clock_handler_install(_new); \
} while(0)
+static void bsp_clock_handler_install(rtems_isr *new)
+ rtems_status_code sc;
+ sc = rtems_interrupt_handler_install(
+ clkirq,
+ "Clock",
+ RTEMS_INTERRUPT_UNIQUE,
+ new,
+ NULL
+ if (sc != RTEMS_SUCCESSFUL) {
+ rtems_fatal(RTEMS_FATAL_SOURCE_BSP, LEON3_FATAL_CLOCK_INITIALIZATION);
#define Clock_driver_support_initialize_hardware() \
do { \
LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].reload = \
1.7.0.4
