[PATCH 25/52] m68k/mcf5225x/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 19:16:16 UTC 2014
 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c | 17 +++++------------
 1 file changed, 5 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c b/c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c
index a373636..af47202 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c
+++ b/c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c
@@ -1,11 +1,8 @@
- *  BSP startup
- *  This routine starts the application.  It includes application,
- *  board, and monitor specific initialization and configuration.
- *  The generic CPU dependent initialization has been performed
- *  before this routine is invoked.
+ *  This routine does the bulk of the system initialisation.
  *  Author:
  *    David Fiddes, D.J at fiddes.surfaid.org
  *    http://www.calm.hw.ac.uk/davidf/coldfire/
@@ -19,6 +16,7 @@
 #include <bsp.h>
+#include <bsp/bootcard.h>
  * Cannot be frozen
@@ -44,11 +42,6 @@ void _CPU_cache_disable_data(void) {}
 void _CPU_cache_invalidate_entire_data(void) {}
 void _CPU_cache_invalidate_1_data_line(const void *addr) {}
- *  bsp_start
- *  This routine does the bulk of the system initialisation.
 void __attribute__((weak)) bsp_start(void)
1.9.3
