[PATCH 22/52] bfin/eZKit533/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 19:16:13 UTC 2014
 c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c | 17 +++++------------
 1 file changed, 5 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c b/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
index 63c2d66..503fb6e 100644
--- a/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
+++ b/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
@@ -1,10 +1,9 @@
 /*  bspstart.c for eZKit533
- *  This routine starts the application.  It includes application,
- *  board, and monitor specific initialization and configuration.
- *  The generic CPU dependent initialization has been performed
- *  before this routine is invoked.
+ *  This routine does the bulk of the system initialisation.
  *  Copyright (c) 2006 by Atos Automacao Industrial Ltda.
  *             written by Alain Schaefer <alain.schaefer at easc.ch>
  *                    and Antonio Giovanini <antonio at atos.com.br>
@@ -14,8 +13,8 @@
  *  http://www.rtems.org/license/LICENSE.
 #include <bsp.h>
+#include <bsp/bootcard.h>
 #include <cplb.h>
 #include <libcpu/interrupt.h>
@@ -80,12 +79,6 @@ void bsp_pretasking_hook(void)
   bfin_interrupt_init();
- *  bsp_start
- *  This routine does the bulk of the system initialization.
 void bsp_start( void )
   /* BSP Hardware Initialization*/
1.9.3
