ISR Disable/Enable on Moxie
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Oct 7 20:45:11 UTC 2014
Hi
In reviewing the warnings in the build logs, I realized that
the Moxies port does not implement _ISR_Disable or
_ISR_Enable.
Anthony, could you provide the little bit of code needed for
this? It appears to just be writing a 1 to special register 1
but you know better than anyone. :)
Thanks.
