[PATCH 1/2] capture: Move logging of task record to occur after filter check.
Jennifer Averett
jennifer.averett at oarcorp.com
Tue Oct 7 18:43:22 UTC 2014
cpukit/libmisc/capture/capture.c | 39 +++++++++++++------
cpukit/libmisc/capture/capture.h | 24 +++++++++++-
cpukit/libmisc/capture/capture_user_extension.c | 51 +++++++++++++------------
3 files changed, 78 insertions(+), 36 deletions(-)
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 8bece88..74b563d 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -313,26 +313,35 @@ rtems_capture_create_control (rtems_name name, rtems_id id)
return control;
-void rtems_capture_record_task( rtems_tcb* tcb )
+void rtems_capture_initialize_task( rtems_tcb* tcb )
rtems_capture_control_t* control;
- rtems_capture_task_record_t rec;
- void* ptr;
+ rtems_name name;
- rtems_object_get_classic_name( tcb->Object.id, &rec.name );
* We need to scan the default control list to initialise
* this control if it is a new task.
+ rtems_object_get_classic_name( tcb->Object.id, &name );
if (tcb->Capture.control == NULL) {
for (control = capture_controls; control != NULL; control = control->next)
if (rtems_capture_match_name_id (control->name, control->id,
- rec.name, tcb->Object.id))
+ name, tcb->Object.id))
tcb->Capture.control = control;
+ tcb->Capture.flags |= RTEMS_CAPTURE_INIT_TASK;
+void rtems_capture_record_task( rtems_tcb* tcb )
+ rtems_capture_task_record_t rec;
+ void* ptr;
+ rtems_object_get_classic_name( tcb->Object.id, &rec.name );
rec.stack_size = tcb->Start.Initial_stack.size;
rec.start_priority = _RTEMS_tasks_Priority_from_Core(
tcb->Start.initial_priority
@@ -1224,6 +1233,8 @@ rtems_capture_release (uint32_t count)
rtems_capture_record_t* rec;
uint32_t counted;
size_t ptr_size = 0;
+ size_t rel_size = 0;
+ rtems_status_code ret_val = RTEMS_SUCCESSFUL;
rtems_interrupt_lock_acquire (&capture_lock, &lock_context);
@@ -1237,26 +1248,32 @@ rtems_capture_release (uint32_t count)
ptr = rtems_capture_buffer_peek( &capture_records, &ptr_size );
_Assert(ptr_size >= (count * sizeof(*rec) ));
- ptr_size = 0;
+ rel_size = 0;
while (counted--)
rec = (rtems_capture_record_t*) ptr;
- ptr_size += rec->size;
+ rel_size += rec->size;
+ _Assert( rel_size <= ptr_size );
ptr += rec->size;
+ if (rel_size > ptr_size ) {
+ ret_val = RTEMS_INVALID_NUMBER;
+ rel_size = ptr_size;
capture_count -= count;
if (count)
- rtems_capture_buffer_free( &capture_records, ptr_size );
+ rtems_capture_buffer_free( &capture_records, rel_size );
capture_flags &= ~RTEMS_CAPTURE_READER_ACTIVE;
rtems_interrupt_lock_release (&capture_lock, &lock_context);
- return RTEMS_SUCCESSFUL;
+ return ret_val;
diff --git a/cpukit/libmisc/capture/capture.h b/cpukit/libmisc/capture/capture.h
index c4edc16..8e0bd1a 100644
--- a/cpukit/libmisc/capture/capture.h
+++ b/cpukit/libmisc/capture/capture.h
@@ -141,7 +141,8 @@ typedef struct rtems_capture_control_s
* Task flags.
#define RTEMS_CAPTURE_TRACED (1U << 0)
-#define RTEMS_CAPTURE_RECORD_TASK (1U << 1)
+#define RTEMS_CAPTURE_INIT_TASK (1U << 1)
+#define RTEMS_CAPTURE_RECORD_TASK (1U << 2)
* @brief Capture record.
@@ -598,6 +599,15 @@ const char*
rtems_capture_event_text (int event);
+ * @brief Capture initialize task
+ * This function initializes capture control in the tcb.
+ * @param[in] tcb is the task control block for the task
+void rtems_capture_initialize_task( rtems_tcb* tcb );
* @brief Capture record task.
* This function records a new capture task record.
@@ -619,6 +629,18 @@ static inline bool rtems_capture_task_recorded( rtems_tcb* tcb ) {
+ * @brief Capture task initialized
+ * This function returns true if this task information has been
+ * initialized.
+static inline bool rtems_capture_task_initialized( rtems_tcb* tcb ) {
+ return ( (tcb->Capture.flags & RTEMS_CAPTURE_INIT_TASK) != 0 );
* @brief Capture get task id.
* This function returns the task id.
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
index 4c7bc1d..69b8d48 100644
--- a/cpukit/libmisc/capture/capture_user_extension.c
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -95,6 +95,9 @@ static inline void rtems_capture_record (
if (rtems_capture_filter( tcb, events) )
return;
+ if (!rtems_capture_task_recorded (tcb))
+ rtems_capture_record_task (tcb);
rtems_capture_begin_add_record (tcb, events, size, &ptr);
rtems_capture_end_add_record ( ptr );
@@ -141,13 +144,13 @@ rtems_capture_create_task (rtems_tcb* ct,
* been created before the capture engine was open. Add them.
- if (!rtems_capture_task_recorded (ct))
- rtems_capture_record_task (ct);
+ if (!rtems_capture_task_initialized (ct))
+ rtems_capture_initialize_task (ct);
* Create the new task's capture control block.
- rtems_capture_record_task (nt);
+ rtems_capture_initialize_task (nt);
if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
@@ -170,11 +173,11 @@ rtems_capture_start_task (rtems_tcb* ct,
if (st == NULL)
- rtems_capture_record_task (st);
+ rtems_capture_initialize_task (st);
if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
@@ -195,11 +198,11 @@ rtems_capture_restart_task (rtems_tcb* ct,
- if (!rtems_capture_task_recorded (rt))
- rtems_capture_record_task (rt);
+ if (!rtems_capture_task_initialized (rt))
+ rtems_capture_initialize_task (rt);
if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
@@ -215,11 +218,11 @@ static void
rtems_capture_delete_task (rtems_tcb* ct,
rtems_tcb* dt)
- if (!rtems_capture_task_recorded (dt))
- rtems_capture_record_task (dt);
+ if (!rtems_capture_task_initialized (dt))
+ rtems_capture_initialize_task (dt);
if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
@@ -239,8 +242,8 @@ rtems_capture_begin_task (rtems_tcb* bt)
- if (!rtems_capture_task_recorded (bt))
- rtems_capture_record_task (bt);
+ if (!rtems_capture_task_initialized (bt))
+ rtems_capture_initialize_task (bt);
if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
@@ -258,8 +261,8 @@ rtems_capture_exitted_task (rtems_tcb* et)
- if (!rtems_capture_task_recorded (et))
- rtems_capture_record_task (et);
+ if (!rtems_capture_task_initialized (et))
+ rtems_capture_initialize_task (et);
if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
@@ -276,8 +279,8 @@ rtems_capture_terminated_task (rtems_tcb* tt)
- if (!rtems_capture_task_recorded (tt))
- rtems_capture_record_task (tt);
+ if (!rtems_capture_task_initialized (tt))
+ rtems_capture_initialize_task (tt);
if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
@@ -300,11 +303,11 @@ rtems_capture_switch_task (rtems_tcb* ct,
rtems_capture_time_t time;
- if (!rtems_capture_task_recorded (ht))
- rtems_capture_record_task (ht);
+ if (!rtems_capture_task_initialized (ht))
+ rtems_capture_initialize_task (ht);
* Update the execution time. Assume the time will not overflow
1.8.1.4
