[PATCH 01/52] sparc64/shared/clock/ckinit.c: Clean up formatting
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 8 19:15:52 UTC 2014
c/src/lib/libbsp/sparc64/shared/clock/ckinit.c | 31 +++++++++++++-------------
1 file changed, 16 insertions(+), 15 deletions(-)
diff --git a/c/src/lib/libbsp/sparc64/shared/clock/ckinit.c b/c/src/lib/libbsp/sparc64/shared/clock/ckinit.c
index d601a93..11779c4 100644
--- a/c/src/lib/libbsp/sparc64/shared/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc64/shared/clock/ckinit.c
@@ -3,7 +3,9 @@
* This file provides a template for the clock device driver initialization.
* Modified for sun4v - niagara
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
@@ -21,7 +23,7 @@
#include <bspopts.h>
#include <boot/ofw.h>
-/* this is default frequency for simics simulator of niagara. Use the
+/* This is default frequency for simics simulator of niagara. Use the
* get_Frequency function to determine the CPU clock frequency at runtime.
#define CPU_FREQ (5000000)
@@ -33,16 +35,16 @@ uint64_t sparc64_cycles_per_tick;
static unsigned int get_Frequency(void)
- phandle root = ofw_find_device("/");
- unsigned int freq;
- if (ofw_get_property(root, "clock-frequency", &freq, sizeof(freq)) <= 0) {
- printk("Unable to determine frequency, default: 0x%x\n",CPU_FREQ);
- return CPU_FREQ;
- return freq;
+ phandle root = ofw_find_device("/");
+ unsigned int freq;
+ if (ofw_get_property(root, "clock-frequency", &freq, sizeof(freq)) <= 0) {
+ printk("Unable to determine frequency, default: 0x%x\n",CPU_FREQ);
+ return CPU_FREQ;
+ return freq;
void Clock_driver_support_at_tick(void)
@@ -85,13 +87,14 @@ void Clock_driver_support_at_tick(void)
void Clock_driver_support_initialize_hardware(void)
- uint64_t tick_reg;
+ uint64_t tick_reg;
int bit_mask;
bit_mask = SPARC_SOFTINT_TM_MASK | SPARC_SOFTINT_SM_MASK | (1<<14);
sparc64_clear_interrupt_bits(bit_mask);
- sparc64_cycles_per_tick = rtems_configuration_get_microseconds_per_tick()*(get_Frequency()/1000000);
+ sparc64_cycles_per_tick =
+ rtems_configuration_get_microseconds_per_tick()*(get_Frequency()/1000000);
#if defined (SUN4U)
sparc64_read_tick(tick_reg);
@@ -109,12 +112,10 @@ void Clock_driver_support_initialize_hardware(void)
#endif
#define Clock_driver_support_shutdown_hardware( ) \
do { \
} while ( 0 )
#include "../../../shared/clockdrv_shell.h"
1.9.3
